k frame to body bushes
Posted 06 July 2008 - 08:16 PM
1) do you push these back in from the inside of the frame or the outside
2) not really a question but, i'm fitting super pro bushes and the bushes for the k frame to chassi bushes seem to have large holes in the centres. i've checked the website to check whether i have the correct bushes and i have. i compared them to the rubber bushes that i removed and the out side diameter is the same but the inside holes seem to be the same but the rubber ones have a locating washer as part of the bush whereas the super pro don't, to me it seems that there is a lot of room for the front suspention to move around in.
any thoughts or help is appreciated
mark
Posted 06 July 2008 - 09:50 PM
Posted 18 October 2008 - 06:29 PM
hi all,have a couple of questions. recently stripped out front end of lx torana to paint engine bay thought while this was out we will replace springs, shocks, all bushes and whatever else needs replacing, ball joints, tie rods. well its time to put back together, was doing really well untill i got to the outrigger bushes
Bump. Me too!
Posted 18 October 2008 - 08:13 PM
Posted 18 October 2008 - 08:24 PM
Edited by ls2lxhatch, 18 October 2008 - 08:27 PM.
Posted 18 October 2008 - 09:08 PM
Andy, I'm only using rubber & the steel tube appears to be part of the bush.
Posted 19 October 2008 - 03:07 AM
Posted 21 October 2008 - 01:00 PM
The steel tube protects the bush from wear due to the threads and constant friction.
Posted 21 October 2008 - 03:09 PM
#10 _The Baron_
Posted 22 October 2008 - 04:54 PM
