You often hear people say increase the pinion angle 3 to 4 degrees down for better launch traction.
What does the statement mean?
The statement saying increase the pinion angle 3 to 4 degrees down from the static canceled pinion angle not from 90 degrees.
Gearbox down 5 degrees, the static canceled pinion angle is up 5 degrees then this would be reduced to up 1 or 2 degrees.
Gearbox horizontal, the static canceled pinion is 0 this would become down 3 or 4 degrees.
Gearbox up 5 degrees then the static canceled pinion angle is down 5 degrees the is increased to down 8 or 9 degrees.
How does this improve traction on launch?
The statement assumes that the pinion is rotating up 3 to 4 degrees from the static pinion angle as the suspension is loaded on launch. Increasing the static pinion angle down 3 to 4 degrees allows for the diff rotation which then results in the perfect canceled pinion angle. The canceled pinion angle means no vibration on launch which means better traction. Once you back off, the load on the suspension is reduced, the diff will rotate down and the uni angles will no longer be canceled. This is not an issue on a dedicated drag car as the run is over.
On a street car the load on the diff when cruising at highway speed is significant less than the launch load. As the amount the diff rotates varies you have to decide what is more important. The perfect angle for drag racing or the perfect angle for cruising.
The amount the pinion angle changes under load depends on many factors. As a starting point from this
website.
Factory bushings: Set Pinion Angle 3 degrees to 4 degrees downward.
Poly bushings: Set Pinion Angle 2 1/2 degrees to 3 degrees downward.
Solid bushings: Set Pinion Angle 1 degrees to 1 � degrees downward.
Edited by ls2lxhatch, 16 August 2009 - 01:08 PM.
