Fitting a R31 Skyline B/W diff to LH/X
310 replies to this topic
#276 ls2lxhatch
  • 5,335 posts
Posted 05 June 2016 - 12:15 PM
The main weak point of the BW78 is the welding of the upper control arm brackets. If they are done properly then 400-450 rwhp should not be a problem on a street car. You would need slicks and a drag strip to push the BW78 to its limit.
FWIW drive trains are rated by torque not horsepower. In theory you could break any diff with 100 hp if you used a low enough gear ratio to increase the torque past the limit of the diff.
The Truetrac is available for the BW78 plus a few locker style centres.
In my opinion the best centre for the BW is a KAAZ. The KAAZ LSD is a cross between a clutch pack LSD and a locker. In a straight line the torque is used to increase the clamping pressure on the LSD clutches which makes the KAAZ a locking LSD.
The Detroit Truetrac never locks. The Detroit Truetrac uses worm gears to transfer %75 of the torque to the wheel with the most grip. In a straight line you get %75 to one wheel and %25 to the other. If you jack one wheel off the ground the other wheel will not turn.
#277 _Darklord_
_Darklord_
Posted 05 June 2016 - 01:14 PM
Great feed back, thanks mate. Car will be mainly a weekend cruiser with some regular runs to the drags so will see some abuse - as to how much, well depends on how much I get into it, probably end up being more than anticipated :)
Is the skyline with KAAZ much cheaper than a 9 inch with truetrac, thinking around 4-5k for the 9 but need to do some more research
#278 _mantis_
_mantis_
Posted 05 June 2016 - 08:55 PM
should be cheaper lighter and take less horsepower lost driving diff , also you can buy Blank skyline discs so
you can choose your own stud pattern
#279 76lxhatch
  • 7,222 posts
Posted 06 June 2016 - 11:06 AM
The Tru-trac is great around corners (with some traction), you can get the hammer down early and it will get great drive out where locking diffs just make the back end step out
#280 ls2lxhatch
  • 5,335 posts
Posted 06 June 2016 - 05:32 PM
The beauty of the KAAZ design is that around corners it is just a normal clutch pack LSD with a light clutch preload. However once both wheels are turning at the same speed the clutch load is increased to the point where the diff is effectively locked.
Edited by ls2lxhatch, 06 June 2016 - 05:32 PM.
#281 Heath
  • 18,403 posts
Posted 06 June 2016 - 10:37 PM
Can someone enlighten me regarding how necessary moving the shock mount is? Is it to fit big tyres or just to clear certain brake assemblies?
What brakes assemblies are a drama? I don't have any brakes, wheels or tyres so I can't see where anything belongs right now haha. I'm gonna go 1" shorter in diff length only, but with a full floater end and unknown brakes... no idea what clearance issues I'm going to find.
#282 dattoman
Posted 07 June 2016 - 01:49 AM
Shortening the diff will cause issues with the brakes
Calipers foul on the shock
You will need to locate the caliper to the front or move the shock
#283 76lxhatch
  • 7,222 posts
Posted 07 June 2016 - 07:17 AM
The R31 calipers don't foul on the shock (standard diff width) but you have to remove the caliper to get the shock on and off which is a pain in the neck. It also looks to me that the shock is more upright and fits the upper mount straighter after moving it in a little.
The big advantage though is that moving the lower mount up means you run HQ length shocks, more options (e.g. easy to find Bilstein etc).
#284 Heath
  • 18,403 posts
Posted 07 June 2016 - 08:14 AM
I consider that to be an advantage, but I consider the fact that I've gone out and bought McDonald Bros mounts that have an integral shock mount a disadvantage.
Hmmm...
#285 torana_nick
torana_nick
  • 759 posts
  • Name:Nick
  • Car:LH Torana Project
Posted 07 June 2016 - 08:58 AM
Mcdonald Bros cut my shock mount and relocated it using there bracketry.
#286 ls2lxhatch
  • 5,335 posts
Posted 07 June 2016 - 02:24 PM
There are a few pictures earlier on in this thread starting with this post.
Rorym
Youngy11 The upper control arm mounts look to be a good design as they avoid welding to the cast centre.
[url=http://www.markswork....au/Pages/daves project lead page.htm]Marks Workshop[/url A9XII
2wild4u
#287 _LH mike_
_LH mike_
Posted 07 June 2016 - 06:38 PM
My diff is at the shop getting the mounts changed at the moment. Are the skyine sway bar mounts of any use for mounting one in a lh?
#288 _mantis_
_mantis_
Posted 08 June 2016 - 04:45 PM
i have a skyline diff in my toranas and left sway bar mouint on but have never used them
if you are interested in some blank skyline discs i have them $198 +postage
PM me if interested Mark
#289 Heath
  • 18,403 posts
Posted 08 June 2016 - 05:04 PM
If you're willing to make a different style of swaybar mount on the chassis, or get a different shape of swaybar made up (spring shops can do this, you just need to give them a template) then there's no reason the tidy R31 swaybar mounts couldn't be used, I feel.
#290 76lxhatch
  • 7,222 posts
Posted 08 June 2016 - 06:34 PM
You can see in the photo that ls2lxhatch posted above of mine that I used the sway bar mounts on the diff housing, and the end links go through the upper arm mounts just in front of the arm pivot
Its just a Commodore bar with the ends straightened out, can get various sizes up to 18mm from factory cars for next to nothing.
#291 ls2lxhatch
  • 5,335 posts
Posted 08 June 2016 - 06:51 PM
The mounts look like they might be in the right spot for the UC style swaybar available from K-MAX and Whiteline.
This is the K-MAC UC style on my hatch.
#292 _LH mike_
_LH mike_
Posted 08 June 2016 - 07:20 PM
Thanks for the info. Does anybody have a pic of where the swaybar mounts to the body?
#293 Heath
  • 18,403 posts
Posted 08 June 2016 - 11:44 PM
This is what the UC's have, but LH/LX don't have any mounts on the body (the swaybars just connect L and R lower trailing arms to one another lol)
#294 76lxhatch
  • 7,222 posts
Posted 09 June 2016 - 07:36 AM
All I had to do was make a hole in the upper arm mount
(please ignore the mess, I've just fixed a leak through the diff pinion spline)
#295 Heath
  • 18,403 posts
Posted 09 June 2016 - 11:06 AM
So you have to pull the upper arm off before installing the link pin? I guess that isn't the end of the world.
What's the swaybar off? Aftermarket or standard UC (IF that's standard R31, you beauty!)
Edited by Heath, 09 June 2016 - 11:07 AM.
#296 ls2lxhatch
  • 5,335 posts
Posted 09 June 2016 - 12:20 PM
Whiteline BHR37 swaybar
K-MAC TRC1
More pictures here
http://ls2lxhatch.com/suspension.htm
#297 76lxhatch
  • 7,222 posts
Posted 09 June 2016 - 08:41 PM
Not quite as easy to get at it with the arm installed but can be done - if you look at the photo above of the Whiteline bar you can get your fingers and/or a spanner in there.
As above, its a live axle VB-VS Commodore bar with the ends straightened out a bit in the press. The R31 bar I had was a spindly little thing and would have been narrower more like the UC one so you would need to fabricate brackets.
#298 Heath
  • 18,403 posts
Posted 09 June 2016 - 10:59 PM
Both nice solutions, but I'm particularly a fan of just running in straight into the floor of the upper mount after a bit of bending on the original bar.
Nice work.
#299 76lxhatch
  • 7,222 posts
Posted 10 June 2016 - 06:21 AM
I guess you could just spread the arms out a little wider to make the R31 bar work, you'd want a bigger one that what I had but I suppose they must be available
#300 _axl1979rose_
_axl1979rose_
Posted 26 July 2019 - 08:41 PM
Hey I’m not sure if this has been covered in the thread but do you use skyline axels filled n drill to what ever pattern your running?
Sorry I’m new to forums and stuff
