Radiator caps? LBS?
#1 _rorym_
Posted 15 June 2008 - 08:13 PM
Running a 15lbs cap.
In the Holden book it says 253/308 uses 13lbs with thermo fully open at 202F
Chev 327 13lbs @212F
Chev 350 is 15lbs @217F
That seems pretty hot to me..
Is a 13lb lid the go or what?
Posted 15 June 2008 - 08:32 PM
Suppose the first stupid question is,I have noticed that no matter how hot the car gets it never sends any excess fluid to the over flow bottle.
Are you using a recovery cap? or a standard cap?
#3 _rorym_
Posted 15 June 2008 - 08:35 PM
Edited by rorym, 15 June 2008 - 08:36 PM.
Posted 15 June 2008 - 08:40 PM
I'm using a factory UC recovery system with a recommended cap for it and it works a treat.
The std cap only has a gasket, the recovery cap has a large seal.
Edited by LX2DR, 15 June 2008 - 08:41 PM.
#5 _rorym_
Posted 15 June 2008 - 08:42 PM
#6 _Bomber Watson_
Posted 15 June 2008 - 09:01 PM
Recovery cap has 2
#8 _Yella SLuR_
Posted 15 June 2008 - 09:33 PM
Posted 15 June 2008 - 09:51 PM
Main visible difference is the big seal in the cap itself and its got recovery stamped on the top, too hard
Edited by LX2DR, 15 June 2008 - 09:53 PM.
#10 _rorym_
Posted 16 June 2008 - 05:44 PM
#11 _Bomber Watson_
Posted 16 June 2008 - 06:09 PM
#12 _The Stig_
Posted 16 June 2008 - 06:18 PM
Posted 16 June 2008 - 11:31 PM
Standard cars run low pressure caps, race cars usually run higher pressure caps, 13pounds and up to compensate for the higher heat generation, a trade off from the higher out put of the motor.
The higher the rating of the cap the higher the temp u can run before you loose water.
