Catch Can
149 replies to this topic
#101 _rorym_
Posted 21 January 2009 - 11:46 AM
Part of the fix.
#102 grina05
grina05
  • 131 posts
Posted 21 January 2009 - 05:36 PM
my eng builder told me to put some pipe cleaners in the pushrods
what do u guys think?
#103 _why-psi_
_why-psi_
Posted 21 January 2009 - 05:48 PM
heres my breather tank. i was thinking of running a line from the bottom of the rocker cover to one of the sideplates as a drain. or does it not need it?
#104 _rorym_
Posted 21 January 2009 - 08:18 PM
Someone elses problem solver.
#105 76lxhatch
  • 7,205 posts
Posted 21 January 2009 - 08:19 PM
Is that a roll pin?
#106 _rorym_
Posted 21 January 2009 - 08:35 PM
In the interest of future users and as suggested earlier and speaking to 82911 on my bearing clearances and how my builder has shimmed the pump to the engine, we have decided to run the H/V for now and see where this all ends up. If it still pumps up I can then change to my new std pump.
I will keep all interested parties informed....and Yes...that is a roll pin and his mod works a treat...gotta love aussie ingenuity!!.
Edited by rorym, 21 January 2009 - 08:35 PM.
#107 ls2lxhatch
  • 5,332 posts
Posted 21 January 2009 - 10:03 PM
I would be more comfortable with the idea of using a roll pin than using pipe cleaners.
#108 grina05
grina05
  • 131 posts
Posted 21 January 2009 - 10:25 PM
me to
#109 _ass308_
_ass308_
Posted 22 January 2009 - 05:27 AM
the pushrods i bought for my engine,came with roll pins,in the packet.
#110 _rorym_
Posted 22 January 2009 - 08:43 AM
Now thats interesting.....
#111 TerrA LX
Posted 22 January 2009 - 12:22 PM
Brands and pictures please.
I was always worried that a roll pin may gouge into something if the pushrod end was not smooth as.
#112 _ass308_
_ass308_
Posted 22 January 2009 - 12:24 PM
sorry rory,i have lead u astray.the roll pins didnt come in the box with the pushrods.my engine builder bought them home from his work.he was going to use them,but changed his mind.it looked to me like they came together.when i first saw the pushrods,he had the roll pins in his hand,with the pushrods.
anyways it seems like its the way to go.as far as my engine builder is concerned,its ok to use roll pins in pushrods
im watching this closely because ill have to do something to.on the dyno i blew the elbows out of the standard vn covers.but there was absolutly no trace of oil coming out,at the moment
#113 _rorym_
Posted 22 January 2009 - 01:32 PM
There will be..the drain backs are smaller...
#114 Evan
Evan
  • 1,287 posts
Posted 22 March 2009 - 12:09 PM
Sorry to bring back up an old thread, but what was the conclusion on this matter?
Did the .050 hole in the push rods restrict the oil flow to the rockers? have you stuck with the high volume oil pump or did you go down to a standard one?
Im going to ring the guy doing my heads and get him to drill the drain holes on my VN heads to 10mm.
Evan.
#115 Rockoz
Rockoz
  • 4,030 posts
  • Name:Rob
Posted 22 March 2009 - 04:53 PM
Another oil question for you rory.
Has anything been done in your engine mods to address lack of oil on the cam.
Seem to remember this being an issue in the 80s.
#116 Evan
Evan
  • 1,287 posts
Posted 23 March 2009 - 12:19 PM
i just rang the bloke that is doing my heads and he measured the drain holes to be 11mm Measured a few others that were 11mm too.
Hmmm. Whats the go with that ?
Evan.
#117 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 11 July 2009 - 12:16 AM
Hey guys,
Just thought i would search for the "answer" with oil up top and catch can setups has anyone else got some photos of their catch can setups?
I definately have an issue with oil/blowbye/breathing/ at high RPM and am keen to set up a catch can after looking on evilbay height seems that it may be a problem with most catchcan setups offered . I have my radiator overflow "catchcan" mounted on passenger side front of head at present .
There seems to be plenty of room behind drivers side headlight for a can but height is a little restricted anyone want to share their setups ?
#118 ls2lxhatch
  • 5,332 posts
Posted 11 July 2009 - 01:14 AM
You will find catch can pictures and discussion in this thread.
#119 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 11 July 2009 - 01:33 AM
Had a read through that thread and get the picture but there aren't many pictures lol
i am just wanting to see how others have setup their catchcans and where they have got them from?
Garth
#120 _Westie_
_Westie_
Posted 13 July 2009 - 11:49 PM
G'day,
Just wanting to get some thoughts on oil catch can issues for my LC. Firstly I am useless mechanically, and so have anything done on the car by my Dad's mechanic. I purchased the car almost as is, but recently have added an ASR race sump, and the mechanic then added this new "shiny" :banghead: catch can and fitting etc which on Sunday just gone, spewed all over the place. (really could not give a shit about shiny..just want it to work)
Previously the car had an upturned 4 litre oil bottle with some clear plastic tubing, and all was fine!
So after some advice and help from friendly racers, I blocked the lower line that connects back to the front of the block. They said that as Sandown was mainly all left hand turns, all the oil will simply run straight up the line and into the can....which is very small.
Does anyone have any suggestions to a decent race setup? My thoughts are simply to get a large catch can from somewhere (like what I had but "shiny"), and then remove the lower line back into the block to stop the oil from rushing up on left hand turns.
Attached File  CIMG5208.JPG   182.84K   25 downloads
Attached File  RIMG1040.JPG   239.07K   26 downloads
Edited by Westie, 13 July 2009 - 11:53 PM.
#121 rodomo
  • 18,037 posts
Posted 14 July 2009 - 12:32 AM
I wouldn't have it returning to the sump at all.
Rather a tap to drain it after a days racing.
#122 _Westie_
_Westie_
Posted 14 July 2009 - 08:54 AM
Right ok. I have seen cars with or without this return to the sump. Seems strange that there would be such varying views on this return.
Yeah, sorry I forgot to mention at the bottom of the can, there is another screw cap to drain the unit.
Which leads me to another question, on Sunday while draining this, I noticed that there seemed to be maybe 1/3 of a teaspoon of grit/sludgy substance which I thought was quite perculiar. Any thoughts on what this would be?
Thanks for you thoughts.
#123 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 14 July 2009 - 09:29 AM
Hey Westie
Probably remnants from the fabrication of "shiny" can inside of it prior to you useing it.
Good to know but,when i do actually get a "shiny" can i will give it a good flush before useing it.
It also interests me the different views on re-useing the oil in the catchcan. I can't see a problem in reuseing it if you drain oil into a suitable container and refill engine straight away after you have been out in the car?
Thanks for your photos mate ,surely there are some more setups out there.
Garth
#124 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 14 July 2009 - 09:54 AM
A variety of sizes available here
#125 ls2lxhatch
  • 5,332 posts
Posted 14 July 2009 - 12:48 PM
The breather line looks a little on the small side, how does it compare with the system you replaced?
I would consider drilling out the breather location on the rocker cover just behind the filler cap and running a second breather line to the catch can. If you do drill out the second breather then make sure you fit a baffle inside the rocker cover.
