308 Mechanical Fuel Pump Recommendations?
_Big T_
Posted 16 May 2008 - 02:31 PM
I got the 308 UC dyno'ed yesterday and I have been advised to upgrade the fuel pump as it is leaning out at high (sustained) revs. It is ok for a quick squirt but if I were to run it down the 1/4 I would have no fuel pressure at about 2/3 track.
The engine isnt a super horsepower monster as its putting out 194 hp at the wheels. There is more in it but the lack of fuel supply is holding it back.
I believe I have a standard 308 pump at the moment and I'd like to know what other people are using or recommend.
I do not want to use an electric unit for various reasons (hooking it up, noise, safety aspects etc).
Any advice would be greatly appreciated.
Cheers,
Big T
Posted 16 May 2008 - 03:00 PM
Get yourself an L34 fuel pump. They look the same as a standard pump, but can pump up to 7psi. I bought one of these for my car off ebay amd have never had fuel pressure issues. My lil 253 pumps out 142 killer wasps, so the l34 pump should work for you to
_Big T_
Posted 16 May 2008 - 03:42 PM
Are they hard to fit up, or more to the point, is there anything I need to be careful of when doing the swap?
Cheers,
T
Posted 16 May 2008 - 03:55 PM
As fas as i am aware, there are no specials tricks you need to know as far as putting them in...
Posted 16 May 2008 - 04:11 PM
_Lostit_
Posted 16 May 2008 - 04:41 PM
_Big T_
Posted 16 May 2008 - 04:55 PM
Electric may be a better option but I really dont want to fiddle around with wiring it all up. Electronics piss me off enough already without having something else to worry about. I just want to be able to unbolt the old one and bolt on a new one.
I am a simple man
_Big T_
Posted 16 May 2008 - 05:29 PM
I wanted to add that a standard pump is okay for me at the moment. Its not until I need to hold the pedal flat for longer than 8 secs i.e drag racing that its going require an upgrade.
Cheers,
T
Posted 16 May 2008 - 05:39 PM
That's easy!Its not until I need to hold the pedal flat for longer than 8 secs i.e drag racing that its going require an upgrade.
Just set up the rest of the car to run 8's!
_Big T_
Posted 16 May 2008 - 05:57 PM
_pallbag_
Posted 16 May 2008 - 07:47 PM
Posted 16 May 2008 - 09:41 PM
_Big T_
Posted 16 May 2008 - 10:51 PM
The more I research this the more it looks like I will have to go down the Electronic path. Looks like I will have to bite the bullet and get over my electrophobia
There seems to be a few options for mech pumps on Chev engines but not much for 308's (unless I want to get an Ozrace kit but they are exy).
Time to hit the search button again and look for a quiet electronic unit.
Edited by Big T, 16 May 2008 - 10:55 PM.
Posted 16 May 2008 - 11:03 PM
Posted 16 May 2008 - 11:08 PM
Mounting and location will also play a part here.
_Big T_
Posted 17 May 2008 - 12:57 AM
ALX76 - Ive done a bit if searching and from what I can gather a Carter Black with rubber mounts might be a good, cost effective option. As I need to fit a relay to the coil to cut the pump off in case of an accident and I have a few other electrical gremlins I reckon I will just get a sparky to wire it up for me.
Posted 17 May 2008 - 08:12 AM
Posted 17 May 2008 - 10:51 AM
I have used the OZNOS setup and been very impressed with it. Yes it is expensive but it works.
As for the carter, every one I have ever used/tuned has required the use of a larger needle and seat. Adjusting the float level may also help. This won't cure the falling fuel pressure but it will help you get more than 8 sec at WOT.
_MAWLER_
Posted 17 May 2008 - 04:27 PM
Have you used/seen the OZRACE mech pump used Struggler or are you just saying that their NOS system works?
#21
Posted 17 May 2008 - 07:18 PM
#22
Posted 17 May 2008 - 08:30 PM
Anybody care to show me a holden V8 mechanical fuel pulp with twin diaphragms?
Correctly installed you will have no further problems with an electric pump.
#23
_trna76hb_
Posted 17 May 2008 - 09:59 PM
#24
Posted 17 May 2008 - 10:16 PM
I am running a Holley Blue pump which comes with a regulator under $200 the wireing is not as hard as you think the pump comes with electrical drawings .
I mounted a relay in boot and main fuse close to battery .The teething problems i had was trying to run 7psi pressure by the time i got to the end of 2nd gear i was blowing 30 amp fuse .
I ran 3/8" alloy fuel line from tank to engine bay {good for 350-400hp they tell me} again easier than you might think fits in original clamps. Kept blowing fuses
I then mounted a Caterpillar 30 amp circuit breaker in place of fuse and dropped fuel pressure to 6 1/2 psi and have not had to reset it yetafter exhaustive testing.
I am running a 650 holley double pumper 4150 series with 69 jets up front and 74 jets in secondaries which drink more than me when pushed hard.
The pump copes no worries now but if i had my time over i would go a holley black pump as mine is quite noisey a mate of mine has got a holey black which is considerably quieter.
#25
Posted 18 May 2008 - 05:50 AM
I have an Endelbrock Performer mech pump on mine, flows adequately
