removing harmonic balancer bolt on v8!!!
_Chamois hatch_
Posted 15 August 2008 - 04:56 PM
its starting to really anoy me!
_willo_
Posted 15 August 2008 - 05:11 PM
Posted 15 August 2008 - 05:13 PM
Right side for left hand threads.
Left side for right hand threads.
Confusing, I know
Posted 15 August 2008 - 05:40 PM
here is my process for undoing tight bolts:
use a 1/2" drive rattle gun, if that doesnt work
use a 3/4" drive rattle gun, if that doesnt work
use a 1" drive rattle gun, if that doesnt work....
time for the Rambo Gun!
_Chamois hatch_
Posted 15 August 2008 - 06:11 PM
_timbotorrie_
Posted 15 August 2008 - 07:09 PM
or in desperate times if you have the sump off jam something between the crank and the block like a wooden handled hammer!
Posted 15 August 2008 - 10:03 PM
_Chamois hatch_
Posted 15 August 2008 - 10:17 PM
_willo_
Posted 15 August 2008 - 10:58 PM
i thought i was the only one bodgy enough to do it like that....should secure the bonnet when tryin this one otherwise the spanner may just fly off and chase ya across the garage....LOLIf it was still in the car, do it' like I've seen Holden do it, fit the socket, jam the rachet in and turn the motor over, rough as guts but worked.
Posted 15 August 2008 - 11:03 PM
_trna76hb_
Posted 16 August 2008 - 07:28 AM
Put a block of wood between the block & crank
& swing off with a socket & bar.
Give the bolt a smack with a copper hammer also .
Ian
_Chamois hatch_
Posted 16 August 2008 - 04:53 PM
used some wise grips on the balancer itself, that jammed up against the timing cover, then a breaker with a 2m iron bar, undid it nicely. with no damage. few scratches on the balancer itself, needed a new balancer anyway.
cheers for the suggestions
_ChevLX_77_
Posted 16 August 2008 - 08:15 PM
