DO I NEED AN ENGINEERS?
_rammaLH_
Posted 09 December 2008 - 06:21 PM
Simple question that seems to have a different answer depending on who i talk to.
Im putting an i304, t5, Bwarner LSD, and front n back vn 5lt brakes in my LH.
The last 2 people i have spoken to have told me i dont need an engineers if i run charcole cannister and cats, just get rwc and show up at vicroads to register it using the 304 engine number.
whats the go?
brett
_Herne_
Posted 09 December 2008 - 08:38 PM
The States are supposed to be working off the one set of guides lately but this doesn't seem to be the case from what i read here.
Herne
Posted 09 December 2008 - 08:45 PM
However, if this is a new rego that involves a road worthy certificate, it shouldn't pass road worthy without an engineers report for at least the brakes and also floorpan and crossmember mods.
Edited by rodomo, 09 December 2008 - 08:46 PM.
Posted 09 December 2008 - 09:22 PM
_ass308_
Posted 10 December 2008 - 06:08 AM
_rammaLH_
Posted 13 December 2008 - 07:34 AM
_Yella SLuR_
Posted 13 December 2008 - 08:57 AM
_lx-304_
Posted 13 December 2008 - 09:09 AM
dave
_Yella SLuR_
Posted 13 December 2008 - 09:15 AM
Anyways, go and see an automotive engineer and they will sought you out.
Edited by Yella SLuR, 13 December 2008 - 09:17 AM.
_Herne_
Posted 13 December 2008 - 10:29 AM
if the motor uses cats from factory then it will need cats for rwc,doesnt matter what car it is in.it is the first thing the engineer will ask before you even bring it down.
dave
I have checked this out quite thoroughly with ACT Rego and the fact is that Cats are NOT required by them here when converting an LH or LX Torana to EFI. ACT rego are adamant about that. However and this is where the but comes in, we have one engineer here who insists on Cats regardless. I have yet to do battle with him on this one but it will come up in the future. He is the engineer I will be using. I realise different states authorities seem to interpret the rules differently so this may be of no use to someone outside of the ACT.
Herne
_Lxrana_
Posted 13 December 2008 - 10:36 AM
Edited by Lxrana, 13 December 2008 - 10:37 AM.
Posted 13 December 2008 - 02:00 PM
And that has been checked by me a number of times.
ACT obviously needs to look into some of the air pollution research and change their tune.
Makes it easier and cheaper though eh Herne!!
Ahhh, no. The ADRs for the VEHICLE as a whole are listed. i.ethe car is complianced to the ADR's not the motor
The emissions ADRs listed relate to the factory installed engine.
Once you remove the factory installed engine, you must comply with the appropriate ADRs.
There must have been a seminar or fact sheet because I have heard that almost word for word from two different engineers.
This is QLD, but it will give you an idea: Motor Vehicle Modifications
Here is the National Guideline : National Code of Practice for Motor Vehicle Modifications An engineer will know every clause in this document, but how they interpret it may be different.
Grant..
_Herne_
Posted 13 December 2008 - 02:07 PM
I would like a few more dB's allowed and i would like 10" rims allowed lol. I know eg that NSW can run 10" yet here at best we may only be allowed 9". With the appropriate engineers approval that is.
I guess the other thing that the ACT could do is to bring in special allowances for modified show type vehicles.
Fingers crossed this happens one day though I seriously doubt a dB upgrade due to the way some people abuse the system in quiet streets.
EDIT, sorry just realised this is becoming a thread steal, my apologies.
Herne
Edited by Herne, 13 December 2008 - 02:15 PM.
_Yella SLuR_
Posted 13 December 2008 - 02:21 PM
Pay an engineer to send you in the right direction. What he'll certify is what you can do.
_L_X_Hatch_
Posted 13 December 2008 - 03:20 PM
Posted 13 December 2008 - 03:33 PM
No engineers required if they fall under owner modifications.
Maybe best you talk to someone WHO HAS DONE the conversion IN YOUR STATE.
Posted 13 December 2008 - 03:35 PM
http://www.rta.nsw.g...ns_nov_2007.pdf
It is sort of vague but as far as I understand how the RTA interprets it (went through this recently with a VP 304 into a HZ) you must fit all the bits relevant to the engine if the engine is subject to a later ADR, where an early engine can be upgraded. This seems to normally include cats and ULP filler neck etc, BUT i've never understood why as the ADR relevant to ULP belongs with the CAR not the engine. So you should be able to fit say a VP engine complete into an LH using the canister and standard ECU (inc Memcal) off the VP but no cats. However no Engineers I know will certify it that way - they make you use the cats and the filler neck as that is what the RTA says has to happen.
_1uzbt1_
Posted 13 December 2008 - 04:21 PM
She was 100% legal and went over the pits and was approved,had a permits filled out and in the gloved box as required.This was about 6 or 7 yrs ago and may not be the case here or in any other state now.
Posted 13 December 2008 - 06:32 PM
_coupe202_
Posted 13 December 2008 - 06:43 PM
or he uses the adr's that the engine has to comply with example engine number. The best thing is to call Vic roads and
speak to someone in the engineering department, then speak to an engineer that is on the Vic roads list.
#21
_Herne_
Posted 13 December 2008 - 07:07 PM
Different states and territories interpret rules differently. Some have aligned with the NCOP while others are in the process of doing so. Even though there will be a generic code for all to follow, different states and territories will interpret and apply their own rules. In ACT you apply the emissions to the car not the engine, in NSW you apply the engine emissions to the car. Regardless, an injected engine is not offered as an option in a Torana so would require certification under the NCOP.
Well put Gerry, I was hoping you might give your input here, I am sure some think I make these things up as I go lol.
Herne
#22
Posted 14 December 2008 - 07:50 AM
You can not put a HQ 308 in a VS and have it registered in NSW.
#23
_Yella SLuR_
Posted 14 December 2008 - 08:13 AM
#24
Posted 14 December 2008 - 08:14 AM
True, but you can use a HQ block if it's rebuilt to VS specs, although it won't fit unless you use a gearbox adapter.
#25
Posted 14 December 2008 - 06:46 PM
Edited by Redslur, 14 December 2008 - 06:49 PM.
