Jims Hatch
TempesT
, Oct 28 2008 10:22 PM
85 replies to this topic
#76
Posted 28 September 2011 - 08:44 PM
Yes jeff and I had to board a plane before I could pick them up.......................................damn :(
The GF is picking them up in the morning. Pics to come
of the calipers.......... not the gf
#77
_LS1 Hatch_
Posted 29 September 2011 - 01:10 AM
Darn....on both counts.
Good deal they've made it at least, even if you aren't there, lol..
#78
Posted 03 October 2011 - 10:26 PM
Tadaaaah! For all of you keen to see about shortening your diff:
Diff Length: 1380mm face to face with front mounted calipers
Rear brakes: Unknown (el ford) had PBr number on them
Wheels: 14x8 �s with 225/60/r14
I then sat the wheel on the face of the disc:
#79
Posted 03 October 2011 - 10:29 PM
Nearly enough room to slide your knob in there Jimmy.
WIDER TYRES
WIDER TYRES
Posted 03 October 2011 - 10:33 PM
Clearance of the tyre on the inside of the wheel:
#81
Posted 03 October 2011 - 10:35 PM
Is that an Alfa beside it??
#82
Posted 03 October 2011 - 10:40 PM
I am still thinking I might move the shock mounting points in a little so I can go bigger again, then do that nifty littl "mini tuck / tub trick"
If i get a chance (flat out atm) Ill draw up a crude version of a rim and the distance I worked out to be.
I am almost tempted to try and run a 9" rim but will most likly settle for a 8.5" which will measur 9.5 bead to bead.
ohhh and my brakes are here!
alfa............... yuk!
no it isnt
no it isnt
#83
Posted 03 October 2011 - 10:46 PM
its a triumph stag, tan leather, hard top / convertable and run a little v8
also there is the little TR7 there too
#84
Posted 03 October 2011 - 10:53 PM
Aha, now i feel ike an idjot.
Knew i recognized the front, had the wrong (very wrong) European manufacturer...
Very cool. I like Trumpies.
Posted 17 November 2011 - 08:01 PM
collecting parts!
#86
Posted 17 November 2011 - 08:04 PM
Brakes are to small, get bigger ones
