650mm rolling diameter to big for rear lx hatch
#1 _ass308_
Posted 22 October 2008 - 01:16 PM
now its not quiet as bad as that looks.its about 2mm to big each side.thats not with clearance though.after a quick bit of investigation i found this
i remember my painter telling me they were a bit small,and we agreed to center the flare.u can just put your finger between the inside lip of flare,and the original lip.theese were purchased from rare spares.i cannot run the size i wanted to on the back now.the look on the painters face would be priceless though if i asked him to redo it .i have decided to fit 18x10 with a 265/35/18 on it,with a rolling diameter of 641mm.i am yet to confirm this fits though but it should.
anybody else have this prob,or are your flares bigger
Posted 22 October 2008 - 01:51 PM
I have a crummy set of flares on it at present but gives you a bit of an idea of where to gain space at the front edge:
Posted 22 October 2008 - 02:53 PM
Dont really have any pics to show what im talkin about though.
You can see how close mine is there..
This is when i first fitted my wheels and thought "bugger"
Posted 22 October 2008 - 03:11 PM
i had to butcher up the flares that were on the car to get them to fit.
Rocket put me onto a guy that has extra wide flares for this exact problem.
i fitted myne up and they required no chopping. I was a very happy camper.
They are currently at the painters getting painted and i will post pics in the next week or so with how they look.
Evan.
Posted 22 October 2008 - 05:35 PM
#6 _ass308_
Posted 22 October 2008 - 07:00 PM
#7 _ass308_
#8 _SS Hatchback_
Posted 22 October 2008 - 07:12 PM
Edited by SS Hatchback, 22 October 2008 - 07:13 PM.
#9 _SS Hatchback_
Posted 22 October 2008 - 07:22 PM
Edited by SS Hatchback, 22 October 2008 - 07:33 PM.
#10 _ass308_
Posted 23 October 2008 - 06:29 AM
evan sounds like u are on to a wina gw
76lxhatch my flares bolt up perfect besides being a bit small,and i cannot stretch the front out at all :(,and that wheel is definalty a 650mm roling diameter.
id like to save other hatch owners from the dramas,disapointment.dont fit flares that are to small across the wheel arch if u want a big rolling diameter
Posted 23 October 2008 - 08:09 AM
#12 _ass308_
Posted 23 October 2008 - 08:53 AM
#13 _Racelx_
Posted 23 October 2008 - 09:07 AM
Further to these posts, Can anyine advise whats the largest diameter and width front tyres you can throw on the front running flares? I am tossing up with either 17 or 15 simmons and will be running slicks. Not worried about legality as will be a race only car.
Posted 23 October 2008 - 10:48 AM
Another thing that i learnt is spend the extra $$ on getting some low profile tyres. You have to do a lot of searching but you can get them, and they cost about double, but still cheaper than having to order new flares and hving to get them painted, etc because you had to butcher up your old flares and are not happy with it.
Evan.
Posted 23 October 2008 - 11:14 AM
Racelx I have 225/50/15s on the front which are the largest diameter I can comfortably fit with the firewall lip flattened. I think maybe clearance could be created for slightly bigger diameter before having to resort to more major modifications. I don't really like the larger wheels because the tyre ends up too low profile but see this for example: http://www.gmh-toran.......c=30311&hl= . I think the hardest part is trying not to have the front and rear look too mismatched in size. The width and offset of the wheel affects the front end a lot too because it hits when turning, wheels that don't fill out the flares get more clearance but don't look as good.
#16 _Racelx_
Posted 23 October 2008 - 02:01 PM
I was thinking 17x9's and 17x11's based on all the threads i have read here ands in saying that I did have 255 x 50 x 15's and 275 x 50 x 15 on my SS hatch many years ago with no issues and yes i do miss it
Posted 23 October 2008 - 02:48 PM
Posted 23 October 2008 - 03:58 PM
#19 _SS Hatchback_
Posted 23 October 2008 - 05:06 PM
Ill try to get some pics up tonight for youthanks for the replies.sshatch u are a lucky man .maybee u have flares fitted, made by someone different.i would love to see some photos of your gaps,if possible .
Posted 23 October 2008 - 05:27 PM
#21 _rorym_
Posted 23 October 2008 - 05:54 PM
Guys,
The slicks on the front will be fine with 15" Simmons...For roads I have 225/50-15 on Challengers and they rub front and back on the front flares with the lip flattenned...Rolling diameter of 615mm off memory..the slicks are 585 r/d...no dramas with them.
#22 _SS Hatchback_
Posted 23 October 2008 - 08:50 PM
different angle
#23 _ass308_
Posted 24 October 2008 - 06:23 AM
#24 _SS Hatchback_
Posted 24 October 2008 - 02:35 PM
#25
Posted 03 November 2008 - 09:42 PM
just got my wider flares back from the painters today and all fitted up. here are some pics as requested.
Am very happy with them. They don't look quite as good as the ones that have the fiberglass at the rear that goes to the body but, you have gotta make a compromise. You cant really see it any hows with the wheels on. The only cutting i did was i took about 5mm off the inside lip before sending them to paint.
With the 295/50/15's that a rolling diam of 676mm. Commodore offsets on the diff, so 24 mm each side longer and 10 inch rims. Standard ride height. No scrubbing... just.
Enjoy
Evan
Edited by Evan, 03 November 2008 - 09:56 PM.
