as the title
thinking of fitting a 16inch fan to my LJ. has MAX CURRENT DRAW : 11.3 AMPS. also will run spotties, couple of amps maybe
so am wondering if it would pay to upgrade the alt.. and if so.. how/with??
like can i just buy one and bolt it in? no wiring loom mods etc??
LJ - alt need upgrading with elec fan?
_SnotGobbler_
, Jan 04 2009 03:26 PM
4 replies to this topic
#1 _SnotGobbler_
Posted 04 January 2009 - 03:26 PM
Posted 04 January 2009 - 03:31 PM
yeah would pay to upgrade it.
sit down and work out what you gunna run and what it will draw
#3 _PRO-192_
Posted 04 January 2009 - 03:45 PM
i assume you intend to use a relay and a alternator upgrade never goes astray... i run an 80 amper on mine but 55 is also a common upgrade to... the get these pumping out good numbers like 130 amps these days so there are plenty of options
micko
micko
#4 _SnotGobbler_
Posted 04 January 2009 - 04:32 PM
well i have no idea if it needs upgrading n what i should be doing.. checking in here to find out from you guys hehehe
are they easy to do?? or do i need to get an auto elec to do it?
Posted 04 January 2009 - 05:17 PM
I'd talk to an auto lekky, only to make sure you get the altenator that has the same mounting pattern as yours.
I'd be buying something around the 80A mark, that way no matter what you want to run it should be plenty!
I got a Bosch 120A for the Monaro, but it's got a reasonable size stereo in it too, plus.. i like overkill
All we had to do was use a rattle gun to remove the nut from the front of the old unit, and rattle it on to the new unit! Viola, Pullet and all on new altenator!
it actually pretty well bolted in and we ran a couple of heavier feed wires to help get that power back to the battery.
Best of luck!
Best of luck!
