Fitting a R31 Skyline B/W diff to LH/X
#101
Posted 06 April 2010 - 08:13 PM
slowlx interesting that the touchy part of the conversion is the axle pattern change, another thought I have is that maybe using equal length axles (VN shorts) centres the housing in such a way that minimal welding to the cast metal is required equally on both sides. The down side is the narrow Torana tunnel with an offset drive shaft...
#102
_hatch76_
Posted 06 April 2010 - 09:20 PM
Hey guys called up 2 well known diff shops in the keysborough and dandenong areas asking about prices to convert the r31 diff. They both said the same thing that they do not recommend this conversion. Their words were that it would not pass an engineer, and that it wasn't the right way to do it. One shop pretty much said he would refuse to change the pattern on the exisitng r31 axles... Their answer was to make billet axles but then just to weld on the brackets and new axles without touching the centre or diff gears would cost almost $1500. They both recommended Cutting down a vn diff to fit quoted me around $900 to do this and weld on the brackets, but then your stuck with commodore stud pattern so dunno now.
Hi mate
I'm in Adelaide, and same problem as you finding someone to do this conversion. Tried Rod tech, they said can't be done. Would have to do a VN onwards. They quoted me $770 to shorten and change stud pattern using a commodore diff. I guess that included the Torana pick up points. Mite check.
Edited by hatch76, 06 April 2010 - 09:23 PM.
#103
_brett_32i_
Posted 06 April 2010 - 09:45 PM
i used shaun mullins in bayswater. was $350 to mount my brackets to the skyline housing. i also supplied donor housings.
i think it was super trick in dandy did my axles (restud) for i think $120 total or $120 each??
#104
Posted 07 April 2010 - 10:03 AM
Hi mate, just wondering where you got the slotted disc rotors from? Did they bome as blanks with no stud holes drilled? Do you have a manufacturer and or part number handy?The Skyline and Commodore calipers are very very similar, only difference is the built-in handbrake on the Skyline ones, bleed nipples in same place. The Skyline mounting position is rotated maybe 25 degrees (at a wild guess) up at the rear compared to Commodore, no issue with bleeding. The Commodore calipers would sit further inboard due to the disc offset I reckon, although perhaps the axle flange position makes up for some or all of this?
edit: looking at Rory's pic on the previous page, it looks like he has had the flange on the end of the housing rotated almost back to Commodore position, mine are standard R31:
#105
Posted 07 April 2010 - 11:44 AM
#106
_@milco@_
Posted 07 April 2010 - 12:27 PM
#107
Posted 07 April 2010 - 06:19 PM
I will measure my spare set later Terra.Ah, yup. Blond moment sorry.
So does someone have some lengths handy from a conversion?
I seem to remember 660mm as the short one and used a VN short as the long but both being 10mm short overall.
_youngy_11_
Posted 08 April 2010 - 12:59 PM
#109
_wardy_
Posted 15 April 2010 - 10:11 PM
#110
Posted 16 April 2010 - 06:59 AM
#111
Posted 16 April 2010 - 08:48 AM
Edited by derrin71, 16 April 2010 - 08:52 AM.
#112
_wardy_
Posted 16 April 2010 - 05:55 PM
Dont know yet if they were blanks or redone skyline rotors , will find out when they arrive monday
#113
_sprx3_
Posted 19 April 2010 - 03:01 PM
im looking at doing this to a uc, i would like to put commy wheels on (maybe walkinshaws VL) will the skyline diff offset be suitable? or should i be looking at a commy diff & getting it cut down?
#114
_sprx3_
Posted 20 April 2010 - 03:55 AM
Hey guys,
maybe i should be asking what offset i should be using with whatg size rim. im going flareless
also whats the best suited front brake upgrade to suit the skyline rear? sorry im new at this
#115
Posted 20 April 2010 - 07:04 PM
Hey guys,
Maybe you should request a mod remove your replys to this thread and start a new thread with your specific questions, this is a thread on how to convert a diff to suit standard LH LX torana, not so much on modifying it to suit your specific car and wheels.
also whats the best suited front brake upgrade to suit the skyline rear? sorry im new at thisp,s im putting a 304 into the car & am looking for a street stip car for some fun
#116
Posted 29 April 2010 - 12:33 PM
He had his new BW commy diff shortened to fit LH?X.
Supplied with new rear rotors & recoed [presumably] calipers.
Unpainted with a stock centre.....$3200!!!!!
#117
Posted 29 April 2010 - 12:51 PM
I just had a visit from a m8.
wow, he got jipped big time. my complete 9 inch with billet axles was only $1900.
#118
Posted 29 April 2010 - 01:25 PM
When did they start making these things out of gold?
#119
Posted 29 April 2010 - 03:39 PM
#120
Posted 30 April 2010 - 12:23 AM
#121
Posted 30 April 2010 - 10:20 AM
I presume that 1 axle is the right length. So instead of using 1 long/1 short, they use 2 short. No resplining required. Only 1 axle tube requires shortening. Someone correct me if i'm wrong.
Then the usual swapping of the brackets.
In a workshop enviroment; with a jig; you should be able to spit out 3 or 4 housings/8hr shift.
Why have the prices gone from $4-600.....to $3000+?
I think this conversion has merit. It started out cheaper & lighter than the usual 9" option, but with these prices, it's out of reach for many!
I need to start making diffs. Clearly i'm in the wrong game!
#122
Posted 30 April 2010 - 11:07 AM
The VN short axle is pretty well exactly the same length as LH/LX Torana but I'm not sure if its preferable to maintain the Borg Warner offset centre which would require different lengths...? Does seem a bit sillyI presume that 1 axle is the right length. So instead of using 1 long/1 short, they use 2 short. No resplining required. Only 1 axle tube requires shortening. Someone correct me if i'm wrong.
#123
Posted 30 April 2010 - 11:46 AM
#124
_Torrie_Man_
Posted 30 May 2010 - 02:30 PM
#125
Posted 30 May 2010 - 05:37 PM
Does anyone know if you could slip a couple of Volvo BW axles into a skyline housing to save redrilling the stud pattern?
volvo axles are 27 spline, totally different size too.
