SL/R 5000
#1 _sandman77_
Posted 14 June 2008 - 12:22 PM
#2 _Yella SLuR_
Posted 14 June 2008 - 12:35 PM
#3 _Yella SLuR_
Posted 14 June 2008 - 12:42 PM
Below is the VHT product.
Do a search, just incase I've got the wrong VHT paint, as there has been a thread on this previously. Can't find the can to confirm, but it may have been Chev Rocket Red. Not sure now.
Edited by Yella SLuR, 14 June 2008 - 12:43 PM.
#4 _sandman77_
Posted 14 June 2008 - 12:59 PM
#5 _torana_
Posted 14 June 2008 - 02:08 PM
Posted 14 June 2008 - 07:02 PM
#7 _sandman77_
Posted 14 June 2008 - 07:15 PM
Posted 14 June 2008 - 07:27 PM
#9 _Lxrana_
Posted 14 June 2008 - 07:32 PM
#10 _sandman77_
Posted 14 June 2008 - 07:46 PM
Posted 14 June 2008 - 08:20 PM
#12 _sandman77_
Posted 14 June 2008 - 08:24 PM
#13 _chrome yella_
Posted 15 June 2008 - 09:09 PM
#14 _Yella SLuR_
Posted 15 June 2008 - 09:44 PM
With the cast aluminium, I've tried all sorts of things, including cleaning it all up and clear coating. The best result was obtained, IMO, with VHT Heat Proof Silver.
Edited by Yella SLuR, 15 June 2008 - 09:45 PM.
#15 _Jim140862_
Posted 07 July 2008 - 11:16 AM
#16 _plumcrazy_
Posted 07 July 2008 - 01:03 PM
Rocket red is actually an orange not red colour or pink like these spray packs are . Motospray and VHT (which used to be good ) are poor quality and have poor adhesion and durability . You need to use the what the factory used which is what i sell in spraying enamel and spray it out of a gun using Dulux/PPG the original paint manufacturer . Even their quality has wained quite a bit over the last 10 years to compete which is annoying . As for the gear box centre body i sell that all also and the correct colour is called "Special red "(looks like red oxide). As for your bell housing water jet /vapour blasting is the best and only method to give it the proper factory look . Sandblasting makes it look dried out and hardens like panel steel and seems to upset the properties of the metal for good . Hope this helps restorers . Cheers James 03 9505-6404
Posted 07 July 2008 - 05:07 PM
Posted 07 July 2008 - 09:33 PM
The alloy used to come up mint in a Trichlorethylene bath, prob very enviro illegal now, so the next best thing is "Soda Blasting" doesn'y give it that destroyed dull look of sand blasting
