hi guys,ive got this sway bar and no real idea how to fit it.i assume the centre goes in the centre and then position it where the holes go.if anyone can tell me where to mount it that would be good.it is a front bar and is missing u bolts,but what does it ubolt too.thanks heaps
dave
fitting sway bar
_lx-304_
, Dec 27 2008 05:20 PM
5 replies to this topic
#1 _lx-304_
Posted 27 December 2008 - 05:20 PM
#2 _homer_
Posted 27 December 2008 - 05:38 PM
R U sure it's for a Torana? Mine looks a tad different to that. (Although mine isn't installed yet)
#3 _clinto_
Posted 27 December 2008 - 06:02 PM
Gday
That looks similar to a whiteline front swaybar that i've got for my torrie. The two large brackets with the two holes drilled at the top attach to the outboard sides of your chassis rails (u'd have to rotate them by 90 degrees from the orientation in the picture) so they project downwards towards the ground.
The ends of the sway bar attaches to the lower control arm
The u bolts are then used to support the middle of the sway bar (see the bushes) and the ends of the u bolts go upwards through the bottom of the brackets
The bar at the bottom of the picture sits on top of that
I'll try to find some pics if you're confused
#4 _lx-304_
Posted 27 December 2008 - 06:30 PM
thanks for that clinto,it is a whiteline bar and another mystery solved.does this look right.
#5 _clinto_
Posted 27 December 2008 - 07:31 PM
yep thats it!
no problemo
no problemo
Posted 28 December 2008 - 01:31 PM
Pictures sent to me by Whiteline when I was enquiring about their sway bars.
