best things to do to a 253??
_torana_49_
Posted 30 August 2008 - 11:16 PM
Mike (torana_49)
Posted 30 August 2008 - 11:27 PM
_torana_49_
Posted 30 August 2008 - 11:34 PM
Posted 30 August 2008 - 11:36 PM
Any particular reason why you don't want a 308?
Tim
Edited by RIM-010, 30 August 2008 - 11:37 PM.
_torana_49_
Posted 30 August 2008 - 11:45 PM
_hatcher_
Posted 30 August 2008 - 11:57 PM
I thought that 253's and 308's ran the same manifold from factory...
Tim
I thought these were the stock manifolds:
2 Brl Manifold on 253
4 Brl Manifold on 308
Dave
Posted 31 August 2008 - 12:03 AM
I forget things sometimes...
Tim
Posted 31 August 2008 - 12:10 AM
_hatcher_
Posted 31 August 2008 - 12:13 AM
Dunno if its right but someone (cant remember who) told me that one of the early commodore models was the only one to come out with a 4 barrel manifold on a 253.
Hmmm, dunno bout that one, spose anything possible with GMH then
_torana_49_
Posted 31 August 2008 - 12:16 AM
Hmmm, i wonder if mines the original engine, hmm
Posted 31 August 2008 - 12:22 AM
Engine no. prefix will tell you what model the motors from.
Swappin manifolds isnt hard and probably common to replace the 2 barrel with a four on a 253.
Posted 31 August 2008 - 01:17 AM
Posted 31 August 2008 - 01:23 AM
You can make them go.
I will be putting one in the Bombadoor within the next 12 months.
RRS might have pull his socks up
Posted 31 August 2008 - 01:42 AM
In any case, assuming your rebuilt 253 has was done correctly and still has at least the 9.0 to 1 compression ratio, Im sure it will benifit from some head work and a mild cam. Just dont over size the head valves. At least with manual you wont have worry or spend money on a stall converter.
_Herne_
Posted 31 August 2008 - 01:47 AM
Amazing how well they go and they are 253's.
Herne
Once the VK commodore came along the 253 was dropped and only black 308s where built. Correct me if I'm wrong anyone.
Correct AFAIK
Posted 31 August 2008 - 03:03 AM
No not ALL 308's had them, some had the two barrel set up same as 253.All 308s had 4 barrells.
_MRNOS_
Posted 31 August 2008 - 06:26 AM
Posted 31 August 2008 - 08:37 AM
Posted 31 August 2008 - 10:05 AM
Yes there was one and only 308 with a 2 barrel, but it wasn't a WW Stromberg it was a 2 barrel Rochester like a HK/T 307 but fitted with a governer. It was a V coded engine (ie xV instead of xT) low compression engine in an M series Bedford. The rest were all 4 barrels. All VC-VH and WB 253's were also 4 barrel.
To make a 253 go good a 4 barrel and Quadrajet, HEI dizzy off a blue motor, extractors, mild cam and stock valve heads. You can do more but it's be cheaper to build a 308 than go any further.
Edited by yel327, 31 August 2008 - 10:07 AM.
#21
_TJ253_
Posted 31 August 2008 - 10:11 AM
and a cam will make her sound tuff Think Crane 286 or Crow 5666 are the go
you will also need Valve Springs and depending on how much cash you got maybe
get a new Holley and Performer manifold.
This is what i have got for my 253 for extra grunt but have not built it yet
Crow 5666 cam & Valve springs to match
465 Holley
Edelbrock performer Manifold
ACL Race Series Pistons
And will Probally go 10-1 Comp
Anyway good luck mate and go the Mighty 253
#22
_torana_49_
Posted 31 August 2008 - 11:34 AM
if i could put up the engine number, could you tell me if its the original engine??
Edited by torana_49, 31 August 2008 - 11:36 AM.
#23
Posted 31 August 2008 - 01:46 PM
If you just want cheap things to improve power and stuff.
Get some good Quality extractors and get a twin system (Twin 2.25" is good for a 253)
Put in an Electronic Dizzy (Make sure you have 12V at the coil)
Maybe get some Thermo Fans and loose the big engine fan
Then once all that is donem GET IT DYNO TUNED! A tune will be the best thing you do, a good tuner will get the carby working great and really responsive! Make sure you do the tune after you have done everything though.
Other things you could look at doing, is a Cam and Maybe getting bigger valves in the heads and a bit of port work, also higher compression would do wonders for you!
#24
Posted 31 August 2008 - 02:30 PM
Carb
Cam
Compression
You already have the base there with the 4 barrel manifold, Rochester and extractors, now just get the heads tidied up, bump the compression up and fit a bigger cam. An electronic dizzy helps too
#25
Posted 31 August 2008 - 04:21 PM
In your situation, as the motor was rebuilt recently and you seem possibly reluctant to redo the bottom end, so really only leaves you with hand full off bolt on addons you can do. Any more than that will be of no benefit on a 253 without raising your compression.
As mentioned earlier, if your gonna go to the trouble of putting in new pistions for at least 10to1 compression you may as well spend the money and time on a 308.
As suggested , thermo fans, electronic dizzy, exhaust, good extractors and a mild camshaft( maybe some HD valve springs too)are all good easy beneficial addons and wouldnt even have to pull off the heads off or motor apart.
You already have the 4 barrel carb which is good for 1.5sec better on the quarter mile than the 2 barrell.
