High Performance Coating (HPC)
Posted 09 November 2008 - 10:22 AM
I had My 202 extractors ceramic "polished chrome" coated roughly 2-2.5 years ago by HPC in victoria.
No problems at all with dealing with HPC, they were quick and helpful and reasonably priced for the coating.
We have since sent around 5 different sets of pipes to HPC for customers.
I knew about the problems with the product being stained by oils and petroleum products, and I have paid the price with one section of my pipes on my 202 (fuel drip has left a nice mark in one spot)
The pipes always looked fine from a quick check when the car was up in the air (triples and manifolds make it hard to see from above) they had some water splatter on them, as to be expected from driving a car on the roads! But I would wipe off any marks and that was that.
Now I have recently pulled my engine out of the LJ, and obviously, Ive unbolted and removed my extractors too.
They were extremely dull and almost matt silver on some of the primaries, I thought to myself "they are just dirty" so I took to them with some warm soapy water and a sponge..... no luck, still dull.
Then I took a closer look and realised some of the finish had turned this dull silver finish, and some was still shiny... what the?
I then wrote to HPC asking if they had a defective batch or if there were certain conditions that would cause the total dulling of the HPC finish.
They responded (quickly too, which is a bonus) that the coating is only rated to 1300 degrees farenheit. (704 degress celcius. roughly)
They suggested my engine was running too lean and that would have caused the overheating of the pipes.
Those who saw my dyno graph from the dyno day I went to, would know that the engine is running very rich.
starting at about 14.25 AFR:P at idle, heading south and bottoming out at 10.5 at roughly 3000rpm and at top revs sitting at just under 11.00
They suggested that this combined with an inlet manifold gasket leak may be the cause of the finish dulling on some pipes but not others...
Im extremely happy with the performance of their product, the ceramic coating is awesome, it isolates the heat from exhaust gasses very well and stops majority of radiating heat.
If I had of known they would fade so quickly, I would have opted for a dull/satin finished pipe instead of the "chrome" look ceramic coating.
I will try and grab a few pictures of what they have gone like, but without any pictures of them when they were new, there wont be much to compare to but it still may be useful.
I am unsure about the restrictions of the coatings supplied by the other ceramic coating companies, this is only in reference to those provided by HPC in melbourne.
Posted 09 November 2008 - 10:38 AM
#3 _chrome yella_
Posted 09 November 2008 - 11:13 AM
Posted 09 November 2008 - 11:41 AM
Did HPC advise whether the coating had been compromised by this dulling?
Posted 09 November 2008 - 11:45 AM
His advice was to either dyno the car and then get the headers silver coated or use the black coating, I had the headers black coated.
Edited by ls2lxhatch, 09 November 2008 - 11:47 AM.
#6 _202LX_
Posted 09 November 2008 - 12:54 PM
#7 _tyre fryer_
Posted 09 November 2008 - 02:24 PM
what did people pay for HPC or jet hot coatings and what fnish did they get.
Posted 09 November 2008 - 07:32 PM
I agree, don't get the silver. It looks the best new and the worst used.
#9 _@milco@_
Posted 09 November 2008 - 09:11 PM
Posted 09 November 2008 - 09:28 PM
#11 _gtr-xu1_
Posted 09 November 2008 - 10:27 PM
Plus with mine the engines done some dyno runs and a couple off nitrous passes too
Edited by gtr-xu1, 09 November 2008 - 10:28 PM.
#12 _the gts_
Posted 09 November 2008 - 11:58 PM
ALX asked a very good question - did HPC advise if the coating is still good or not?
if you want shiny stuff get stainless tubes that can be polished (or chrome???) if you want heat reducing & corrosion resistance performance buy a type of ceramic coating!
Posted 10 November 2008 - 08:30 AM
I payed $200-$300 for mine to get coated (cant quite remember the dollar for dollar figure)
Im waiting on another reply from them to see what they say. I will ask them if the coating has lost its heat retention properties aswell, I just inferred it had not from their first email.
Posted 10 November 2008 - 08:59 AM
I have never heard that HPC will look the same after use, they only claim it will work better and look better than rusty extractors after use.
Posted 10 November 2008 - 09:06 AM
http://www.hpcoating.../pages/auto.htm
quote directly from their site-
HiPerCoat� exhaust coating protects headers against rust and corrosion while providing a beautiful, stain resistant finish that will not discolour like chrome or stainless
They sell the product as durable, and even state the finish is stain resistant and wont discolour (which i take to mean lose its shine or gloss or go orange/purple/blue like chrome does when heated)
Edited by orangeLJ, 10 November 2008 - 09:09 AM.
Posted 10 November 2008 - 10:41 AM
I see pacemaker dont makes these claims...
10) What is ceramic coating?
Ceramic coating is a thermal skin applied internally and externally to the header. This skin or coat, apart from other properties, consists of ceramic and aluminium. This combination provides very high thermal resistance and is an ideal coating for headers, pistons and other high temperature components. A by-product of ceramic coating is its high lustre or finish, and should increase the life of the product. We at Pacemaker recommend the use of ceramic coated finishes on all of our products
Posted 10 November 2008 - 10:45 AM
Posted 10 November 2008 - 10:50 AM
Posted 10 November 2008 - 11:18 AM
Mine have a nice petrol stain that wont go away....
Seems they do stain
#20 _The Baron_
Posted 10 November 2008 - 11:20 AM
I have just had mine done to prolong their life.
I went for silver as the black requires much higher temperatures to cure than the local guy could achieve in his baking booth. This means the black will remain "soft" and more susceptible to damage during installation than the silver.
Apparently black was best on turbos etc.
I would have preferred black but the installation is fiddly with 4 part HM L34 headers.
#21
Posted 22 November 2008 - 06:31 PM
To be honest, i'm not overly concerned as it's not a show engine bay, but i can understand how some people would be!
Well put thread!
Posted 22 November 2008 - 08:16 PM
I might shoot off a reminder on monday and see what they say.
#23 _CHOPPER_
Posted 22 November 2008 - 08:18 PM
#24
Posted 24 November 2008 - 01:19 AM
#25
Posted 24 November 2008 - 08:18 PM
http://www.ausrotary...7...a&start=140
Danny.....
