Hi,
Just in the process of putting the dash back in and have noticed that the small L shaped rod that connects to the nob i believe is missing.
Does anyone have some photos of how it is attached and what it looks like?
Young
LX Foot brake rod
_youngy_11_
, Jun 05 2008 11:57 AM
2 replies to this topic
#1 _youngy_11_
Posted 05 June 2008 - 11:57 AM
Posted 06 June 2008 - 02:59 PM
Hey Youngy..
I took a couple of pics for you mate..hopefully it will help you out.The rod pretty much comes from your knob and then bends up in front of the two L shaped levers which have teeth that bite onto the main Teethed section of the footbrake..if that makes sense.When the handle is turned or pulled it raises the two L shaped levers and releases the footbrake.Don't worry if you cant find it or make one to suit..not having it is a pretty good security device especially for those not in the know of toranas.You can just reach under and lift the two levers with your fingers to release the park brake.
Anyway here a re the two pics..Sorry about the quality but they were taken by torchlight.better than none though
Good luck !!
Good luck !!
#3 _youngy_11_
Posted 10 June 2008 - 11:48 AM
Ok thanks heaps for that will be having a good dig around for it soon.
Your photos do clear up what i thought it was.
Youngy
Youngy
