'74 LH Torana Project
#51
_BlownOutlaw_
Posted 25 September 2008 - 12:59 AM
I only have 12V at the battery and the alternator does not seem to be doing anything so far, same reading as at the battery. There is S & L connections at the back of the alternator also, ive hooked the existing lead up to the L side and was told the S side goes to coil +. So I have done that too now, but ran it a few times without that one conneted.Ive got the main lead running to the battery. I only have the S & L connections done temporary, but should be getting the proper connector tomorrow. I get the red BATT light to light up on the dash before starting, and usually its supposed to go away once started, but its not going, I pressume thats because im not getting 14V from the alternator?
Will look into it further, but no doubt only 8V at the coil is the cause of the ignition issues.
#52
Posted 25 September 2008 - 05:05 AM
HI Guys
Thanks for the comments. OK on the windscreen de-mister question and suggestions, thats good stuff. I wouldn't mind the heater working if I could hook it up, but Im still not sure where im supposed to connect the hoses too in the manifold or pump?
As Chev LX 77 has stated, pump will be the suction side and manifold will be supply side for the heater as on most V8's.
#53
_BlownOutlaw_
Posted 25 September 2008 - 10:25 AM
#54
_BlownOutlaw_
Posted 25 September 2008 - 06:49 PM
Ive cut the resistor wire where it says do not cut, haha. Ive found the ignition switch connector and actually removed the resistor wire connector from the plug and snipped the resistor wire totally out of it. I spliced into the other pink wire from that connector and soldered it to the new wire going to the coil. Then I had no start ignitin so I had to also cut the yellow wire and feed it also to the lead to the coil.
This in turn gave enough voltage to switch in the alternator and when I started the car and checked coil voltage had 14.3 or so. So everything is good.
Shortly onto the rest of the exhaust system.
#55
_BlownOutlaw_
Posted 26 September 2008 - 02:47 PM
Into this ......
Looking pretty good so far.
Tail pipes and mufflers in a moment.
#56
_BlownOutlaw_
Posted 27 September 2008 - 05:53 PM
We were going to do the exhaust but have decided that be better of taking to an exhaust shop to the the rear section properly.
So we concentrated on getting the brakes working, which we have done after a number of dramas. It has commodore VP rear discs and Hoppers twin spot vented fronts.
Few questions if anyone reads this -
The Handbrake cable.... whats best do ??
The hoppers caliper seems to hit parts of the control arms at the front when they are turned full lock. Is this normal ??
#57
_LH SLR 3300_
Posted 27 September 2008 - 08:14 PM
#58
_BlownOutlaw_
Posted 27 September 2008 - 08:18 PM
#59
_LH SLR 3300_
Posted 27 September 2008 - 09:21 PM
#60
_BlownOutlaw_
Posted 27 September 2008 - 09:41 PM
Sorry, in my previous post I meant to type I CAN take photos later, not cant. Typo.
#61
_LH SLR 3300_
Posted 27 September 2008 - 09:54 PM
#62
_BlownOutlaw_
Posted 28 September 2008 - 12:24 PM
Again, nothing has been cleaned up as just trying to get all the engineering and rego done first. Clean up later.
#63
Posted 28 September 2008 - 01:43 PM
Seems strange, mine clears fine (that's one of the main reasons I shelled out for the kit). I wasn't sure it would clear the cross member bump to begin with when the suspension was at full droop, but at ride height everything is fine and ride height is quite lowThe hoppers caliper seems to hit parts of the control arms at the front when they are turned full lock. Is this normal ??
LHSLR3300 I'd love to see those pics of your relief in the top arm, I had someone with the same setup ask me about this the other day
#64
_LH SLR 3300_
Posted 28 September 2008 - 06:33 PM
IMG]https://cache.gmh-to...00/DSC00005.jpg[/IMG]
#65
_LH SLR 3300_
Posted 28 September 2008 - 06:51 PM
Hi 76lxhatch the photos are posted. I also had to get longer brake hoses made as both LH & HZ ones were too short. I also had to fit a " collar & spring " to keep the hose from rubbing on the tyre when turning. You may be able to see part of this set up in my pics.Seems strange, mine clears fine (that's one of the main reasons I shelled out for the kit). I wasn't sure it would clear the cross member bump to begin with when the suspension was at full droop, but at ride height everything is fine and ride height is quite low
Afraid I can't help much with the hand brake cables as I used a Skyline diff, but for various reasons I had a lot of different hand brake cables lying around and managed to find enough pieces to fit everything together without modifying cables, only moved the rear brackets on the body back a little. It might be worth taking some measurements and having a hunt around the wreckers for something that will fit straight in?
#66
_BlownOutlaw_
Posted 28 September 2008 - 07:39 PM
Ive sorted out the handbrake cable with the commodore rear discs, though I havent used it yet as have only completed one side. Im still using the origninal cable set up front to back from my Torana. Ive taken the drum brake cable levers from a Kingswood diff that i have here. Ive then cut them to correct side for this set up and welded them to the existing commodore lever using a TIG. Taken into account the extra cable length and positioned the lever accordingly before welding.
Should be OK. Will find out shortly.
#67
_LH SLR 3300_
Posted 28 September 2008 - 08:03 PM
#68
_BlownOutlaw_
Posted 29 September 2008 - 07:59 PM
Was the first time I drove it today, front drivers side tyre scraping guards over large bumps. Must lip the front wheel arches. Also when I was reversing into the shed its picked the front lower edge of the guard up and bent it, so will have to cut the edge off that too.
All seems good. Small water leak from the temp sender in the manifold. Surprisingly im only using a 260CCA battery at present and its working rather well.
I didn't take any photos, it looks fairly ugly at present in my view. The engine feels really strong, and the good thing about it is it never went over 4000rpm all day, good power down low. Plus im running it in.
I saw a mechanic re engineering. The fuel cell in the boot is not allowed. Or should I say, its illegal to fill the tank from in the boot. Not sure how to get around it at present.
#69
_LH SLR 3300_
Posted 29 September 2008 - 09:00 PM
#70
_LH SLR 3300_
Posted 29 September 2008 - 09:22 PM
#71
_BlownOutlaw_
Posted 29 September 2008 - 09:24 PM
The cars rego ran out about 2 weeks ago.
Edited by BlownOutlaw, 29 September 2008 - 09:25 PM.
#72
_LH SLR 3300_
Posted 29 September 2008 - 09:46 PM
#73
Posted 29 September 2008 - 11:06 PM
#74
Posted 30 September 2008 - 09:31 AM
LH SLR 3300 thanks for the pics, looks good
#75
_BlownOutlaw_
Posted 30 September 2008 - 09:49 AM
ALX76 - The bends came from Geoffs Exhaust in Wagga, they have a mandrel banding machine there. I got the X pipe from there also, which cost me about $130 all up.
76LXhatch - Yes it goes alright too! But I will be happier when I can drive it when its all engineered properly.
Edited by BlownOutlaw, 30 September 2008 - 09:50 AM.
