![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Off to willowbank
#51
_waz355_
Posted 23 February 2009 - 05:41 PM
Thats a sweet photo wayne.
What tyre pressures do you run?
#52
_Herne_
Posted 23 February 2009 - 05:48 PM
snip
try leaving from idle & see if it has any effect on your 60ft times, the convertor will still flash to 2500rpm thats where it's lock up point is, this should also hit the rear tyres harder causing them push the car forward, also play around whith tyre pressure's.
Our LC runs a 5000rpm stall convertor & we also run a trans-brake running through a 2-step, which allows me to select the RPM at which i what to leave the start line at, currently we are leaving the line from 3000-3400rpm (depending on track conditions) any higher & it hits the tyre's to hard & wheel spins instead of pushing the car forward, & thats with a std Torana rear end.
Just my thoughts, Cheers
Wayne
All good info OLC383 thanks for that I too was wondering as my car pushes though the front brakes too. I put it down to torque but wasnt sure. ( 355/Tri with 2500 stally )
A big help. TY as i was thinking there is no way I can load this thing up without breaking a cherry
![:)](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/smile.gif)
Herne
Edited by Herne, 23 February 2009 - 05:49 PM.
#53
_OLC383_
Posted 23 February 2009 - 05:56 PM
Wayne
#54
_waz355_
Posted 23 February 2009 - 08:17 PM
Just have to get time to put the box back in, hoping to have it going by the end of the week though. Making a few suspension changes as well - new shocks front and rear and raising the front a couple of inches.
#55
_HRV74_
Posted 23 February 2009 - 09:21 PM
![:spoton:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/spoton.gif)
Waz, 11.87 is awesome considering your terminal speed of 102! Can't wait to see what she does on a trouble free run.
Harve
#56
_Terrible One_
Posted 02 March 2009 - 11:10 PM
#57
_OLC383_
Posted 04 March 2009 - 11:34 AM
What combination are you running in the mighty LJ
Wayne
#58
_Terrible One_
Posted 05 March 2009 - 06:11 AM
Once I get the diff and a few other things sorted I'll go back for a re-tune on 1bar and see how much it makes.
#59
Posted 06 March 2009 - 07:54 PM
#60
_waz355_
Posted 07 March 2009 - 08:34 AM
hey waz, whats the spec of your motor?
Turbo pattern 308
Stroked to 355
Bored 60 thou - makes it 360 cubic inches
Did have Scat crank, now have eagle crank and scat rods
Venolia pistons
Waggot solid cam (610 lift, 260 @ 50thou duration, 290 total)
Solid lifters, adjustable yella terra platinum rollers with 7/16 studs and guide plates
Crow crome moly one piece push rods
RPM alloy EFI heads (flow 500hp)
Crow double valve springs
Full ARP stud kit in mains and heads
High volume oil pump
Hi energy sump
Harrop single plane manifold
Barry Grant 750 demon.
Block has been 0 decked and line bored
10.8:1 compression ratio
Pacemaker extractors with a twin 2 1/2 system
MSD CDI ignition
Desert cooler radiator with twin thermos
Thats about it. Made 341hp at the wheels a couple of months ago, but have since ironed a few more bugs out of it and is going better so I would expect over 350 at the wheels.
Edited by waz355, 07 March 2009 - 08:35 AM.
#61
Posted 09 March 2009 - 02:02 PM
#62
_waz355_
Posted 09 March 2009 - 02:51 PM
#63
Posted 09 March 2009 - 03:55 PM
#64
_waz355_
Posted 09 March 2009 - 05:57 PM
yeah, street driven, will see the strip from time to time though
Yeah I think 3.7's would be a good comprimise. I had 3.5's before and they were good on the street, but not that flash down the quarter.
