Toughest Manual Gearbox?
66 replies to this topic
#1 _rorym_
Posted 15 July 2008 - 05:24 PM
Heres a question...which one is toughest?..M21/22 Muncie? Toploader?..Super T10?
Are T10s different to Super T10?..guessing yes..found a T10 out of 64 Mustang..
All opinions appreciated.
Edited by rorym, 15 July 2008 - 05:29 PM.
#2 _TORANR AMORE_
_TORANR AMORE_
Posted 15 July 2008 - 05:55 PM
Toploader.
#3 _rorym_
Posted 15 July 2008 - 06:21 PM
Thats one.
#4 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 15 July 2008 - 06:25 PM
toploader , then again i,d rather a tremec TKO600
#5 _MRNOS_
_MRNOS_
Posted 15 July 2008 - 07:01 PM
Toploader then maybe the steel case-not alloy case- super t10
#6 _rorym_
Posted 15 July 2008 - 08:33 PM
Thats 3.
#7 _ronaldoredsox_
_ronaldoredsox_
Posted 15 July 2008 - 08:44 PM
I'm no expert, but, they say the Top Loader is 'bulletproof'.
#8 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 15 July 2008 - 08:50 PM
From the options above, have to be a Toploader.
#9 Dr Terry
Dr Terry
  • 3,324 posts
Posted 15 July 2008 - 11:02 PM
Hi Guys.
Here's how it goes, shoot me down, if you want to.
The best GM 4-speed manual up to the mid 70s, was the Muncie fine spline.
The best Ford 4-speed 'box was the Toploader.
There was also the Borg Warner T10, which was used in many US 'Muscle Cars' of the 60s & 70s.
When GM & Borg Warner merged & made the 'Super T10', this was the best.
In my opinion the strongest US 4-speed manual of the era, was the BW Super T10. All the racecars, including Group C Falcons in the late 70s /early 80s used this box, even Dick Johnson's XD/XE.
Dr Terry
#10 ozyozyozy
ozyozyozy
  • 950 posts
Posted 15 July 2008 - 11:26 PM
toploaders are strong, but dont shift with big hp, a number of friends have had them unless you have dog box conversion and a bit of blueprinting there just trouble. magnesium cased super t10, there sick, shifts awesome, strong can handle big hp, they have big input, output and countershaft shafts, and pretty light.
even the early t10`s were a good gearbox, parts are available.
#11 _JBM_
_JBM_
Posted 16 July 2008 - 06:44 AM
Im sure Litre8 would have the answer to this after the number of gearboxes hes tried and fried.
James
#12 _rorym_
Posted 16 July 2008 - 07:12 AM
Howard runs a Jerico off memory...but if you are looking for value for $ it does appear the toploader is the pick...then a Super T10 if you can get one under $3000 or so.
#13 _chrome yella_
_chrome yella_
Posted 16 July 2008 - 03:57 PM
rory i have a 64 mustang t10 in my hj monaro, its a cast iron housing and has been fitted with many super t10 internals, but still has the small layshaft and splines. i had trouble with jumping out of 3+4 but it was because of the wrong selector key pad. it is a great gearbox when warm, the hurst indy is superfast and doesnt miss shift. also i had a toploader close ratio + hurst indy in my l34 and it was way slower and not as precise as the t10. as for strength i never broke either. i have put a full rebuilt m21 back in the l34. full circle...
#14 yel327
  • 13,598 posts
Posted 16 July 2008 - 05:04 PM
Super T10 and then the Muncie. Bob Jane used a big block Muncie in his ZL-1 Camaro. He did have to cheat a bit to strengthen it up but it was a 7litre 600ft-lb or so torque engine. Standard top loaders will bust behind a 400hp small block, whereas a Standard Muncie will last. Toploaders can be modified to make them last though.
#15 _rorym_
Posted 16 July 2008 - 05:22 PM
Chrome..have a chance for a T10 but it is 1965 model...whats the difference to a Super T10?..Can you upgrade it?...how do you tell the difference?
#16 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 16 July 2008 - 09:32 PM
I vote Super T10. These boxes were designed for cars, toploaders were designed for trucks and shift accordingly.
JMHO
#17 _82911_
_82911_
Posted 16 July 2008 - 10:24 PM
Richmond Road race 5 speed.
Of the production boxes.... super t10
#18 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 17 July 2008 - 12:26 AM
Put me down for a Super T10 any day, they,re an awsome gearbox (Rock solid)....
#19 _TORANASS_
_TORANASS_
Posted 17 July 2008 - 01:39 PM
What about the toyota 4spd box's, iv heard super stories of these 4cyl boxs holding on behind some big big HP packages.
Anyone have any experiance on these, there cheap and easy to get.
John
#20 _JBM_
_JBM_
Posted 17 July 2008 - 01:43 PM
Supra boxes are the strongest and there is 2 types of Celica box, a steel case and an aluminium case one.
James
#21 _rorym_
Posted 17 July 2008 - 02:22 PM
John
The 3.89 first gear is a killer....
#22 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 17 July 2008 - 06:38 PM
ive heard the supra turbo boxes you cant get parts for but ive seen a few busted up pretty bad also dont like toploaders because of how they shift never driven anything with a muncie but from what i hear the super t10 is the ducks guts
#23 _rorym_
Posted 17 July 2008 - 07:04 PM
What I want to know is can you make a T10 into a Super T10?
#24 yel327
  • 13,598 posts
Posted 17 July 2008 - 07:42 PM
Here's a funny story about Muncies and Toploaders. My mate had a Muncie in his HK Monaro for 15 years behind a 400hp 350. He gave it a flogging. Blew up heaps of Saginaws and 10-bolts before putting the Muncie and 9" in. Blew the guts out of 3 or 4 9" diffs before putting a mini-spool in, and it then lasted the 15 years. In the end he got scared of breaking the Muncie and put a toploader conversion in. Blew up 3 of these, all rebuilt as new. One was a GTHO box. It's still got a top loader in it as it doesn't get driven much anymore. And the same Muncie that copped 15 years of abuse is now in a WB 1-tonner behind an injected 308, and has been for about 5 years now. Gets used for towing all the time and is still going strong.
#25 _chrome yella_
_chrome yella_
Posted 17 July 2008 - 10:14 PM
rory i dont think you could fully super t10 a early t10 as you you would have to do a lot of machining to make it fit. i pretty sure the layshaft is 1/4 inch bigger in st10 so to bore the cluster and housing to suit wouldnt be viable, what mine has is s t10 1st, 2nd, 3rd gears and selecting hubs ,torrington roller bearings between each gear fitted but the rest is standard t10. also the bevel on the gears are a bit staighter on the s t10 witch gives it the "muncie whine" saginaws are a bugger because when you change gears to fast and big revs they keep breaking circlips between 2nd and 3rd
