Parts Bin suspension
76 replies to this topic
#26 TerrA LX
Posted 15 March 2009 - 01:26 AM
QUOTE (ALX76 @ Mar 15 2009, 01:43 AM) *
I reset (bent?) my standard ones (I used someones jig) (press?) and saved hundreds.
Not picking, just asking. :huh:
(bent?) Sorta yes and (press?) NOOOOOOOO way buddy.
Edited by ALX76, 15 March 2009 - 01:28 AM.
#27 LhMusL
LhMusL
  • 468 posts
Posted 02 May 2009 - 03:09 PM
Just a quick sum up, if you wanted to use the Hoppers 290mm kit on a LH, would you just get a UC front end, lower the upper control arm bolt holes 25mm and get a kit to suit UC??
Is the main reason for swapping stubs etc just to get a better caliper on there eg. HX, HQ etc so if your going Hoppers kit which is better than HQ, then you dont need to go through the hole changing stubbs, steering arms etc????
Or is it more the ride height drop and the thicker stubs (a9x, HX 1tonner) that you would swap stubs for???
#28 76lxhatch
  • 7,207 posts
Posted 02 May 2009 - 05:48 PM
Mainly the brakes that you would swap for as you've written, I doubt many people would be too worried about using them for drop stubs when lower springs are so readily available
#29 LXCHEV
LXCHEV
  • 3,611 posts
  • Car:'76 LX - 383 Chev
Posted 02 May 2009 - 10:21 PM
Agree - the main reason for going to all the effort of converting to HQ stubs is for running HQ brakes. By doing so, introduces the steering geometry issues, hence the need to fit A9X style steering arms, to bring it back to normal specs again.
So if you can fit bigger brakes onto the factory stubs these days, there's not really a need to perform the stub axle conversion.
One question for cruiza - you mention "weld bracing plate to underside" of any sub-frame / k-frame. What's the reason for this, is flex really an issue? Any pics to show what you're talking about, I'd be interested to see that. As for the rest of your list - I think you've summed it all up beautifully. It's pretty much how I built my front end too - besides things like Bilstein shocks as well (I used Sports Ryders)... the other thing I would like to change, is to go for the solid bushes to mount my LX rack - is anyone making these yet? I reckon there'd be a few interested people if someone did a run of them.....
Edited by LXCHEV, 02 May 2009 - 10:22 PM.
#30 _Bomber Watson_
Posted 03 May 2009 - 12:14 PM
I was gonna spin some up out of 4340 steel at work, although i have been looking into getting myself an aluminium billet to make them from.
Though if a lot of people are interested i may be able to price an aluminium billet, might even be able to talk the boss and the cnc operator into the feasibility of ripping up a program....
That or someone qualified can have a go at it and save me the dramas....
#31 76lxhatch
  • 7,207 posts
Posted 03 May 2009 - 02:03 PM
What's the reason for the solid mount bushes, to keep the slightly quicker LH/LX ratio or just because its cheaper and easier than a UC rack?
#32 LXCHEV
LXCHEV
  • 3,611 posts
Posted 03 May 2009 - 06:48 PM
I would have thought to keep the quicker LH/LX ratio rack in place, and do-away with the rubber or nolathane type bushes, whichever you run. Would be cheaper and more effective than going and sourcing an entire UC rack and swapping them over, plus then you end up with a slower ratio rack.
#33 _CHOPPER_
_CHOPPER_
Posted 06 May 2009 - 07:42 AM
If you want to run a high castor angle without power steering, the UC rack would give lighter steering whilst keeping the benefit of better directional stability of the higher castor angle.
#34 _cruiza_
_cruiza_
Posted 06 May 2009 - 08:49 PM
Hi LX Chev
I was told when I was doing this that flex bending was an issue and for me it has helped protect the sump, (still had to weld up holes twice) sorry no pics but if you look at underside flat plate with slight kick welded at seam at front below rack mounting and then rest of way round. Another thought could be that plate also beefed up for jacking the car up, I didnt think to ask just did what I was told.
Also just as a follow up comment UC steering rack is slower then LX LH but I steer with right foot anyway so was not an issue
#35 _Squarepants_
_Squarepants_
Posted 06 May 2009 - 09:30 PM
Hi LX Chev
I'd also be very interested to see pics of this "beefing up", "slight kick" and "rest of way round". I don't quite understand what you mean with your explaination.
As far as the slower UC rack and the throttle steering goes, I'm all for it, it just means more arm work when crossing up. That's why I'd prefer quicker ratio.
#36 _cruiza_
_cruiza_
Posted 06 May 2009 - 09:49 PM
anyone got a pic of the underside of a front subframe? I will photshop mod to pic of standard one
Edited by cruiza, 06 May 2009 - 09:50 PM.
#37 _Squarepants_
_Squarepants_
Posted 06 May 2009 - 10:20 PM
I hope these'll do.
#38 _cruiza_
_cruiza_
Posted 07 May 2009 - 07:33 AM
Yep they will do nicely, I see yours has a dent it which I figure is the reason for beefing it up.
out line in red foldline is ----- I am making sense now? :blink:
Attached File  subframebottom.jpg   378.85K   75 downloads
Attached File  subframe_front.jpg   343.35K   52 downloads
#39 76lxhatch
  • 7,207 posts
Posted 07 May 2009 - 08:28 AM
You just put another plate over that area?
#40 _cruiza_
_cruiza_
Posted 07 May 2009 - 09:20 AM
yip :D
#41 _Squarepants_
_Squarepants_
Posted 08 May 2009 - 06:01 PM
Thanks Cruiza, I'm reading you loud and clear now.
What thickness plate did you use? I'm thinkin 5-6mm???
#42 _cruiza_
_cruiza_
Posted 08 May 2009 - 06:33 PM
Nah 2 - 3 mm tops I cut the hole in the centre so it looked totally standard too only way to tell I had doine it was bit of weld at the ends, I thing the sandwich effect of two layers of metal gives it the strength as much as thickness, as I have mentioned in another thread the underside of my car copped a huge beating from lumps and bumps in the roads in NZ
#43 _Squarepants_
_Squarepants_
Posted 08 May 2009 - 06:51 PM
Aahh, yep. That makes sense. Thanks mate, I think I'll have a crack at that.
#44 _cruiza_
_cruiza_
Posted 09 May 2009 - 04:09 PM
If you do post some pics, also remmber not to weld too much in one area other wise heat will distort bend the K frame
good luck
#45 _Squarepants_
_Squarepants_
Posted 09 May 2009 - 05:28 PM
Will do.
While we're here, does anyone know what the recess in the pass. side outrigger (on the right in the pic of the bare x-member) is for?
Edited by Squarepants, 09 May 2009 - 05:29 PM.
#46 76lxhatch
  • 7,207 posts
Posted 09 May 2009 - 09:19 PM
Both outriggers are identical I think, so the passenger side recess does nothing but on the driver side it provides steering gear clearance on top.
#47 _Squarepants_
_Squarepants_
Posted 10 May 2009 - 08:27 AM
I see, said the blind man.
Cheers! :spoton:
#48 _brett_32i_
_brett_32i_
Posted 06 June 2009 - 05:23 PM
can anyone confirm that hq-wb widen the track by 50mm???
i remember when i ran them that it sat lower, but cant remember it being any wider?
#49 _cruiza_
_cruiza_
Posted 06 June 2009 - 06:05 PM
Yes they do and lower the car by 25 - 30mm
#50 _Squarepants_
_Squarepants_
Posted 06 June 2009 - 10:29 PM
Stub axles, yeah?
Not sure of exact distance but yes, that's what I've been told by people in the know.
