1UZ into LH/LX
231 replies to this topic
#126 _Sprog_
_Sprog_
Posted 14 March 2010 - 04:00 PM
One Rear sump 1uz
#127 _niterida_
_niterida_
Posted 14 March 2010 - 08:52 PM
Nice work !!
#128 _Viper_
_Viper_
Posted 14 March 2010 - 09:43 PM
x2 looks good
#129 _Sprog_
_Sprog_
Posted 03 April 2010 - 03:38 PM
Busy weekend.
Got the sc400 Air con/heater unit to fit in the torry.
Should actually sit an inch or two higher, havn't made brackets yet
#130 Heath
  • 18,374 posts
Posted 03 April 2010 - 03:43 PM
woah that's a big bastard! I thought new cars were supposed to have 'compact' things
Sump looks great
#131 _Sprog_
_Sprog_
Posted 04 April 2010 - 07:38 PM
Measured up the commo condensor today, should fit without a prob.
Going to see if the ac/heater assy will be a better fit than the toyota gear.
It's great having half a scrap yard out the back!
#132 _1uzbt1_
_1uzbt1_
Posted 05 April 2010 - 01:05 PM
its looking good,you making some exhaust headers for it or using the soarer manifolds?
what model commodore condensor are you going to use??
#133 _Sprog_
_Sprog_
Posted 05 April 2010 - 06:28 PM
Will be making steam pipe manifolds, i have made up some stainless extractors but decided to go turbo.
i have a vn commo siting out the back, i'll use the stuff out of that.
#134 _1uzbt1_
_1uzbt1_
Posted 05 April 2010 - 08:05 PM
Just a suggestion, but i would probably stick to using either the entire system out of one or the other and not to "mix n match".Both system are designed entirely different.(the vn runs a flooded evap/accumulator and the soarer a standard tx and uses a evaporator pressure regulator).The efficiency of the evap/condensors from model to model may result in a system that may not work 100%.
Then again i may be completely wrong and it may be fine but i would be a pain in the arse to have to modify somthing when its all back together.
#135 _Sprog_
_Sprog_
Posted 06 April 2010 - 04:13 PM
Thanks for the heads up.
I only have a basic understanding of ac systems. Didn't know there was different types.
would the commo condensor work with the toyota system if i used all the toyota parts. exept the condensor.
#136 _dirtbag_
_dirtbag_
Posted 06 April 2010 - 04:52 PM
Hey Sprog that's looking sweet man. Great work.
I hope it'll be running a proper gearbox. Those motors go nuts with manual gearboxes.
Again, great work :spoton:
#137 _1uzbt1_
_1uzbt1_
Posted 07 April 2010 - 05:43 PM
That was the main part i was worried about,im not sure whether the vp commy condensor would be good enough as they arent a very efficent condensor(neither is the commy evap for that matter).The lexus/commy use the same style serpintine condensor but i think the lexus is larger.You will get a compounding heat problem if the heat is not fully removed as it goes through the condensor,meaning higher vent temps etc.
FYI a vr/vs is a far more efficent condensor.
#138 _Sprog_
_Sprog_
Posted 07 April 2010 - 06:52 PM
just cheked the commodore, it's a VS.
The lexus condensor is bigger. it wont fit in the torry.
Edited by Sprog, 07 April 2010 - 06:54 PM.
#139 _Sprog_
_Sprog_
Posted 07 April 2010 - 08:51 PM
i might try it with the commo condensor and the rest of the toyota gear, the condensor will get a load more airflow through it than in the sc.
#140 _1uzbt1_
_1uzbt1_
Posted 07 April 2010 - 08:58 PM
vs,its should be fine then,they use a far more efficent condensor(parrallel flow) .Just watch the nut that goes from the condensor pipe to the drier cannister the nut normally corrodes and splits,new condensor.
Anyway, been watching this conversion with interest,keep up the good work.
#141 axistr
axistr
  • 1,204 posts
Posted 07 April 2010 - 09:53 PM
G'day Sprog, just come across your build thread great work mate well done, I was thinking about doing a nother Torrie with a Toyota quad, not selling the hatch thow. Have a look at my cardomain site I put Toyota/Denso air with photo's and basic rundown in my hatch have a look it may help you. I am only over at McGraths Hill not far from you, must catch up may be able to help each other out.
P.s also did my PPL at scoies now flying out of Richmond RAAF base, bianial this friday not looking foward to two hours of terra.
Best of luck Lenny
#142 _Sprog_
_Sprog_
Posted 08 April 2010 - 06:45 PM
Thanks for your input, helped a lot.
pic of bomodore conensor in the torry, it was an interference fit, so i might not need any other mountings.
#143 axistr
axistr
  • 1,204 posts
Posted 08 April 2010 - 08:46 PM
Sprog my condensor is 1997 toyota hilux and fits sweet, very easy to attach with the hilux mounts. the reciver dryer fits to the left top straight on the discharge side.
Attached File  torana 352.JPG   107.85K   28 downloads
#144 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 08 April 2010 - 09:21 PM
interference fit lol i like it
#145 _Sprog_
_Sprog_
Posted 22 April 2010 - 04:24 PM
Painting Dash. Matte Black
#146 _Sprog_
_Sprog_
Posted 17 May 2010 - 05:33 PM
ok, engine is back in.
started putting the torry electrics back in and working out how to connect it to the 1uz.
Have rebuilt the steering column, and added commo indicator / wiper stalk.
Just a couple of questions for you all,
Does any one know of a brake booster that will work in a torana with an overall diameter of less than 9 inches? would the gemini 7" work?
Where can i get a set of Gbox x-member mounting rubbers?
Thanks for all you help and comments.
#147 _dirtbag_
_dirtbag_
Posted 17 May 2010 - 06:33 PM
Aussie auto does those little gold anodised double diaphram boosters pretty cheap, and are easy to use with different master cylinders. We use them a lot on hot rods cos they're a lot smaller than most other boosters. Might be worth a look?
As for gearbox crossmember rubbers - do you mean the gearbox mount itself, or where the crossmember mounts to the chassis? If it's the latter there are no rubbers, it just bolts to the chassis metal to metal. If that's not what you meant, it proves I am an idiot : )
#148 76lxhatch
  • 7,198 posts
Posted 17 May 2010 - 08:30 PM
Actually dirtbag there are insulating rubber spacers in auto models from factory, I'm sure there was a thread on here somewhere with some speculation as to why which was never really answered. I think one option to replace them was to cut down some sway bar bushes?
#149 _dirtbag_
_dirtbag_
Posted 18 May 2010 - 05:47 PM
Yeah, I don't know anything about "auto" toranas. I only ever play with REAL ones : ) hehehe :badabing:
#150 _Sprog_
_Sprog_
Posted 18 May 2010 - 06:46 PM
Yeah i meant where it bolts to the chassis. its a CRS moded x member, i think it was originaly an auto one cause it has large mounting holes.
might just make up some aluminium bushes so it locates on the bolts properly.
Thanks guys
