Drilling K Frame Holes
7 replies to this topic
#1 _Lhover_
_Lhover_
Posted 13 August 2008 - 09:55 PM
Hello all I have just drilled lower holes in my k frame for my UCA mounts.I read that some people have trouble marking out their k frames and drilling accurately.Well below is how I did it- easier making an drilling fixture and safer than experimenting on your frame.
See below for drawing of template.
Finished drilling template
Checking template holes are drilled to rhe correct centre distances to suit UCA pivot shaft.(make sure you check both sets of holes)
Template bolted to k frame through upper holes- Now drill through bottom set of holes with 7/16 inch drill.
Finished k frame with drilled holes
Please note that this template is for moving UC k frame holes down 25mm if you have an lx lh k frame you will have to change the 25mm dimension to suit your vehicle.I could have drilled the holes lower but I wanted to leave a bit of the verticle face to hold my shims nice and tight.
Cheers Chuck. :D
Edited by Lhover, 13 August 2008 - 10:01 PM.
#2 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 13 August 2008 - 10:23 PM
Nice job!
#3 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 13 August 2008 - 10:52 PM
Onya chuck :spoton:
#4 TerrA LX
Posted 13 August 2008 - 10:57 PM
awesome work :spoton:
#5 rodomo
  • 18,032 posts
Posted 13 August 2008 - 11:13 PM
Your an "ideas man"! :clap:
#6 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 14 August 2008 - 06:17 AM
Sweet! :clap:
#7 _Lhover_
_Lhover_
Posted 14 August 2008 - 08:35 AM
Gooday Rodmo,
I would like to think I'm an "Ideas man" but whenever I tell my wife how good my Torana will be when I'm finished, she says "tell him he's dreamin".
Chuck
#8 rodomo
  • 18,032 posts
Posted 14 August 2008 - 09:39 AM
Gooday Rodmo,
Chuck
Laff, laff, laff :spit: :clap:
