Gas primer button doesn't work
7 replies to this topic
#1 _73LJWhiteSL_
_73LJWhiteSL_
Posted 26 August 2008 - 08:18 PM
Gday all,
was just wondering if anyone had any ideas? My gas primer button, that squirts gas into the carb when it is pressed has stopped working. So consqeuently i have to crank for 30 - 45 seconds before the car starts if the car has been sitting for more than 5 or 6 hours.
As best i can see the switch still works, the wires on the switch look ok, but i am not quite sure how the system works. All the wires around the converter appear to be connnected.
Anyone got any ideas?
thanks
Steve
Edited by 73LJWhiteSL, 26 August 2008 - 08:18 PM.
#2 _[NORUST]_
_[NORUST]_
Posted 26 August 2008 - 10:10 PM
well i know it not gonna help with your problem but i heard that thses switches are illegal...... you should have an automatic primer swith set-up to your ignition.
allthough having said that i think i wanna get a prime button installed aswell as mine still takes a little too long to start.
#3 _73LJWhiteSL_
_73LJWhiteSL_
Posted 26 August 2008 - 10:27 PM
Are you sure these switches are illegal? The switch was installed by the reputable company who fitted the gas system. I would rather not have to take it back there just to fix a switch, but i am gonna have to do something soon.
Steve
#4 rodomo
  • 18,032 posts
Posted 27 August 2008 - 12:50 AM
Do you use Shell gas?
#5 _73LJWhiteSL_
_73LJWhiteSL_
Posted 27 August 2008 - 07:45 AM
I do actually Rob, only cause i get the coles dockets off my parents since they hardly use them.
Whats wrong with Shell Gas?
Steve
#6 _73LJWhiteSL_
_73LJWhiteSL_
Posted 27 August 2008 - 10:20 AM
Thanks for the PM devilsadvocate it appears just unpluging and replugging the cables on the black solenoid have made it work again. Possibly a dirty lug.
Here are some pictures of my setup It looks like the blue one is the lockoff and the black one is the primer.
Steve
#7 rodomo
  • 18,032 posts
Posted 27 August 2008 - 09:04 PM
Steve
Correct!
There has been a problem with Shell, the solenoids stick due to residue on the seats.
Car won't start cold but O.K. for the rest of the day once warmed up. I maybe go to 2 or 3 a week in this weather.
#8 _73LJWhiteSL_
_73LJWhiteSL_
Posted 27 August 2008 - 10:45 PM
Well it worked briefly and now doesn't work again. So any suggestions for unsticking the solenoid? Maybe try some BP gas?
Steve
Edited by 73LJWhiteSL, 27 August 2008 - 10:45 PM.
