The SLR 6000 Project
#101 _Herne_
Posted 23 April 2009 - 12:20 PM
Herne
#102
Posted 23 April 2009 - 12:42 PM
#103 _Herne_
Posted 23 April 2009 - 12:48 PM
Didn't take any notice to tell you the truth herne but it'll be pretty tight I reckon, trying to fit a 3" pipe either side of the tank
yeah mate I wish you luck
You might have to look at going under the diff. Not sure if that appeals to you or not.
Herne
Edited by Herne, 23 April 2009 - 12:52 PM.
#104
Posted 23 April 2009 - 01:00 PM
#105 _LXATIV_
Posted 23 April 2009 - 01:07 PM
#106 _Lxrana_
Posted 23 April 2009 - 07:00 PM
#107
Posted 23 April 2009 - 10:07 PM
In the past, to get dual 2.5" pipes past the tank and 265/60 tyres I had to relieve the rear bracket mounting the tank to the rail. 3" pipes will be interesting.
Thanks howard, lol, you got me thinking, So got straight home from work out into the cold shed with a bit a 3 inch pipe. It is definately going to be interesting, It's going to be very tight, BUT, I reckon we can make it work, it'll have to pretty much hug the bottom corners of the tank and will have to run under the diff as Herne said. I want to see what it'd look like with the same style pipes beside the tank as the A9X's but 3" instead of the small A9X size.
#108 _The Baron_
Posted 23 April 2009 - 10:32 PM
Took 3 goes and it could still be better but it rarely touches.
It goes over the diff but does not use the factory hangers.
Just remember you need heat clearance and it will shake and shimmy with the engine movement.
#109
Posted 24 April 2009 - 09:03 AM
#110 _LXATIV_
Posted 24 April 2009 - 01:10 PM
#111
Posted 24 April 2009 - 01:27 PM
Edited by orangeLJ, 24 April 2009 - 01:27 PM.
#112
Posted 24 April 2009 - 01:52 PM
#113 _doogs_
Posted 24 April 2009 - 02:12 PM
#114 _LXATIV_
Posted 24 April 2009 - 02:30 PM
#115 _j7723_
Posted 24 April 2009 - 02:39 PM
#116 _LXATIV_
Posted 24 April 2009 - 02:48 PM
It might be a bit late now, but i remember reading an artical on gray myers new xa coupe and he had reliefs cut in the floor for the exhausts
#117
Posted 24 April 2009 - 04:18 PM
go up into the boot then out the back off the boot heaps of room in there LOL
Good for winter driving too...
#118 _LXATIV_
Posted 24 April 2009 - 04:20 PM
#119
Posted 24 April 2009 - 04:40 PM
Just get the rear sections ceramic (HPC, jethot etc) coated, would keep the heat away from the fuel tank.
Thats the plan as the extractors also need to be modifed before they go off to jet hot, so I though I may aswell get the rest done aswell, or even just teh tailpipes.
Going under the diff would help with heat but it would probably cause problems with clearance
Have seen a few cars with the pipes under the diff so can't be too bad, Dont think i'll have enough room over the diff as the car will sit pretty low and it is a lot of extra stuffing around with bends, ect. The main problem area for exhausts on low cars is the middle of the car when your going over speed humps, in driveways and stuff, thats why we made cutouts in the rear passanger floor for the exhuast to sit up a lot higher. Around the diff area shouldn't be too much of a problem, as the exhaust will sit around the same height as the bottom trailing arm mounts, sussed this out last night.
Or just dump it at the diff and be done with it, lol haha.
#120 _Herne_
Posted 24 April 2009 - 05:34 PM
Life would be much easier if they just let us dump it at the diff eh
A mechanic once said to me Al your exhaust is illegal anyway (noise) so why not dump it at the diff and be done with it lol I think he has a point.
I will now put my halo back on straight so as not to disillusion any one
Herne
#121
Posted 24 April 2009 - 05:46 PM
It will be the sour point of your car and the first thing people pick on.
#122
Posted 24 April 2009 - 10:03 PM
Not necessarily, I've had another Torana enthusiast tell me (while looking at my car) that I should have run the exhaust under the diff rather than over because its possible to fit bigger diameter pipe. It was already under, tucked away nicely with no clearance issues.dont let the build down by runing the exhaust under the diff, it looks shit full stop and its noticeable.
#123 _Herne_
Posted 24 April 2009 - 10:07 PM
I agree, if someone is looking at the car with an intent to buy then the pipes can soon be changed to their liking. I dont think I would call them ugly running under the diff but if possible and at a fair cost I prefer them over. Mine are currently over but I drop from 2.5" down to 2" to do it. Not happy with that but its affordable
Herne
#124 _darrenmark1_
Posted 24 April 2009 - 10:19 PM
#125
Posted 27 April 2009 - 07:21 PM
Mounted the surge tank today in the boot after speaking to the engineer, All sweet having the battery and the surge tank in there together although on opposite side of the tank, all that is required is the battery to be in a box with a ventilation hose to the outside of the car. Also ordered the 1/2" fuel pipe to run underneath the car, going to run braided fuel line's in the engine bay and the boot.
Seen a very smick White and Black SLR5000 today in my travels, Nice and low, Big fats, Shiny Tank, Geez it was nice I near ran of the road looking at it, lol.
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
