dry decking
27 replies to this topic
#1 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 24 October 2008 - 01:56 PM
just wondering if anyone here has dry decked a 186/202 before? where did you drill and tap the block for the coolant lines?
#2 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 27 October 2008 - 07:29 PM
no one?
#3 rodomo
  • 18,030 posts
Posted 27 October 2008 - 07:34 PM
It's over my head sorry.
A bit like Kelvin :blink:
#4 racean69
racean69
  • 781 posts
  • Name:Rod
  • Car:LH sedan
Posted 27 October 2008 - 07:50 PM
makka what is actualy involved in this process?
benifits???
ps.. I went to school with Kelvin
Edited by racean69, 27 October 2008 - 07:50 PM.
#5 _why-psi_
_why-psi_
Posted 28 October 2008 - 09:49 AM
all water transfer holes between the head and block need to be plugged, headgaskets arent used, instead copper o-rings seal the combustion chambers.
#6 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 28 October 2008 - 01:32 PM
Use the welsch plugs..........often done on Nc engines, not necessarily dry decking them though.
Grant..
#7 _202LX_
_202LX_
Posted 28 October 2008 - 02:41 PM
What do you gain by doing this? The only thing i can see that it would do is improve the heads seal on the block.
#8 Com_VC
Com_VC
  • 411 posts
Posted 28 October 2008 - 05:42 PM
is it sorta like this?? http://www.farrfaste...ct turbo 6.html
When I sure this setup I had no idea what it was, this thread sorta put me on the right track. No idea what advantages it has though... Wouldn't mind reading a little more into it now..
#9 _why-psi_
_why-psi_
Posted 28 October 2008 - 07:44 PM
this is a "dry deck" block
no water transfer holes
Edited by why-psi, 28 October 2008 - 07:45 PM.
#10 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 28 October 2008 - 09:22 PM
Good for one shot ponies - drag-strip motors - but not so good if you want to drive it around town.
Grant..
#11 _why-psi_
_why-psi_
Posted 28 October 2008 - 09:26 PM
actually some 90s mustangs came out dry decked, and indy cars also run dry decks
#12 orangeLJ
Posted 29 October 2008 - 01:45 PM
so they have an external water gallery inlet to cool the heads?
#13 _why-psi_
_why-psi_
Posted 29 October 2008 - 05:22 PM
yep and block
#14 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 29 October 2008 - 07:39 PM
yep, thats what dry decking is, comes in handy if your sticking a head that doesnt belong on a 202 on. I was thinking welsch plugs would work.
#15 _Bomber Watson_
Posted 29 October 2008 - 07:54 PM
What about the funky shaped ones at the back???
Could you weld and re deck?
#16 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 29 October 2008 - 08:26 PM
we will see what i can do when i get a practice block
#17 rodomo
  • 18,030 posts
Posted 29 October 2008 - 08:33 PM
Blue 2850 here if you want it.
#18 Com_VC
Com_VC
  • 411 posts
Posted 29 October 2008 - 08:41 PM
are u sticking a ford head on it?
#19 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 29 October 2008 - 10:27 PM
yep, gonna give it a shot
#20 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 30 October 2008 - 01:06 PM
drill, tap, screw something in, then weld and surface the deck.
Simple really.
Don't just try and fillem with weld.
Grant..
#21 MRLXSS
  • 12,400 posts
Posted 30 October 2008 - 01:25 PM
I bet you never get around to doing it.... much like that starfire... LOL
#22 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 30 October 2008 - 05:43 PM
I might take you up on the offer rob, you can keep the innards though!
#23 orangeLJ
Posted 31 October 2008 - 08:27 AM
Ford head? which model?
How close are the combustion chambers in the head, to aligning with that on the 202?
would be a pretty massive job IMO, especially clearancing everything
#24 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 31 October 2008 - 12:57 PM
Chris,
It's the 3.9/4L heads AFAIK.
Same bore spacing. Spin head front to back.
You'll need to weld some meat to the top off side of the block (oil pump side).
Voila, cross flow.
It IS possible to redrill the water supply, but v. difficult.
Grant..
#25 Com_VC
Com_VC
  • 411 posts
Posted 31 October 2008 - 01:59 PM
I've seen a setup that a large chunk of aluminium was bolted to where the side plates that cover the lifter/pushrod area would normally go, this was with the crossflow aluminium head, I think xd-xf era?
Have also heard of an OHC setup which used the EA-AU style head.
Which head do you plan to use?
By the way, anyone know if the BA's kept the same bore spacing? twin cam, 16 valve 202 would be pretty awesome :)
In the future I plan to play around with one of these setups :)
