253 stroker options
_CHOPPER_
Posted 18 November 2008 - 02:10 PM
Generally I'm after sensible suggestions, but feel free to throw in a couple of silly ones, provided they're funny.
Posted 18 November 2008 - 03:59 PM
Posted 18 November 2008 - 04:08 PM
Bottom End
Holden 253 Block
Offset Grind Crank
Balanced and Blue Printed
305 Chev Pistons
SJ Chev Conrods
Compression 9.5:1
Bore 3.766 Stroke 3.180
You can probably go a bigger bore than i have, Something like 60 thou i have heard is still safe on 253's. Not sure what capacity that would make it?
But Ryan is right, P platers cant drive V8's on their P's... Unless this is for a track car?
_202LX_
Posted 18 November 2008 - 04:16 PM
_CHOPPER_
Posted 18 November 2008 - 08:06 PM
Here are my specs
A stock 253 is 3.625" bore, want to double check your numbers?
Didn't know about the new P plate laws, not my problem though.
_@milco@_
Posted 18 November 2008 - 09:33 PM
Posted 19 November 2008 - 05:29 AM
Posted 19 November 2008 - 06:51 AM
Stock 253 bore is 3.625"
Stock 305 SBC bore is 3.736"
030 over 305 bore is 3.766"
To get the right deck height with a 253 mini stroker you need to use the 305 piston which neccesitates the 0.110" to 0.140" overbore. Like I have said before, the 253 has really thick cylinder walls and can easily accomodate this sort of overbore.
FWIW a standard 305 SBC has a stroke of 3.48" so using a 355 crank in a 253 with the 305 pistons will net 305 cibic inches, a 030" overbore will lift it to 308 CI. The 305 pistons will need to have the tops trimmed down to remain level with the deck with this much stroke.
Hope this helps.
_CHOPPER_
Posted 19 November 2008 - 11:54 AM
Posted 19 November 2008 - 09:16 PM
Thanks for that Struggler, is that using 5.7" long rods and what pin height does the 305 piston have?
You will need to cut the pistons down regardless of rod length, obviously more with the longer rod.
As the 305 has the same stroke as a 350 I assume the pin height is similar, ie. 1.560"
_Toranamuk_
Posted 19 November 2008 - 11:00 PM
It was 3.543 stroke, used a 5.850 conrod with 2.00 BE & a Buick 3.720" piston, took it to 308 cubes.
Made good HP with a stock cam, heads, manifold & carby & made excellent torque & t was only 9.2:1 comp.
I still have the motor in pieces as the prototype crank was soft (120 rockwell), the replacement crank is longer stroke, 3.6".
Personally, for the expense of building it, I'd go with stock stroke, bigger bore, good comp, smartly ported small inlet valve heads with a 1.6" exhaust valve, ported stock dual plane manifold & a Rochester carby.
Cam doesn't have to be too big, look for a dual pattern, something around 224/228 050" will perform well, give a bit of a note at idle & still achieve reasonable fuel efficiency.
Ive had similar combo's in Torana's with Supra 5sp gear boxes & 3.7:1 gears run mid 13's cosistantly & pop out the occasional low 13 (13.2 was best) yet be very happy mild street cruisers.
There's lots of options.
I'll ring you soon about the 308.
Craig
Edited by Toranamuk, 19 November 2008 - 11:02 PM.
_CHOPPER_
Posted 19 November 2008 - 11:27 PM
The 308 was picked up and paid for yesterday.
Can the 253 be bored out to 3.800", or is that pushing it too far?
Posted 20 November 2008 - 12:27 AM
_trac-torqueraceengines_
Posted 20 November 2008 - 12:59 AM
Edited by trac-torqueraceengines, 20 November 2008 - 01:12 AM.
_Stuart_
Posted 24 November 2008 - 05:04 PM
Posted 25 November 2008 - 12:02 AM
Mort
Posted 25 November 2008 - 08:10 AM
Whats the difference between forklift LPG and normal LPG? I have an abundance of FL LPG around here....
Posted 25 November 2008 - 11:50 AM
Posted 25 November 2008 - 12:05 PM
_CHOPPER_
Posted 25 November 2008 - 02:42 PM
As there has been no definite answer posted, does this mean it's a 'maybe'?
#21
Posted 25 November 2008 - 03:00 PM
If you used an oversize there was not enough meat left as there is only 128tho from standard to water.
Was under the impression chev pistons are too fat.
Could be wrong as this was some time ago and Im sure there are OP who could have done the job differently.
Sorry I could not be of more help.
#22
Posted 25 November 2008 - 03:01 PM
I think 80thou? is the biggest you can go before you hit water, but that depends on how good your block is..
#23
Posted 25 November 2008 - 08:24 PM
I was under the impression, all those years ago, when these things were at their height of popularity, that 111tho over was a standard 305 Buick, not chev piston.
A Chev 305 and a Buick 305 have exactly the same bore and stroke.
Knock a welsh plug out of a 253 and measure the bore wall, its about a quarter of an inch thick.
Will it go 3.800 ? I don't know but I can't see why not.
MRLXSS You say 080 is the biggest overbore poss. yet your engine is .140 over...WTF ??
#24
Posted 25 November 2008 - 08:35 PM
LOL! Dont i look like a fool! I just repeat what others tell me! LOL (Bit like a pet bird... allo cocky)
Edited by MRLXSS, 25 November 2008 - 08:40 PM.
#25
Posted 25 November 2008 - 11:16 PM
Never late in a 308.
