Need new Starter
#26
_76S.L.R_
Posted 27 December 2008 - 06:04 PM
#27
Posted 28 December 2008 - 02:26 PM
#28
Posted 29 December 2008 - 11:11 AM
Install a relay triggered by that dud wire and run a power wire straight from the battery.
This is the easiest and quickest way to fix it.
#29
_76S.L.R_
Posted 29 December 2008 - 04:05 PM
Looks like I'll have to go that way,I have no idea what sort of relay/type I need to buy 30 amp? then what terminals are used on the relay(which ones do I use on the relay to hook the wires to?) soon as I find out I'll go buy one..........................This is the easiest and quickest way to fix it.
#30
_lx-304_
Posted 29 December 2008 - 05:06 PM
dave
#31
_76S.L.R_
Posted 29 December 2008 - 05:26 PM
Correctjust double checking,but it is the purple wire from the harness plug you have connected to the c-terminal yeah.
dave
#32
Posted 29 December 2008 - 09:32 PM
wiring diagram is on them or search the forum/web.
#33
_76S.L.R_
Posted 29 December 2008 - 09:51 PM
#34
Posted 29 December 2008 - 09:54 PM
#35
_76S.L.R_
Posted 29 December 2008 - 10:33 PM
Sorry I shoud've been more clear= its not disengageing from the flywheelIs it not engaging or not disengaging?
#36
Posted 30 December 2008 - 12:16 AM
Or the starter pinion gear mechanically jams in the flywheel?
#37
_76S.L.R_
Posted 30 December 2008 - 12:38 AM
No it stops cranking when the key is let go,its just the Starter gear/cog wont disengage from the flywheel and retract back into the stanionary position,but I still dont know why? these starters are made specially for V8 holden red motor.Im running T350 box and the 308 is turbo Pattern,has this anything to do with it not lining up?,the papers with the starter say" Despite appearances this starter is purposely designed for Holden passenger vehicles fitted with V8 Holden stock(Not Chevrolet) engines from HK(1968) to early VT(2000) as long as they are fitted with standard extractors and ring gear.Does this men it continues to crank although you have let the key go?
#38
Posted 30 December 2008 - 07:15 AM
IS the flex plate standard?running T350 box and the 308 is turbo Pattern
Because-
#39
_76S.L.R_
Posted 30 December 2008 - 12:10 PM
#40
_76S.L.R_
Posted 31 December 2008 - 05:33 PM
I need to get my shit together and do what suggested on my" Hard To Start When Hot" thread= buy and wire in a TACHIOMETRIC RELAY so the fans only come on when the motor is actually running the sparky that wired them up obviously did it wrong and charged $$$ too!,I put the hose back onto between the Water Pump and Thermostat Housing and changed the Thermostat too ,seems to be running cooler now and fans are no longer working overtime...
THANKS TO ALL THOSE THAT CONTRIBUTED AND HELPED ME OUT HERE
Edited by 76S.L.R, 31 December 2008 - 05:34 PM.
#41
Posted 31 December 2008 - 08:43 PM
#42
_Yella SLuR_
Posted 01 January 2009 - 12:11 AM
Edited by Yella SLuR, 01 January 2009 - 12:12 AM.
#43
_PRO-192_
Posted 01 January 2009 - 12:33 PM
micko
#44
Posted 07 May 2009 - 08:42 PM
Just wanted to say thanks to all who contributed to this thread as the information was very helpful in finding a replacement starter for my 5.0L VK. Damn thing has had a reluctance to start when hot or left sitting for a few days (like an almost flat battery) for some time now. Battery and leads were known to be fine as they're relatively new so I decided to purchase the Jaylec Hi-Torque starter rather than another reco'd standard one. Best thing I ever did as the cranking issues have now disappeared.
Jaylec compared to the original.....
Cheers,
Jeff
#45
_76S.L.R_
Posted 07 May 2009 - 09:47 PM
Well at least someone got their car sorted!!, I still havent got my Jalec Starter to fit/ work correctly yet!, as stated earlier guys the starter cog keeps getting caught on the flexplate? from all reports their starters bolt straight on with no mods but mine gets stuck?.Today I made some shim plates for the starter( 1mm thick, one for each side) I havent had a chance to fit it all back up again, I allways though starter shim plates were really really thin but I rang Armadale Auto Parts over here in W.A yesterday and they said to make the shims 1mm thick and most people use from 1-3 of these stacked,you cant buy starter motor shims for 308's either! you have to make them.Im hoping to hell that it'll work with the shims I made and 1mm is the right size needed.Howdy,
Just wanted to say thanks to all who contributed to this thread as the information was very helpful in finding a replacement starter for my 5.0L VK. Damn thing has had a reluctance to start when hot or left sitting for a few days (like an almost flat battery) for some time now. Battery and leads were known to be fine as they're relatively new so I decided to purchase the Jaylec Hi-Torque starter rather than another reco'd standard one. Best thing I ever did as the cranking issues have now disappeared.![]()
Cheers,
Jeff
After reading lc2dr's post it sounds like this starter will fix my probs if I can get it lined up and makes me even more puzzled as to why mine won't fit right as it sounds like he's had no problems with installation or function, my S.L.R is running Turbo 350 trans but im told it should still bolt staight up
#46
_76S.L.R_
Posted 09 May 2009 - 09:37 PM
#47
_76S.L.R_
Posted 16 May 2009 - 02:11 PM
#48
Posted 16 May 2009 - 05:45 PM
#49
Posted 16 May 2009 - 06:04 PM
#50
_76S.L.R_
Posted 17 May 2009 - 05:59 PM
ARGHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!,I spoke too soon= just tried to start her up for a sunday drive about and again the starter got stuck on the flexplate!?? it went fine driving it about last week though!?now its getting stuck again for some bloody reason?.Well done - I'm glad you got it sorted. It's nice when cars start as they should!
lc2dr= did you have any probs fitting your Jalec Starter?,did it just bolt staight on? if so then for the life of me cant figure out why mine needs shims and still gets stuck?............
