Making a 202 Fuel Efficient
Posted 17 June 2008 - 09:02 AM
As some of you know my girlfriend has just got herself another UC and got it registered. It is her daily driver, but its going through HEAPS of petrol!
It is a completely stock Red 202 Auto, With A/C in a UC.
At the moment she is getting about 250k's out of a tank! Which is just terrible!!! We are looking for a few mods that will improve economy. (My V8's gets better economy! LOL)
We have a Electronic Dizzy that is going in on the weekend. What Spark plug gap should we run and what timing to? For economy.
Are there some other mods we can do that will save her Fuel and money?
The diff ratio i am pretty sure is a 2.78 or 3.08 (I'll have to double check)
The Tyres are 185/75/13's (pretty sure they are 75 profile, could be 70's)
It runs the standard Single Barrel Carby (Can we easily tune these to use less petrol?)
Anyway, any ideas are GREATLY appreciated... The car in the next month or so is going to be booked in for a gas conversion. But hopefully these mods will increase economy for both gas and petrol.
Posted 17 June 2008 - 09:13 AM
Plug gap for HEI ignition is 1 mm..depends which books you read...some say 1.3 others 1.5...1 mm is fine and it is not that critical. Timing will need to be set correctly. Do you have a timing light? if so Disconnect the vac advance line and plug it, set the timing at 6 degrees, lock it up and reconnect vac advance line.
Edited by FastEHHolden, 17 June 2008 - 09:14 AM.
Posted 17 June 2008 - 09:14 AM
1mm gap and timing set with the highest possible advance and engine vacuum will give best economy and power.
You could go leaning it out but ur right foot is the best tool to use here.
Just make sure the carb is in the best working order, alot of guys go wrong here, trying to tune a shit carby.
Again, whilst setting the timing, use the vacuum gauge to get the highest possible vacuum.
Posted 17 June 2008 - 09:20 AM
Posted 17 June 2008 - 09:27 AM
Maybe going to a two barrel like a WW could actually help.
You could find, that she is using the right foot alot due to the lack of power.
Ive got triple SUs on my 202 in my LJ and i get ALOT more then 250kays to the 35litre tank.
Posted 17 June 2008 - 09:34 AM
Posted 17 June 2008 - 01:12 PM
#8 _evil UC hatch_
Posted 17 June 2008 - 02:18 PM
I agree, dual fuel sux, I hate it. its one or the other in my booksIf she is definately going gas, save your $30 and park the car for the week or 2...I recommend straight gas and get a dedicated gas mixer..one that gets rid of the carby altogether.
so as fast eh said park it until the lpg conversion is done, or another option is to get the thing working properly on petrol, I was able to get about 450kays to a tank with a 350 holley and a heavy foot after I disconnected my lpg and rebuilt the carb, I was getting about 150kays per tank on petrol beforehand.
if you spend money on the single barrel now it would be a waste of time in my opinion as its likely that they will remove it for something else when they do the lpg conversion
Posted 17 June 2008 - 02:40 PM
I agree on the straight gas set-ups. I ran an Impco on my HQ and it worked pretty well. (Heaps better than when it was "Dual Fuel" LOL)
#10 _nunganunga_
Posted 17 June 2008 - 05:55 PM
Recurve the dizzy before you go to the trouble of changing it.
Dual fuel is the best option on a stock red six in my opinion. You can tune spark and modify compression to suit gas and keep petrol as a back up. The only limitation with dual fuel is the type of mixer you sometimes have to use, but a spud in a single stromie works great!
I would pop the top off the carby and check the float level in the meantime, also the power valve has a habit of coming loose.
#11 _wraith75_
Posted 17 June 2008 - 05:56 PM
Posted 17 June 2008 - 06:39 PM
Posted 17 June 2008 - 09:25 PM
Posted 17 June 2008 - 09:42 PM
Posted 17 June 2008 - 10:00 PM
#16 _bones_
Maybe you should go the other way. Bore and stroke it to about 600 cubes. 250 kays out of a tank would be easier to stomach then.Sleeve and de-stroke down to 138.
Posted 17 June 2008 - 10:04 PM
Posted 17 June 2008 - 10:07 PM
Hey! Yeah!Cut 2 cylinders off, then you can call it something flash like a ....... Hmmm ........ Maybe ........ a Starfire!
Your brother could help you, he likes Starfires.
Posted 17 June 2008 - 10:55 PM
Posted 18 June 2008 - 08:20 AM
#21
Posted 18 June 2008 - 08:49 AM
I don't want to change the subject but I firmly beleive that crap petrol is being sold thru the discount joints.Anyone else getting bad economy? Maybe the f*ckers are watering down the petrol!
I fill my VT up with my locals version of ethanol blend and it says I will get 430 km..which I am very lucky if i get that...but a tank of premium (who can afford that?) says I will do 690 km.
Obviously there are a ton of variables here...but I can fuel up on premium and drive to the Gold Coast (from Gosford) but there is not a hope on cheap stuff and this is in a car that is smart enough to work stuff out for itself....what hope has a Torry got?
I reckon crap fuel combined with a buggered carby could easily get that kind of economy. Back when i first got my EH it managed 275 km on its 40 lt tank and it was bog stock...a bigger cam, YT head and Holley 350 later and it got 400km for 40 lt.
I now get about 6 km a litre on gas.
#22
Posted 18 June 2008 - 09:01 AM
Funny you say about the crap petrol. I had been filling up on the 7-11 Ethanol blend and getting very good economy (400-450k's a tank @ city driving @ 14.9L/100km's)I don't want to change the subject but I firmly beleive that crap petrol is being sold thru the discount joints.Anyone else getting bad economy? Maybe the f*ckers are watering down the petrol!
Then i Filled up on Regular Mobil Unleaded (Actually cost more Per litre than the normal Eth blend) and got 18.75L/100! When i Filled up last night it said the tank will only get 360k's out of the tank! Almost 100ks less than what is normally says!
With figures like that, i think i will switch back to Premium Fuel, as its actually cheaper...
#23
Posted 18 June 2008 - 11:23 AM
My hatch with the stock 253 and 2barrel Stromberg is horrible on fuel - I mean really bad! I have mates with mild 308's that make twice the power (literally) and return better economy when cruising.
I also remember my old 202 - once again, when cruising, I used to get better economy when I had my triple SU's tuned up, than running the single 350 Holley. The motor was just so much sharper and more responsive with the triples, that I barely had to touch the throttle.
I don't think there's much you can do if you're about to change things soon anyway - but if you were thinking long term with her same setup - I'd be paying some attention to her carb - even getting it on the dyno too.
#24
Posted 18 June 2008 - 05:58 PM
#25 _73LJWhiteSL_
Posted 18 June 2008 - 07:24 PM
When i stuck the manual in the LJ i had the carby rebuilt and i have been getting 12 - 15litres/100, untill i stuck the cam in last Christmas.
Steve
