Hopper Stoppers+New 15" mags
#1 _76S.L.R_
Posted 26 August 2008 - 08:23 PM
How much do the Hopper stopper Brake Kits sel for these days?
Posted 26 August 2008 - 09:15 PM
you need from DBA blanks.
Kits are $1200 with smooth rotors $1300 slotted and $1350 drilled and slotted.
This gets the whole package, rotors, calipers, pads, hubs, bearings, seals, grease caps, brackets, spacers and hoses all totally bolt on with no mods,
Caliper to the rear (swap stubs left to right) Calipers come red, black yellow or alloy all same price.
Engineers report is included.
All stud patterns available, and minimum 15 inch wheels needed, check with us re brands as some need small wheel spacer to clear.
For the rear we have a 280 by 20 vented set up based on HSV VS rear rotorsand Corvette rear calipers with handbrake incorporated.
This sells at $1300 with smooth rotors, $1400 slotted and $1450 drilled and slotted. can best seen at www.hoppers.com.au/street3.htm
The standard master and booster will certainly be fine for 4 wheel discs, only thing you need to do is remove the residual valve form the master
cylinder going to the rear brakes.
This is a little valve that lives behind the brass olive in the outlet port where the line comes out.
Remove the brass olive by screwing a small self tapper into the centre hole, use this to pull the seat out, discard the valve and refit the seat. Now you
have a 4 wheel disc master.
Next take the seals out of the proportioning valve part of the combo valve and its all good to go with 4 whels discs, (the valve is set 220 psi for
drums and discs will be fine with either no valave or at least 450psi.)
Freight usually around $40 and we can take payments by Credit Card, direct credit,
send cheque or money order in post.
Posted 26 August 2008 - 09:25 PM
Posted 27 August 2008 - 11:45 AM
#5 _76S.L.R_
Posted 30 August 2008 - 03:51 PM
Edited by 76S.L.R, 30 August 2008 - 03:59 PM.
#6 _76S.L.R_
Posted 06 September 2008 - 12:42 PM
Posted 06 September 2008 - 02:50 PM
#8 _76S.L.R_
Posted 06 September 2008 - 05:39 PM
Thanks mate,I'll give them a call next week...........Have you spoken to Stan at Allstreet Tyres & Wheels (08) 9359-3888
#9 _Stuart_
Posted 20 November 2008 - 09:41 PM
Posted 20 November 2008 - 11:48 PM
They do a kit for Torana that pushes the wheels out 8mm per side
Then you could use Commodore wheels
Lots more choice there and 12mm studs instead of lil 7/16 ones
Posted 21 November 2008 - 09:55 AM
Posted 21 November 2008 - 09:56 AM
the 3 peice are suppose to b extremly strong the centres are pressed in then seam welded in place.and best of all they r not made in china like 90%of wheels these days.he paid 300 for 2x 17x8s and 350 for 17x 9n1/2s so reasonable priced.and he got them in hq pattern.
#14 _CHOPPER_
Posted 21 November 2008 - 01:23 PM
Speak to Hoppers first
Or if you're not religious, get Ford stud pattern and get AU fitment rims. They have +35 offset compared to Torana offset of +32. With the 8mm increase per side, this will increase front track by 10mm overall. You then get the super strong 1/2" studs and the worlds most common stud pattern.
#15 _Stuart_
Posted 21 November 2008 - 04:48 PM
Posted 21 November 2008 - 05:55 PM
