1UZ into LH/LX
#176
_Sprog_
Posted 05 February 2011 - 05:34 PM
#177
_Sprog_
Posted 11 February 2011 - 04:26 PM
got the speedo and fuel gauge done (fuel gauge will work backwards. left = full)
Should get the tacho done tomorrow, then i'll post pics.
Does anyone have experience modding the electronics in a VDO tach?
The IC is an ITT 3003-393, but i cant find any info on it.
#178
Posted 11 February 2011 - 04:45 PM
Probably different to what you are trying to do.
Matt
#179
_Sprog_
Posted 11 February 2011 - 08:04 PM
im sure it would be quite easy to do, if i had some info on the chip.
probably just change a resistor and bridging wire or two.
ive seen instructions on how to make it work with an ls1.
VDO would just have a basic circuit that can be configered to whatever they needed.
ive had it hooked up, and the needle moves with the engine revs ok. but at 2/3 the rate.
the vs only has a 120 degree dial, i'd like 270
#180
_Sprog_
Posted 14 February 2011 - 09:23 PM
ordered a set of gauges from speedhut in the US.
#181
Posted 14 February 2011 - 11:16 PM
#182
_Sprog_
Posted 18 February 2011 - 03:48 PM
Anyone had experience with fibermaster flares/spoilers?
Where can i get a drivers side exhaust hanger?
I've started installing the cats and making up the exhaust system.
hoping to borrow the TIG frm work tomorrow to weld it all up.
pic's on sunday.
#183
_Sprog_
Posted 18 February 2011 - 04:20 PM
#184
Posted 19 February 2011 - 06:45 PM
Lenny.
#185
_Sprog_
Posted 20 February 2011 - 04:01 PM
My camera broke so there a bit crap
#186
_keg006_
Posted 21 February 2011 - 07:50 PM
Looks neat. What cats are they?
#187
_1uzbt1_
Posted 21 February 2011 - 10:21 PM
#188
_TorYoda_
Posted 21 February 2011 - 10:55 PM
Sorry I did not get back to you on the pipes... I wasn't following this thread. I made mine at work and they are tuned length 4 into 1 stepped from 1 5/8" to 1 3/4" with merge collectors and a 3" X pipe. After the X pipe I ran a twin 2 1/2" system with 5" Supertrapp mufflers. It's well under legal limits and sounds great. Your 1/1/2 pipes will definitely not be too large. Mine pulls like a 15yo schoolboy with a penthouse right from idle. Cams in these things are tiny and it's all over at 5500rpm. 227 degrees adv and 182 degrees at .050" and .315" lift. I'm about to order a set from Kelford in NZ that will let another 90 hp out of my engine with an extra 1200rpm at the top. The set I'm buying drop in onto the standard valve springs so just need to be re shimmed.
Edited by TorYoda, 21 February 2011 - 10:56 PM.
#189
_Sprog_
Posted 22 February 2011 - 01:32 PM
Toryoda:
Thanks for the info. do you have a pic or sketch of how you ran the pipes?
i'm still looking for ideas to get the drivers side to be equal length. the steering shaft makes it a tight space.
how much are the cams costing you?
#190
_Sprog_
Posted 24 February 2011 - 04:41 PM
just have to make up a few mounting bits.
pics to follow.
#191
_Sprog_
Posted 06 March 2011 - 04:16 PM
Gauges installed, should have got 4" speedo & tach.
Built a new radiator shroud.
Started fitting flares and spoilers.
It's a fibremaster kit.
Not bad quality, needs some minor tweeks. $600 all up.
#192
_Sprog_
Posted 12 March 2011 - 03:02 PM
Got a pannel guy de-rusting the drivers side doors.
Thinking i might just drop it off to him and say just get all the paint work done.
#193
Posted 12 March 2011 - 03:43 PM
#194
_Sprog_
Posted 12 March 2011 - 05:32 PM
There you go
their stuff works good, quick delivery.
I'll put up pics of how i mounted them soon
Edited by Sprog, 12 March 2011 - 05:34 PM.
#195
Posted 14 March 2011 - 09:47 PM
love the look of that right hand side guage
#196
_Sprog_
Posted 16 March 2011 - 04:19 PM
Should look more like the one on the right.
#197
_Sprog_
Posted 17 March 2011 - 03:18 PM
got it back in the shed and found a big petrol leak.
have to fix it tomorrow, when the fumes have cleared.
#198
_Sprog_
Posted 15 April 2011 - 04:20 PM
cutting out the guards and finishing up the flares.
hoping to get most of the paint done over easter.
#199
_Liam_
Posted 15 April 2011 - 06:30 PM
#200
_TorYoda_
Posted 17 April 2011 - 08:01 PM
Cats are 2.5in magnaflows. euro 4 spec.
Toryoda:
Kelford Cams in NZ have a good range of choices advertised on their site for $1341/set. They were affected by the earthquake there and I'm having difficulty getting a reply from them. I'm ready to buy a set and all I need is a reply with an invoice.
No pictures of the headers sorry, just not enough space to get any to show worthwhile detail. You will need to run the rear pipe into the wheel arch, then down and below the outside of the crossmember and back underneath on the LH/X...... This is how I do them at work. I do the same both sides simply so they look similar. Be sure to turn your steering to full lock so you fabricate to miss the tyre! On my LJ I ran both rear pipes outside and below the crossmember just to make it easier on both sides. Be grateful you do not also need to negotiate your way around the starter as is required on a chev!!! Equal length is not as critical as many believe. The difference of a few inches is only a matter of a few HP but in Pro Racing it can make all the difference and it is these guys who want/need all they can get.
Here is a link to Kelford..... http://www.camshafts..._id=68&vmcchk=1 If you have any luck contacting them please let me know. The 207A is the grind I have chosen for mine. These will produce a significant HP increase with minimal cost and effort.
