i304 into LH
#76
_rammaLH_
Posted 08 February 2011 - 05:07 PM
The nice set of 15 inch simmons with yokohoma tread are no good as the inside of the front rims hit on the ball joints. Will run spacers down the track but wont get through engineers like that so looks like im up for another set of farken wheels just to get certificate done!!! GRRR!!!
anyone else come across this?
Brett
#77
Posted 08 February 2011 - 06:05 PM
#78
_rammaLH_
Posted 09 February 2011 - 06:30 AM
brett
#79
Posted 09 February 2011 - 08:40 AM
Around $150 + labour/rim.
#80
Posted 09 February 2011 - 08:26 PM
#81
_rammaLH_
Posted 10 February 2011 - 05:40 AM
Looking into getting some narrower inners for the two front wheels, should get me out of trouble if i can find any! on the right track you think?
brett
#82
Posted 10 February 2011 - 10:45 AM
With the rims it's more likely that you may need to go to a different offset like a hq.
#83
_rammaLH_
Posted 11 February 2011 - 06:02 AM
Will have a look tonight again but its rubbing on the plate not the ball joint itself!
Brett
#84
Posted 11 February 2011 - 02:41 PM
It might give us a better idea of the problem.
I assume Retro are quoting you the price with labour? They dont think that us [as comsumers] have the ability to sequence torque down the bolts. More to do with legalities me thinks.
#85
_rammaLH_
Posted 12 March 2012 - 07:21 AM
Considering i have gone from drum to disk brake rear end whats by mest booster/master cylinder combo?
Other question i have if if i put handbrake on floor on a lever instead of a pedal will i have any issues with engineers passing it?
Will get some more photos up as i progress but between now and december car WILL be finished and on the road finally. Cant believe it was 2008 when i first posted on the forum about my plans with the car. Understand why it takes people 10 years to do a full resto on a car now!
ramma
#86
Posted 01 December 2012 - 09:17 PM
#87
_rammaLH_
Posted 10 February 2013 - 07:30 AM
Rear brakes are now completed, full vs Commodore rear brake set up, disks, calipers pads and brake lines. Handbrake cable getting delivered next week then we will be fixing a few little things and will be off to exhaust shop. Been a bloody long project but I'm nearly there! Will get some pics up when I can figure out how!
#88
_rammaLH_
Posted 10 February 2013 - 07:57 AM
_red roar_
Posted 10 February 2013 - 08:40 AM
#90
_rammaLH_
Posted 10 February 2013 - 08:44 AM
#91
_rammaLH_
Posted 04 May 2013 - 03:30 PM
After 5 years it is so close now, putting some peddlers springs and shocks in front as the rear already has peddlers gear.
Will be off to exhaust ship in around 3 weeks, tidy up a few small things then get inspected and club plates.
#92
_rammaLH_
Posted 01 June 2013 - 08:15 AM
Pumped brakes up and pedal came good after a couple of leaks got sorted.
Booked in for exhaust Tuesday!
#93
_LH mike_
Posted 22 September 2013 - 06:07 AM
what hub did you use for the front brakes?
#94
_Wattsmini_
Posted 19 November 2013 - 11:17 AM
