lc guards
Posted 27 July 2008 - 07:56 PM
i have drilled out all the spot welds and unpicked it near the door jams,
do i just separate the joins around the headlight area?
Posted 27 July 2008 - 08:04 PM
Tim
Posted 27 July 2008 - 08:21 PM
on
Edited by brocks72xu1, 27 July 2008 - 08:22 PM.
Posted 27 July 2008 - 08:25 PM
Posted 27 July 2008 - 08:27 PM
Posted 27 July 2008 - 08:29 PM
Posted 27 July 2008 - 08:33 PM
Posted 27 July 2008 - 09:02 PM
Posted 27 July 2008 - 09:08 PM
hope this helps, it that what you want to do
Posted 27 July 2008 - 09:11 PM
#11 _gtr161s_
Posted 27 July 2008 - 09:12 PM
I unpicked my donor as one piece without cutting, A thin slitting blade or chisel helps to breaks the difficult spot welds but still drill them all and it will come as as my pics
The fiddliest part was getting to the spot welds where the rail meet the rear of rad support underneath
https://cache.gmh-to...drdriveside.jpg
https://cache.gmh-to...frontendoff.jpg
https://cache.gmh-to...4drfrontend.jpg
Posted 27 July 2008 - 09:18 PM
Posted 27 July 2008 - 09:22 PM
Posted 27 July 2008 - 09:26 PM
Posted 27 July 2008 - 09:36 PM
#16 _tuffgong_
Posted 28 July 2008 - 05:29 AM
step one good car that you are re-storing,,, clean all spot welds, cut the quater about 1 inch from these welds then use the dyegrinder and vicegrips to rip away the rest of the old quater,,, takes time,, but clean and no holes to fill.
step two replacement quaters,,,, do the same thing here but from the otherside,, this leaves no holes and then you just drill the new holes in between the original spot welds and dyegrind them gentle flat and smooth, no one will ever pick that thay have bein off or on.
the time for each quater about 2 to 3 hours, thats if you have the tools on hand. it really is easy, when you dont need to use the part you are removing.
cheers john.
#17 _2runa_
Posted 28 July 2008 - 09:16 PM
