9 inch axle length
#1 _Demag_
Posted 27 May 2008 - 08:44 PM
I am in the process of converting a 9 inch to fit in a Lx . I am going to copy a banjo that has come out of an LX and keep the same width . My question to members is how long do I have to cut my axles as the centre is offset and one axle is longer than the other compared to our little banjos.
#2 _v8slrtorana_
Posted 27 May 2008 - 10:15 PM
Housing was std width.
#4 _Demag_
Posted 27 May 2008 - 10:58 PM
V8slrtorana ,you wouldn't have a photo of your housing so I can get an idea of how far you offset the centre section.
all the best
#5 _v8slrtorana_
Posted 28 May 2008 - 06:41 PM
Tapered roller = holden = easier. You can switch from torana drums, to hq drums to commodore discs on that bearing setup.
Ford solid roller = headache.
#6 _Demag_
Posted 30 May 2008 - 12:40 AM
are they salsbury axle tubes spigoted into the 9" housing ? Looks like a neat job .
I got my axle tube ends from Mcdonald bros today and now I will chase down tubing with a 70mm ID . Hopefully I can find tubing around that size with a 5mm wall . In that case I will have 80mm OD . I might post some pics when it is coming along .
#7 _slr6000_
Posted 31 May 2008 - 12:15 AM
The center of the diff will be offset as well as the tail shaft but doesn't foul the tunnel. change to torana or hq stud pattern, use the ford brakes and HG drums.
#8 _Demag_
Posted 31 May 2008 - 02:26 AM
#9 _slr6000_
Posted 31 May 2008 - 08:11 PM
To get all the brackets right I made a jig up using a standard diff, but moved the upper control arm mounts higher as the ford housing is larger than a banjo housing.
Then dropped the 9 inch in and weld up.
I found shortening the easy part, getting the brackets done took a bit of work.
#10 _Demag_
Posted 28 June 2008 - 10:04 PM
https://cache.gmh-to...pg?t=1214654527[/IMG]
#11 _slr6000_
Posted 03 July 2008 - 11:34 PM
heres a link that shows an alignment fixture to make sure you get it all straight.You have to watch out for distotion when welding it all up.
http://www.crankshaf...ear_end_housing
Another thing to get right is the pinion angle, you can work it out using an angle finder like this one.
http://cgi.ebay.com....1QQcmdZViewItem
Also a good idea to weld in some filler and drain plug bungs.
#12 _Demag_
Posted 04 July 2008 - 01:17 AM
Edited by Demag, 04 July 2008 - 01:20 AM.
#13 _slr6000_
Posted 04 July 2008 - 09:09 PM
Posted 04 July 2008 - 09:21 PM
when you set up the top bracket closest to the centre,
make sure you can still get the bush in.
I also put the drain plug off to one side so it doesnt get knocked about.
#15 _Demag_
Posted 05 July 2008 - 12:23 PM
Arrimar I am tossing up wether to put a drain plug in but if I do I was thinking exactly that.
cheers lads keep em coming in
