The breather line looks a little on the small side, how does it compare with the system you replaced?
I would consider drilling out the breather location on the rocker cover just behind the filler cap and running a second breather line to the catch can. If you do drill out the second breather then make sure you fit a baffle inside the rocker cover.
The breather line 90 degree fitting is the same part that fits into the cover, so I assume that the hose which fits over it is also the same diameter.
I have read abit in this thread and the other catch can thread about having steel wool or something like that inside the can...what will this do?...and is this what the "off the shelf" units have?
I'm starting to think that a larger can is what needs to happen (atleast thats what CAMS wants - 3 litres), but I dont want to simply bandaid the issue of holding the oil somewhere else, when it should really be in the motor.
Cheers for your thoughts, they are all good
