MY CAR WONT START!
#1 _UNVSM8_
Posted 08 June 2008 - 05:41 PM
its a fuel injected 5 ltr in to a UC hatch...
#2 _rorym_
Posted 08 June 2008 - 06:22 PM
#3 _UNVSM8_
Posted 08 June 2008 - 06:38 PM
which module? the ignition module?Check the module hanging off the side..know faulty unit.
#4 _Yella SLuR_
Posted 08 June 2008 - 07:54 PM
Posted 08 June 2008 - 08:10 PM
Put the test light to the negative side of the coil and to earth.
With the engine cranking, the test light should flash on and off.
If it doesn't flash, the problem is usually in the module or wiring to and from.
Posted 08 June 2008 - 10:03 PM
If this area is dry, the module has probably cooked and you'll need a new one.
Fill the hole with new paste when you put this one in.
Grant..
Posted 08 June 2008 - 10:27 PM
Posted 09 June 2008 - 12:20 AM
#9 _Lostit_
Posted 09 June 2008 - 09:13 AM
before you go to this part the coil lead good? the cap good? the rotor good?
#10 _Yella SLuR_
Posted 09 June 2008 - 09:27 AM
#11 _rorym_
Posted 09 June 2008 - 11:40 AM
Thats the sucker!Think he means the module that lives on the base of the distributor. Known issues with that little beasty.
#12 _UNVSM8_
Posted 09 June 2008 - 12:09 PM
ok well did this test and the light does not flash so then it could be the module...Put a test light to the positive side of the coil and to earth. With the key on, the light should light.
heres a pic of the back of my engine when it was out wheres the module?...
or is that ribbed little box that has to plugs to it? which i have no pic of..
Posted 09 June 2008 - 12:28 PM
#14 _UNVSM8_
Posted 09 June 2008 - 07:25 PM
#15 _Lostit_
Posted 09 June 2008 - 08:35 PM
