XU1 Diff
4 replies to this topic
#1 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 November 2005 - 08:07 AM
Hi Folks
I have a noisy CW+P in a 3.36 LSD. I have immediate access to a 3.08 LSD. What are the pros and cons to fitting the taller diff? I must admit I can't get used to 3000 plus RPM at highway speeds. IIRC my VT Commodore is less 2000 at the same road speed.
Any thoughts welcome thanks
Baz
#2 _draglc_
_draglc_
Posted 19 November 2005 - 11:58 AM
The first thing is the 2 bottom bolts in the diff housing itself. the 3.36 has long bolts, and the 3.08 has short ones. if the 3.08 doesnt have the bolts with it then ull need to find them. Other than that its a simple swap over.
The taller diff will be slower off the line, and might use a little more fuel, although u probably wont notice its not that much of a difference.
Andrew
#3 _redlh_
_redlh_
Posted 19 November 2005 - 02:13 PM
Install the taller diff. Unless you're into dragging at every set of street lights or you're out on the strip, you don't need a diff that has your engine at 3000 rpm when cruising on the highway. Hell, get a 2.78 if you can! It will improve your economy not decrease it, and with petrol prices these days, that's a good thing. ;)
B)
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 November 2005 - 10:33 PM
Hi All
This is all food for thought. Can anyone quote the Kms per 1000 rpm in top gear for the various diff ratios on XU1s?
Bazza
#5 _draglc_
_draglc_
Posted 25 November 2005 - 07:54 PM
barry just posted this link in memorabilia section...
https://cache.gmh-to...a-specs-web.jpg
that what ur after bazza?
