HOLDEN GEAR NOBS
#1 _dave720gtr_
Posted 05 March 2006 - 04:15 PM
that knows what there tallking about so is there some holden gear nob exspert out there
that can shed some light on this as there are alot of different coments regarding wich
car /torana had what nob? an its confuzing please help as i think others would like two no this two ,
And its not that i think you guys that posted in my thred onthis subject dont no what your tallking about some of you may have owned these cars from new its just
confuzing , IF YOU WERE REBUILDING A GT,HO3 YOU WOULD WHANT THE RIGHT NOB on it
SAME APPLYS TO A GTR OR XU1 to me anyway, plus thay whant $39.95 for the shift paten plate for the lj conconsole i dont want too payfor it if i dont need it
some of you,s prob think who give a shit
So witch torry had what nob ??here we go AGAINE BIG CAN OF WORMES
PLEASE ONLY POST IF YOU REALY NO
.....DAVE.....
#2 _doublin gtr_
Posted 05 March 2006 - 05:46 PM
#3 _lx5008_
Posted 05 March 2006 - 07:40 PM
#4 _dave720gtr_
Posted 05 March 2006 - 08:41 PM
lx5008 email sent soundes like you been busy
#5 _devilsadvocate_
Posted 05 March 2006 - 09:24 PM
#6 _lx5008_
Posted 05 March 2006 - 09:30 PM
#7 _doublin gtr_
Posted 05 March 2006 - 09:36 PM
but gm3300 has a very original gtr built around the same time as yours and it has the shift plate and grain knob so it would be a safe bet to go with that on your car
hope this helps
Edited by doublin gtr, 05 March 2006 - 09:37 PM.
Posted 06 March 2006 - 06:58 AM
Posted 06 March 2006 - 10:29 AM
Mine is the same.my mates LC 71 Bathurst XU1 has the knob with the shift pattern and depress
Posted 06 March 2006 - 10:57 AM
I have an April '73 GTR which I have owned since March '76. Back then it only had 25K's on the clock and was completely original/unmolested, so no reason to believe the gear knob/console would have been tampered with. The gear knob has the H pattern with 'Depress' and no shift pattern plate on the console.
Cheers,
jpxu1
#11 _doublin gtr_
Posted 06 March 2006 - 06:20 PM
#12 _gm3300_
Posted 06 March 2006 - 09:56 PM
Torana's. It appears as though that in practice
many cars were fitted with different knobs as
standard, this could well be traced to a supply issue
at the time of manufacture, if the evidence you
have supports the type of knob and console your car
had from new then it would be correct, the parts
book only provides info if things where built
correctly, it doesn't allow for changes or disruption
to supply of parts during manufacture.
So starting from the beginning (you might want to grab a beer, there's quite
a list)
LC-Opel Box
KNOB-exc GTR-2811208
KNOB-GTR-2808589
LC-Aussie 4 speed
KNOB-2817736
KNOB-Lock nut-2805499
LJ-RHD-Aussie 4 speed
KNOB-2817736
KNOB-GTR-2817737
LJ-LHD-Opel Box
KNOB-2811208
KNOB-Lock nut-2809216
HQ-Aussie 4 speed 6/8cyl
KNOB-Floor shift(no console)-2817736
KNOB-Console shift-2817737
The 2817737 knob is the textured knob, the 2817736 knob is the
shift pattern knob. The Opel knob has a different size thread
hence the different part number.
I've included the HQ info because it uses the same patterned
knob as the LJ when using a console with a shift pattern plate.
I would say if your GTR/XU1 had a shift pattern knob then its likely
that other cars built at the same time would also be the same, also
it appears as though early cars had carry over parts from LC's, an
example is the "acorn" wheel nuts on early LJ's, the good thing is
with such a strong interest in the cars now more and more info
is coming to light.
grant
#13 _hg350_
Posted 07 March 2006 - 03:17 PM
The knobs are no longer available from Holden.
If you want an exact repro knob, let me know. Dont waste your money on the rare spares one, they arent even close to what an original one looks like.
Posted 07 March 2006 - 11:21 PM
jpxu1
#15 _doublin gtr_
Posted 08 March 2006 - 06:10 AM
my 3/72 adelade has H pattern
grants brisbane has robuck
jpxu1 73 adelade H pattern
these are all gtr,s so it may be another brisbane adelade thing
all xu1s ive seen had robuck
#16 _hg350_
Posted 09 March 2006 - 11:04 PM
Here goes
Holden production/design provided there would always be a visible shift pattern to the driver in a floor shift be it auto or manual. Except in the case of the very early LC XU1's & GTR's. XU1's received the HG 350 GTS knob and thus had no shift pattern displayed, and GTR's got the HK woodgrain knob which matched the steering wheel. These are the only exception as it was pre the ADR rule that required a visible shift pattern.
It was either on the knob itself or the console never both.
So in the case of LC XU1 (except those mentioned above) these cars DID NOT have the H pattern plate for the console, so they got the H pattern depress knob. As did LC GTR.
LJ XU1 had the roebuck grained knob as that model had the H pattern plate on the console from beginning to end of the model run
LJ GTR had the same as LC XU1 & GTR ( H Pattern knob) as they came standard with a console without the H pattern plate.
HQ GTS, LH/LX SLR, all had the LJ roebuck knob
LX SS hatches all received the H pattern knob for the obvious reason that there was nowhere to place the shift pattern on the console.
Standard A9X received the H pattern knob
T10 gearboxed A9X's received a unique white knob with black H pattern
c/- GM USA
Some people would think I have a knob fettish, but I just like to call it a mild infatuation
And before anyone ask's
PETER WISHES
#17 _dave720gtr_
Posted 10 March 2006 - 03:57 PM
thank you HG350 top work
regards gave
And thanks to every body
Edited by dave720gtr, 10 March 2006 - 04:03 PM.
#18 _gm3300_
Posted 11 March 2006 - 01:53 PM
Hi hg350, could you please provide the information that supports this theory? All the evidence i have says the robuck knob was used on the 82911 model. thanksLJ GTR had the same as LC XU1 & GTR ( H Pattern knob) as they came standard with a console without the H pattern plate.
grant
#19 _hg350_
Posted 14 March 2006 - 08:17 PM
AS GTR'S DIDNT have a H pattern plate on the console, they got the H pattern gear knob.
Also a quick look at a parts book you will see that GTR's have a different knob listed to an XU1
The Above APPLIES TO LJ
Roebuck was NEVER used on LC's.
#20 _finer70_
Posted 14 March 2006 - 08:49 PM
I have GTR's 70's build with Opel box. The knobs I have found for these is the smoothe H patern but they do not have depress. You do not need to depress to select reverse with an Opel just push sideways and up.
The first LC XU1 had the Opel so would it not have the same knob? If not, what would it have been?
The depress would be needed for the Ausie box I think.???
#21 _gm3300_
Posted 14 March 2006 - 09:48 PM
In the LJ parts book i have is this listing
PLATE - Gear shift pattern - 82911 part no 2815059
is this wrong?
torrynut has some pics posted of his 7/72 GTR, i don't know if the
console in this car is original, but it also has a shift pattern plate.
(mine is a late june car 27.06.72)
here's the pic, you can see the plate behind the boot(small square). thanks again
grant
#22 _gm3300_
Posted 15 March 2006 - 07:49 AM
only listing with the gear shift plate, if anyone has further
info please provide it
grant
#23 _hg350_
Posted 15 March 2006 - 08:36 AM
But
If you refer to all Holden print advertising at the time I have yet to see an interior picture of a GTR with a H pattern plate on the console, actually all pictures I have of brand new GTR's show the H pattern knob.
I have owned 2 GTR's, one was a second owner car that was untouched and it did not have a H pattern plate and it still had the remains of the H pattern knob. The second car while it had many more owners, it was still pretty much all there and again it did not have a H pattern plate. I have seen a couple of still with the original owner LJ GTR's and none of these had the H pattern on the console.
The parts book while always the best source of determining what is right and wrong also has mistakes in it. And there were always cars that ended up with something that they normally wouldnt have. I feel that from my experience that 99.9% of GTR's I have come across had the H pattern knob so I believe this to be the correct knob.
Where were the 2 cars you referred to built ?
Finer you are right there was no depress I just didnt check what I typed before I posted. I had to many knobs to think about
Either way
I think the best rule to follow is
If you have a H pattern console, you use the Roebuck knob
If you dont have the H pattern plate for the console you use a H pattern knob.
#24 _dave720gtr_
Posted 19 March 2006 - 07:23 PM
ANY ONE NO WHOT ITS OFF ?
