i304 into LH
_rammaLH_
Posted 30 October 2008 - 06:49 PM
Car has had a full bare metal respray in white with a black bonnet, everything re-chromed too so great shell for a project!
Currently has a warm 186, aus 4 spd n banjo thats all coming out.
Have purchased a 1990 model VN calais 5lt, complete running car to hack into and get stuff for the conversion. Only prob is its an auto and im goin with a manual so need to find either a supra 5 spd or v8 vn 5 spd.
Plan on using borg rear LSD diff and back end including brakes.
Will start off with a few questions and no doubt there will be many many more to come, just trying to make sure im awaire of everything i need to do before diving in head first!
First question
1. Do i need an engineers certificate to register car?
2. Do i need to upgrade to the VN front brakes to register?
3 Standard VN computer and loom, will it move straight over to LH without any dramas?
4. What sort of $$ am i up for to put a hydrolic clutch set up in? n where is best place to buy the "kit" from?
sorry bout the dumb ass questions, all pretty new to me, will attach couple of pics of the car. let us know what you think
thanks in advance!
brett
_rammaLH_
Posted 30 October 2008 - 06:53 PM
https://cache.gmh-to...ng/DSCF0888.jpg
_rammaLH_
Posted 30 October 2008 - 06:55 PM
Posted 30 October 2008 - 07:43 PM
_rammaLH_
Posted 03 November 2008 - 07:54 AM
Do the wiring kits come from castlemain rod shop or somewhere else?
much appriciated
brett
_Sammy_
Posted 03 November 2008 - 12:16 PM
if you just use the commodore engine and efi loom you would need to wire in 3-4 relays some fuses etc
you'd probably be best going for a commodore 5 speed as it will keep the computer happy with the right speed signal. but these days you can get conversions to just about anything.
personally i'd prefer the efi over a carby on that motor as it makes it a much nicer car to drive, but carby is certainly an option.
if you did go carby route then you would probably need to change a few things to get the dizzy happening, probably just a blue motor dizzy would get it working.
i suggest contacting the local rego authorities and they should be able to point you in the direct of what you need to comply with rego...
you may also need to put ventilated front discs on the car .... depends on the rules for your state though.
_AGGRO_
Posted 03 November 2008 - 01:16 PM
Cheers, Rowan.
_rammaLH_
Posted 03 November 2008 - 05:33 PM
Yeah going to do all brakes i have decided, commodore pattern makes bit more sence when it comes to buying wheels too. Will prob end up gettin some fr17 simmons or something down the track.
My mate that is doin the conversion for me just put a lexus v8 in a hilux, lexus's have bout 7 different computers apparently so doesnt think he will have too much of a hard time with vn computer.
thanks heaps for the info, im sure there will be a few more questions to come!
bretto
_rammaLH_
Posted 04 November 2008 - 07:29 AM
Posted 05 November 2008 - 04:18 PM
_HatchmanSS76_
Posted 08 November 2008 - 08:46 AM
Was thinkin lastnight, i might re-register the car while the 186 is in it then get working on it. If i get done then get it engineered. Any big worries with doin it this way?
You could do it that way even thou it's a bit nuaghty. Get caught and you'll get a yellow canary, don't think they can do much else unless it becomes an EPA thing for emissions than your bung hole will be the size of a dinner plate.
The only other issue is you may have a problem getting an engineer to sign off on everything exactly as you have done and you have to pull it all out and redo it his way.
There is another way of beating the emissions side of thing with an injected block but we're not allowed to premote it on here as it's illeagle, but it does involve having a spare engine block
Posted 12 November 2008 - 06:44 PM
_rammaLH_
Posted 19 November 2008 - 04:33 PM
http://cgi.ebay.com....em=270304249333
going to sydney friday night to pick it up. perfect for what im after! got an lsd, drives perfect, manual and has the wheels i was wanting to get down the track a bit anyway!! has done just over 200,000ks
picked it up for 2k plus one way flight and fuel back again, im wrapped!
seems bit too good to be rippin everything out of for the LH but ah well!
let the fun begin
_lx-304_
Posted 19 November 2008 - 06:30 PM
Posted 20 November 2008 - 07:02 AM
There is no 'pollution gear' as such on a 304 EFI V8, apart from the cat (which is part of the exhaust) & the vapour canister, which most LH/LX Toranas already have anyway.
Seems to be a lot of work to go thru (swapping blocks), just so you don't need a cat which are cheap as chips.
If rammaLH swaps all the necessary bits he needs from the VN V8 5-speed he just purchased & fitted everything in a tidy fashion any engineer would pass it, no worries.
Dr Terry
_rammaLH_
Posted 20 November 2008 - 05:36 PM
Just spoke to my mate thats going to be doing the conversion for me and discussing with him diff gears. what would you recomend for the borg warner lsd diff in the LH. was thinkin along the lines of 3.9's.....?
brett
Posted 20 November 2008 - 08:44 PM
_rammaLH_
Posted 24 November 2008 - 03:53 PM
so far
-sump
-shortened driveshaft
-shortened axles (do i need to shorten diff housings???)
-conversion kit for vn brakes to go on.
-engine mounts? or will it bolt straight in?
what else????
thanks heaps in advance
brett
_rammaLH_
Posted 24 November 2008 - 04:19 PM
Posted 24 November 2008 - 08:45 PM
#21
_rammaLH_
Posted 25 November 2008 - 02:42 PM
-Dont really wanna use standard front brakes cause got a set of f90 simmons which are commodore stud pattern
let me know if im on the wrong track with it cause its all pretty new 2 me!
anything else i need to add to my list of bits needed?
thanks heaps again
brett
#22
Posted 25 November 2008 - 02:54 PM
#23
_ado_
Posted 25 November 2008 - 03:15 PM
#24
_lx-304_
Posted 25 November 2008 - 03:41 PM
dave
#25
Posted 25 November 2008 - 03:43 PM
