Transmission Cooler
#26 _ass308_
Posted 16 December 2008 - 05:33 AM
ss hatchback,what size stall are u running ?.and how far off the stall do drive on the freeway ?
#27
Posted 16 December 2008 - 10:37 AM
Currently doing this on mine, mounted smack bang in the front of the radiator (will see if i lose cooling).
Just wondering before i start drilling holes!!
Mike
#28 _Herne_
Posted 16 December 2008 - 10:52 AM
See pic.
If we can do it we hope to hide the the hoses entirely before Summernats but thats a big if right now, we are running out of time real fast. Also the radiator needs to have the cut ends of trans lines removed and plugged.
Am still hoping to get the engine out and do some work to hide the brake lines, trans lines and fix the leaking rear main and respray the engine bay!!!!! but work cant start until this Friday at the earliest and I have scrutineering on the 30th, sounds like we have plenty of time but we have Xmas right smack bang in the middle. Things might not get done....
Herne
Edited by Herne, 16 December 2008 - 11:00 AM.
#29
Posted 16 December 2008 - 11:25 AM
You should not need to cut the transmission lines, you should be able to slide the tube nut back and slip the cooler line over the flare.
#30
Posted 16 December 2008 - 11:28 AM
#31 _Herne_
Posted 16 December 2008 - 12:11 PM
That pic reminded me to at least unbolt and remove the old lines where we cut them
Working on the new boot design today, thats not yet finished either lol
Herne
#32 _j7723_
Posted 16 December 2008 - 12:17 PM
#33 _Herne_
Posted 16 December 2008 - 12:22 PM
Herne
#34
Posted 16 December 2008 - 12:40 PM
Mike
#35 _SS Hatchback_
Posted 16 December 2008 - 08:26 PM
Im running a 3200 stall and on the freeway its about 2800 at 100kph, but its fairly tight convertor and doesnt seem to be slipping there if i go up any steepish hills i drop a gear if i feel im to far under the markss hatchback,im getting my pwr radiator this week .im geting 2 types of coolers on it,for the trans.the standard radiator tank cooler,plus a air cooler mounted on the front between the grill and radiator.i was told u cant have to much trans cooling,and to get both.will see how it goes
#36 _SS Hatchback_
Posted 16 December 2008 - 08:28 PM
Mine run up under the drivers gaurd, it was a bit of a rush job when i did it but ill get around to doing a neater job, but they work and arent causing any issues so im not in a hurry.Hey herne and SS hatchback, where do the hoses run to get back to the trans?
Mike
#37 _2wild4u_
Posted 16 December 2008 - 11:47 PM
#38 _HRV74_
Posted 17 December 2008 - 08:09 PM
Dimension? Just wondering if it covers half your radiator like mine practically does.
Yeah covers pretty much half my radiator (passenger side), it extents down to basically level with the bottom of the bumper.
Engine has never reached 200 deg F.
Cheers, H
#39 _SS Hatchback_
Posted 17 December 2008 - 09:29 PM
#40 _the gts_
Posted 20 December 2008 - 08:28 AM
Anyone have thoughts on having a trans cooler taking up one side of the radiator and an engine oil cooler taking covering the other half, maybe with their own fans if necessary. the radiator will be a big aluminium one
#41
Posted 20 December 2008 - 12:13 PM
http://www.gmh-toran...showtopic=22327
#42 _the gts_
Posted 20 December 2008 - 10:56 PM
#43
Posted 21 December 2008 - 01:02 AM
#44 _SS Hatchback_
Posted 21 December 2008 - 09:33 PM
#45 _76S.L.R_
Posted 22 December 2008 - 04:56 PM
#46 _the gts_
Posted 23 December 2008 - 12:02 AM
are the fans set up to draw through rather than push?
Edited by the gts, 23 December 2008 - 12:05 AM.
#47
Posted 23 December 2008 - 01:20 AM
#48 _HRV74_
Posted 26 December 2008 - 12:29 PM
I have a Trans Cooler infront of my radiator and its pretty big(covers the left side of the radiator) might be wise for me to opt for a smaller one!
Maybe it's the type of oil cooler that's the issue, rather than the size. The oil cooler on Rob's (SS Hatchback's) car seemed to be quite thick/solid compared to mine - there might not have been much air flowing right through it, which caused the radiator to suffer. In this case, repositioning the cooler was beneficial.
With the right cooler, you can cover half the radiator with no probs, cause plenty of air flows through.
Is this your take on it Rob?
H
#49 _SS Hatchback_
Posted 26 December 2008 - 09:42 PM
