What Brakes for LC/LJ V8?
Posted 24 July 2008 - 01:23 PM
Could you have the standard brakes of a LC while braking for a V8?
I just wanna know the options of what kind of brakes i can put on...
I heard that HQ brakes can be placed on... what about commodore brakes etc...
even with adaptors etc...????
Posted 24 July 2008 - 02:01 PM
HQ work but depending on what V8 you put in you might have trouble getting it approved.
Pretty much if you pull a 308 out of a HQ put on HQ. Or Pull a 304 out of a VN put on Commodore etc.
Posted 24 July 2008 - 03:04 PM
These are better brakes than SS's and SLR5000's had. If you are going for a better upgrade. Go the HQ brake upgrade, this will require a Stud pattern change though (No hassle, more and better wheels available!)
Up to how much you want to spend, and how serious the motor will be
Posted 24 July 2008 - 06:10 PM
_AGGRO_
Posted 24 July 2008 - 06:38 PM
_Machine_
Posted 25 July 2008 - 02:56 PM
In Wa the standard Lj brakes are good enough for passing rego with a 308.
M.
Posted 25 July 2008 - 03:13 PM
13" you can probably only run Torana Brakes
14" HQ brakes or torana brakes
15" + go nuts! HAHA what ever brakes you want!
Edited by MRLXSS, 25 July 2008 - 03:14 PM.
Posted 25 July 2008 - 03:17 PM
Posted 26 July 2008 - 07:20 AM
_LJ355_
Posted 26 July 2008 - 10:21 AM
when you can get these on there for the same amount
Posted 26 July 2008 - 10:32 AM
Tim
_LJ355_
Posted 26 July 2008 - 10:34 AM
_Machine_
Posted 26 July 2008 - 11:27 AM
Are they a straight fit and what rim size is it from eg will 14" be too small.
Ta, M.
_LJ355_
Posted 26 July 2008 - 11:34 AM
i paid $550 a pair 3 years ago bolt straight on to HQ stubs
Posted 26 July 2008 - 04:17 PM
Edited by Bart, 26 July 2008 - 04:18 PM.
_Machine_
Posted 27 July 2008 - 12:31 AM
_LJ355_
Posted 27 July 2008 - 10:12 AM
Machine HQ stubs bolt straight on to LC/LJ
Posted 27 July 2008 - 05:57 PM
Bart il have a look when i see the car next weekend
Thanks LJ355, the reason i ask, i know these Outlaw brakes are in the US, and if i want to buy some other brand brakes from the US i can use this as reference by using the part number. So if i want Baer or Willwood i can refer to this Out Law bolt patern by its part number
_Machine_
Posted 28 July 2008 - 02:40 PM
Ta, M.
Posted 28 July 2008 - 03:25 PM
#21
_JBird_
Posted 28 July 2008 - 05:08 PM
HQ discs
Outlaw 4 pots
HQ wheels 14" or greater
Does that sound about right?
#22
_LJ355_
Posted 28 July 2008 - 05:16 PM
They may not be designed for street use but i bet they work better
than any HQ or commodore caliper
#23
Posted 29 July 2008 - 10:54 PM
i havent actually tried HQ stubs myself because of being told about these problems, i got the hoppers stoppers 290mm kit myself and the engineer has told me it doesnt really matter it just has to pass a braking test (thats in vic with an rb30 being fitted)
#24
Posted 30 July 2008 - 11:52 AM
#25
_lj30et_
Posted 30 July 2008 - 02:08 PM
