Fitting a R31 Skyline B/W diff to LH/X
#51
Posted 12 January 2009 - 04:35 PM
Posted 27 January 2009 - 04:17 PM
Edited by rorym, 27 January 2009 - 04:19 PM.
#53
Posted 27 January 2009 - 04:45 PM
Did you try it disabled to see how it went first?
#54
Posted 27 January 2009 - 07:20 PM
_@milco@_
Posted 19 February 2009 - 11:09 PM
#56
_Terrible One_
Posted 03 March 2009 - 10:49 PM
#57
_@milco@_
Posted 04 March 2009 - 07:19 AM
#58
Posted 04 March 2009 - 07:43 AM
Posted 04 March 2009 - 10:50 AM
Did you find any of the those Statesman anodised 450cp Prop valves at the wreckers?
This is speculation but you might be able to find them on V8 wagons with 4WDisc too I suspect.
If so I would be interested to see if the spring is the same as the picture as when I dismantled it the prop valve it seemed slightly skewed,
possibly suggesting it was tampered.
BTW: That photo of the dismantled prop valves is one I took a while back when when fixing a mates Statesman SLE brakes.
Had to unseize the prop valve.
#60
_Terrible One_
Posted 05 March 2009 - 06:05 AM
you would need to cut the housing down for sure.
I did some searching around here after I posted that and I found that LHoon bloke fitted one in his LJ 2 door without cutting it down, just used some front wheel drive offset wheels.
I sent him a PM with some questions, just waiting for his reply. If thats the case I'll definitely go down that path.
#61
_Terrible One_
Posted 05 March 2009 - 06:24 AM
In addition to that I found out that all R31 Skyline's are a 4x114.3 offset which is the most common 4 stud pattern (that and 4x100). I think a solution could be to re-drill axles and brakes to Torana pattern and then get a set of Astra 5 stud steel wheels (same stud pattern as Torana) which will solve the front wheel drive offset problem with the BW diff and you can keep a set of matching wheels. I didn't want to have to go 4 stud on the back.
#62
_conanricho_
Posted 17 March 2009 - 03:34 PM
just have 2 question. does it matter if the diff was out of an auto or manual
and a sedan or wagon skyline...??
#63
Posted 17 March 2009 - 05:38 PM
im think about doin this in my lh 308 manual, it looks like a great idea...
NO same same.
R31 Skyline 28 spline axles
Pintara..same diff same everything except 25 spline axles and diff.
Posted 17 March 2009 - 05:39 PM
LH Hoon used Commodore s off memory...same offset as Astra.
Fuzzy...no joy.
_Terrible One_
Posted 21 March 2009 - 03:38 PM
#66
_hatchit_
Posted 25 March 2009 - 09:10 PM
#67
Posted 25 March 2009 - 10:59 PM
Posted 26 March 2009 - 06:55 AM
#69
Posted 26 March 2009 - 11:29 AM
#70
Posted 26 March 2009 - 01:09 PM
#71
Posted 26 March 2009 - 03:28 PM
#72
Posted 26 March 2009 - 07:57 PM
#73
Posted 26 March 2009 - 08:49 PM
Just read through.. great work, looks pretty simple to set up the handbrake too. Rory, did you get the skyline axles re- drilled to hq pattern? how did you get the discs? are they skyline items re-drilld to hq pattern aswell?
Yep...No dramas as the wheels hold the discs on...I will get blanks redrilled like 76LX did for this car.
Edited by rorym, 26 March 2009 - 08:52 PM.
#74
Posted 26 March 2009 - 08:53 PM
who would do that kind of job? the diff place i get to do the mounts??
Aussie Diffs Currumbin.
_brett_32i_
Posted 19 April 2009 - 12:35 PM
NO same same.
incorrect.
auto pintara had 25 spline and 4.11 ratio. manual had 3.9 and 28 spline
