'74 LH Torana Project
160 replies to this topic
#26 _BlownOutlaw_
_BlownOutlaw_
Posted 13 September 2008 - 07:05 PM
Just another update.
Removed the front seats last night and found $3 all up in change :D including some 1c pieces. This car has never been touched which is great. Did a lot of vacuming and still has the hessian insulation under the carpet, which I am leaving there, after all its not a race car of course :D The floor is all painted still original from factory and not a spot of rust seen, in pretty much perfect condx. Pretty happy with that. Ive welded up a plate to cover the original shifter hole and put a silastic under it and bolted that down to seal the hole. The main reason I had to pull the carpet back was too cut off the rear center console mounting bracket. Which I did and smoothed and painted and then modified that bracket to be one end of a shifter mounting plate bracket. At the front of this im just using the original front mount for the console. The plate is about 5mm aluminium.
Im thinking that at the front of this plate I may weld another plate angled up towards the heater vents to mount the gauges in.
Above is just a shot of the special vice jaws for doing the braided hose lines.
Might get another shot of the shifter plate in a moment.
#27 _BlownOutlaw_
_BlownOutlaw_
Posted 13 September 2008 - 07:43 PM
Here is a few more pics
Pic looking down under shifter plate a little
One of the front wheels with the new GTS caps.
Front of engine with modded bracked and new alt.
Trans cooler
#28 _BlownOutlaw_
_BlownOutlaw_
Posted 14 September 2008 - 06:39 PM
G'day slowly workin away at it.
Seats n things r back in and carpet. Ive run the shifter cable and its been attached to the box this arvo and adjusted with help from Kane355.
Ive also put the carb on and fuel fittings.
#29 _BlownOutlaw_
_BlownOutlaw_
Posted 16 September 2008 - 02:12 PM
Startin to look pretty trick
#30 MRLXSS
  • 12,414 posts
Posted 16 September 2008 - 02:22 PM
MMMM, that looks nice!
#31 orangeLJ
Posted 16 September 2008 - 02:23 PM
Nice!
I can answer one question, the laws dont say anything (well for NSW) about having HOT air blowing on the windscreen, only that there must be a air stream to de-mist the windscreen.
#32 _noslx_
_noslx_
Posted 16 September 2008 - 02:37 PM
good work mate...i,m looking forward to seein this finished :spoton:
#33 _TJ253_
_TJ253_
Posted 16 September 2008 - 03:46 PM
Looking Hot Gonna give the seats a little tidy up?
#34 Heath
  • 18,393 posts
Posted 16 September 2008 - 04:14 PM
Yes, two 85mm computer fans put into the ducts and wired up poxily for roadworthy? She'll be right mate.
#35 _BlownOutlaw_
_BlownOutlaw_
Posted 16 September 2008 - 06:49 PM
HI Guys
Thanks for the comments. OK on the windscreen de-mister question and suggestions, thats good stuff. I wouldn't mind the heater working if I could hook it up, but Im still not sure where im supposed to connect the hoses too in the manifold or pump?
Also still unsure what ports need to be blocked or what needs hoses ran to where for water passage around the manifold and the holes in the water pump. Ive emailed Edelbrock to see if they can help at all.
Re the seats, probably just put some covers over them for now and get them retrimmed later after all the rego and engineering is taken care off.
Been doing a little work on the fuel tank, its a big mumma 75 ltr aluminium job. Get some pics after thats been sorted a bit more.
Wont have much else to do after that really, except the electrical wiring and brakes. Oh and just make something to mount the 4 extra gauges. Oh and the exhaust ..doh forgot that bit. But I already have the mufflers and X pipe.
#36 _ChevLX_77_
_ChevLX_77_
Posted 16 September 2008 - 07:23 PM
My chev has one in the pump and one in the manifold. works alright
#37 _BlownOutlaw_
_BlownOutlaw_
Posted 18 September 2008 - 11:35 AM
Yes I am going to try to run one in the pump and one in the manifold, got fittings yesterday. Also got twin 2.5" tail pipes from the front of the diff back. Got a few other hose fittings too, should be able to complete the fuel system today. Really got to get to this gauge panel but been putting it off.
#38 _BlownOutlaw_
_BlownOutlaw_
Posted 19 September 2008 - 01:32 AM
Boot mounted 75ltr fuel cell.. Working on the gauge panel at present ... 1.30am go back out there in a moment
Yes the pickup should probably face the rear, but I dont think there will be a problem as its got the sump set up and foam, and besides ...its not a race car lol
Edited by BlownOutlaw, 19 September 2008 - 01:39 AM.
#39 _Brad1979UC_
_Brad1979UC_
Posted 19 September 2008 - 01:37 AM
And here i am at 1:30am about to go play PSP....
hehehe its cold out there man but its lookin the goods, the engine bay is coming together well
#40 _AGGRO_
_AGGRO_
Posted 19 September 2008 - 08:28 AM
This is coming along very nicely leigh! Still easier than having a missus eh! Haha. Would really love to cruise with your car when its done. Road trip?
#41 _BlownOutlaw_
_BlownOutlaw_
Posted 19 September 2008 - 12:24 PM
Gauge panel came up quite good and looks great in the car. Sorry the bottom switch is a bit out of alignment with the top one, but that happens when your rushing.
Thanks comment Brad. And Rowan, I dunno I think a missus would be easier. As for a road trip... lets not jump the gun, not even started the thing yet. Though I did dump some oil in the engine and box this morning. Not far away from the first fire up though.
Edited by BlownOutlaw, 19 September 2008 - 12:27 PM.
#42 _doogs_
_doogs_
Posted 19 September 2008 - 05:14 PM
Nice progress, keep the updates coming.
#43 _LH SLR 3300_
_LH SLR 3300_
Posted 20 September 2008 - 09:45 PM
I used HQ radiator hoses on my Chev LH as HQs had a 350 Chev option,& a Chevy more or less bolts into a Torrie like it does a HQ. I Had no dramas getting them either asked my local auto one & had them that afternoon. As for heater hoses from memory mine had a hose running from the top of the water pump & from an outlet on the drivers side of the inlet manifold (edelbrock performer) to the heater. There was another outlet on the passenger side of the manifold that I used for my temp sender. What water pump did you use? I used a long pump as that's what HQs used but I think 307s had a short pump. All the best with your project.
#44 _BlownOutlaw_
_BlownOutlaw_
Posted 20 September 2008 - 10:44 PM
Yeh its a short water pump. I have found some radiator hoses that will do the trick for now. There not HQ chev, but as you say, they would fit probably quite well. We'll see what happens. One is a Torana V8 hose and the other is a stateman V8, I had to cut the stato one a bit.
I have now got the heater arrangement sorted out, and what you have described sound pretty much exactly like what i have done. I only got this done today.
Have also run the oil press and water temp, plus exhaust temp cables today.
#45 Heath
  • 18,393 posts
Posted 21 September 2008 - 09:30 AM
lol I thought that shifter plate was going to fit in the bottom of a long 4cyl console until you made that guage panel. Still looks good though and is still unique
#46 _BlownOutlaw_
_BlownOutlaw_
Posted 21 September 2008 - 03:50 PM
OMG! Ive got oil pressure!
Not done a great deal since last post, but I have quickly set up the oil pressure gauge and connected the oil pipe up to it. Ive also removed the dizzy and put in an oil system primer. Connected a drill to the primer shaft and spun it with the drill, got oil flowing quite easy.
Only took a couple of moments and I got around 70psi just using a battery drill to spin it. Really happy with that, thats great.
Ive kept the drill on for about 3 mins to get oil up everywhere its needed before turning the motor over for the first time, which hopefully wont be too far away. Just a lot of electrical to do.
#47 _BlownOutlaw_
_BlownOutlaw_
Posted 24 September 2008 - 05:58 PM
G'day folks. Just a quick msg to tell you that its alive!! OMG!
Started the engine up this afternoon, with no dramas at all. Went on the 2nd hit of the key.
Straight out the extractors at the moment, but it sounding very healthy and crisp.
More info later. Running around with a pretty big grin at the moment. :D
#48 _noslx_
_noslx_
Posted 24 September 2008 - 06:31 PM
well done mate ...its always good when they fire staight up!!!!
#49 _LH SLR 3300_
_LH SLR 3300_
Posted 24 September 2008 - 07:04 PM
Congrats, always a good feeling when you hear them fire up for the first time. Well done & can't wait to see the car hit the road. Guess it won't be too long now.
#50 mrlctorana
mrlctorana
  • 572 posts
Posted 24 September 2008 - 07:26 PM
Good to hear mate, that smile will be even bigger once you get it on the road.
