There was a post some time ago about what drill bits to use or were best for un picking panels. I can't seem to find it.
What is the best drill bit to use?
Is there a special bit for this purpose and if so what's it called.
Unpicking Panels
_HatchmanSS76_
, Jun 13 2008 08:43 AM
8 replies to this topic
#1 _HatchmanSS76_
Posted 13 June 2008 - 08:43 AM
#2 _JBM_
Posted 13 June 2008 - 08:53 AM
I think that the bits your referring to have 2 ends and short fluting, Ive seen these used in the sheetmetal industry for rivet holes. They are about 3 mm diameter, or 1/8" in the old money.
James
James
#3 _why-psi_
Posted 13 June 2008 - 09:01 AM
even better than drill bits is a "Spotweld cutter"
Posted 13 June 2008 - 08:14 PM
Hatchy,
When in doubt use a hack knife
#5 _RB26DETT_
Posted 13 June 2008 - 09:05 PM
i use spotweld drill bits
#6 _RB26DETT_
Posted 13 June 2008 - 09:07 PM
#7 _greenmachine215_
Posted 13 June 2008 - 11:00 PM
Craig, you should have asked me, im willing to come up with the gas axe
what are you unpicking? the straight hatch or the bent one?
Posted 13 June 2008 - 11:09 PM
Alot of the time i have just drilled right the way thru with a normal drill bit and use the hole left behind to plug weld the new section in place.
#9 _HatchmanSS76_
Posted 15 June 2008 - 01:04 PM
Working on the new one.Craig, you should have asked me, im willing to come up with the gas axe
No gas axe reqired. Just need to unpick some bits to fixed rusted sections.
Thanks guys for the drill bit info.
