HQ CALIPERS ON TORANA STUBS
_wardy_
, Nov 05 2008 06:03 PM
10 replies to this topic
#1 _wardy_
Posted 05 November 2008 - 06:03 PM
How many ppl out there have done it this way , pics would be great . Im tryin to do this atm but it looks like i will be grinding for ages ,unless ive picked up the wrong calipers. I can bolt them up fine ,its the tie rod clearance thats the trouble , i will take some picks and through em up shortly
Posted 05 November 2008 - 06:36 PM
Sounds like you don't have HQ calipers
And why are you doing it ?
#3 _202LX_
Posted 05 November 2008 - 06:41 PM
i have HQ calipers on my torana stub axels. They have to got left on the right side. this will make them upside down so every time u wanna bleed them u need to take the caliper off and turn it up the right way
#4 _wardy_
Posted 05 November 2008 - 07:01 PM
This is what i have so far , im thinking now i may have the wrong calipers
Posted 05 November 2008 - 07:33 PM
The calipers you have are HZ Girlock alloy. Different hose location to the WB ones used in the conversion thread. You would need to grind as much away as shown in the conversion threrad but hose isnt in as good a location. HQ PBR cast iron are the ones that need less grinding if any. Will depend on how your front end is set up. With the Harrop arms and the PBR caliper you shouldnt need to grind at all. Hose is still in the lower position unless you can find some genuine L34 calipers.
#6 _wardy_
Posted 05 November 2008 - 07:56 PM
So there HZ , i didnt want to buy new arms . Iwill keep playing with what i got for now and see if i can make it work.
Posted 05 November 2008 - 08:14 PM
I can post you some WB calipers if you want them.
I've been told that they are the best of all the HQ-WB calipers and it sounds like the hose is in a good spot.
PM me for a price. Also have stubs and discs if anyone is interested.
#8 _wardy_
Posted 05 November 2008 - 08:25 PM
pm sent
Posted 05 November 2008 - 11:35 PM
The best are the Girlock cast iron
Followed by the PBR cast iron
The alloy ones stretch under stress
Posted 06 November 2008 - 11:45 AM
Which model did the ^ calipers come from? HQ?
#11 _wardy_
Posted 06 November 2008 - 06:55 PM
I was told they were hq when i brought them , looks like they are hz after some members looked at them and i done some research today.
