'74 LH Torana Project
160 replies to this topic
#151 _BlownOutlaw_
_BlownOutlaw_
Posted 23 May 2010 - 04:03 PM
OK been a bit pre-occupied lately.
Need some more assistance. I need to take the windows out of the front and rear doors and the weather strips, rubbers either side of the windows.
Never done it before and so dont wanna stuff anything up.
Can anyone help with some info on what to do?
I'd like to replace the rubber seals and the bottom of each side of the bottom of each window. Guess there in the rare spares rubber kit. Which I have not purchased yet.
Leigh
#152 _BlownOutlaw_
_BlownOutlaw_
Posted 23 May 2010 - 05:05 PM
THere is also a round bit surrounding the door lock knob, half in the door and half out of the door, Im not real sure how I can get that out without breaking it ??
#153 _LH SLR 3300_
_LH SLR 3300_
Posted 23 May 2010 - 05:18 PM
Hi Leigh. Removing the window rubbers (belt moulds) you're talking about can be a real pain in the ass, especialy if they've been in there for 30+ years. I normaly remove the door glass to make the job easier. Back doors are easy, lower the glass, unbolt the reg from the door & slide it off the channel at the base of the window then remove it from the door. The glass should lower further into the door now. Remove the quarter glass divider channel by removing the phillips screw at the top, then the 3/8 nut at the base. Wind in the threaded stud & you should be able to move the channel enough to take the quarter glass out. Now remove the divider channel. Sometimes removing the threaded stud will make this easier. Now the door glass can be removed. Front doors are easy too. Lower the glass about half way, remove the bolted on channel the regulator runs on & you should be able to tilt the glass forward & slide it off the regulator & remove it from the door. To remove the belt moulds, i use a wide blade paint scrapper. The moulds are held in by metal clips & i gently work the scrapper along between the door & the rubber until i find them. Then i gently push down on the scrapper & lever in. Sometimes due to age these metal clips break but i've managed to get the moulds off without damaging them before. If they do break, repo ones from Rare Spares aren't that expensive & are pretty good quality. I've used them on my cars with no problems. Hope this helps. Good luck with it & be sure to post some more progress pics. Cheers Matt
#154 _LH SLR 3300_
_LH SLR 3300_
Posted 23 May 2010 - 05:37 PM
This is called a ferule i think. Here's a pic of one i removed from my Torana.
As you can see, they're held in by two metal prongs that are bent up to locate it on the door frame. To find & bend them down is difficult, so i usually pry them out using a slightly bent thin bladed flat screw driver. As the are metal encapsulated in plastic you have to be very carefull & gentle when doing it this way but as you can see by my pic, it can be done. If they do break, i have a few spares i'm quite happy to post to you, or you can by them new from Rare Spares. Cheers Matt
#155 _BlownOutlaw_
_BlownOutlaw_
Posted 23 May 2010 - 05:51 PM
Matt, your a legend, thanks, I will see what I can do :)
Ive also just pulled out the brake booster, and heater control cables.
#156 _BlownOutlaw_
_BlownOutlaw_
Posted 23 May 2010 - 07:13 PM
Matt, thanks, I got the little ferule thingys off, I reached in and straightened one of the tabs and then they come out fairly easy. One of the tabs broke :(
If you can buy them new I might just get a set of new ones, but thanks fot the offer Matt.
I removed the external mirror also. The little plastic screw bit the pushes into the door broke at the rear inside the door so had to get pliers and hold the plastic thread bit. Can u get new ones of those ?
Thats all I'll do this evening, but at least ive done a little bit more.
Still very undecided on the colour scheme.
#157 _LH SLR 3300_
_LH SLR 3300_
Posted 23 May 2010 - 09:05 PM
Yeah Rare Spares sell those plastic mirror grommet things, i bought a pair for my Torana as the original ones fell apart when i tried to remove them. Geez you done well to reach up & bend those ferule tabs down, i guess you must have alot of paitence. Can't wait to see some progress pics, the lengths you're going to to build this will make a very neat Torana. Keep up the good work Leigh Posted Image
#158 _BlownOutlaw_
_BlownOutlaw_
Posted 05 June 2010 - 11:59 AM
Hi Matt, didn't really find it too hard to get to the ferules to be honest.
I would put some photos up, but all seems the same to me its just all pulled apart. I guess I can take a few.
I usually do things properly all not at all, and at the moment the motivation is down quite a bit so a lot has stopped. The only way to really do this properly is to pull everything off it and paint it and put it back together again. Replace everything that needs to be replaced. Should be like brand new when its done. And I'll be driving it not leaving it in the shed.
Im going to try do a bit today if I can, so I will get some photos. JUst watching the 1979 Bathurst right now haha.
#159 _BlownOutlaw_
_BlownOutlaw_
Posted 13 June 2010 - 09:45 AM
Im building a rotisserie at present so I can flip the car over.
#160 _mick74lh_
_mick74lh_
Posted 13 June 2010 - 04:22 PM
Working hard mate! Good stuff, but doesn't sound like you're gonna come to the drag day hahaha
Here's a shot I grabbed at Motorvate
Jesus christ!
#161 _BlownOutlaw_
_BlownOutlaw_
Posted 13 June 2010 - 04:32 PM
Yeh hi Mick, cant wait to hear how the Doorslammer goes down the 1/4 mile, good i hope. Im considering building another one after I finish this Torana.
I finished the rotisserie, here is a few photos:
Attached File  13062010(001).jpg   40.36K   34 downloads
Attached File  13062010.jpg   47.92K   33 downloads
should make things a bit easier
Edited by BlownOutlaw, 13 June 2010 - 04:37 PM.
