Yet another Hatch rebuild
#251
_sunburst73-xu1_
Posted 04 February 2013 - 07:55 PM
#252
_AD_75_
Posted 04 February 2013 - 08:04 PM
#253
Posted 04 February 2013 - 08:49 PM
Is it me or dose it seem that everyone that has laid a finger on this car gets a cramp in their middle finger??
Hahaha, this has to be the winning cramp then, frocken ET cramp.
Besides, we're special kids, you don't pick on the special kids.
#254
_BARRY JACKPOT_
Posted 04 February 2013 - 10:09 PM
#255
Posted 06 February 2013 - 07:46 PM
My pants just got tighter. When's it coming home?
Too many donuts ???
Went and saw Tim today, did a couple of little things while Tim was rerunning the hand brake setup, he said I should be able to bring it back home with in two weeks, so I'm looking forward to that
#256
_greenmachine215_
Posted 06 February 2013 - 10:07 PM
Be sure to drop past buddina and lay some strips on nickin way!he said I should be able to bring it back home with in two weeks, so I'm looking forward to that
#257
Posted 10 February 2013 - 01:16 PM
But soon realized that doing it this way was going to scrape against the tail shaft.
So Tim whipped up another bracket to run the cables lower and miss the tail shaft.
Its mounted to the lower section of the gearbox.
He made some brackets to mount the casing ends and welded them onto the seat mounts.
Tim cut the tank brackets to get clearance for the exhaust.
So that was excellent, now we can continue with the exhaust.
Tim loaded up the hatch onto his trailer.
And dropped it off to the Exhaust shop.
Only to find out that there is going to be a clash with the Handbrake cables, who knew, they were up nice and high, but I wanted the exhaust up as high as it could go, I have a stupid steep driveway. :(
So we decided to disconnect the cables, and sort it out later, and they carried on with the exhaust.
So I am quite happy with the way it came out
#258
Posted 10 February 2013 - 01:59 PM
So he came up with this idea, he's a bit of a clever chap.
Removed the exhaust and tail shaft.
Made a new bracket to bolt to the side of the gearbox.
Now it sits up nice and high.
Then he made new brackets for the casing ends again, but up in here now.
And with the cables in, I think it looks very neat.
Plenty of clearance with the exhaust and tail shaft in.
Cant see the cables now.
I went to put the air cleaner on, sounds simple enough, NUP, the bolt it came with, was too small. so Tim made one from two bolts.
One on the left is a stainless steel bolt that Tim had, and on the right is what the air cleaner came with.
He turned down and drilled a hole in his lathe.
And TIG'ed them together.
All fitted up.
Well that's about where were up to, thanks for looking.
#259
_LS1 Hatch_
Posted 10 February 2013 - 02:09 PM
#260
Posted 10 February 2013 - 02:27 PM
#261
Posted 10 February 2013 - 03:01 PM
#262
Posted 10 February 2013 - 03:20 PM
#263
Posted 10 February 2013 - 05:09 PM
So many photos and not one
to be seen you guys are slipping.
Yeah, pretty bad hey, I think the car did one this time, bloody handbrake.
hey paul where'd you get the exhaust done? & what size speed demon are you using? the old boy has a new 750 speed demon siting around that was bought for his C3 350 thats no longer required......
Exhaust was done in Nambour on the sunny coast, cant remember what they were called, Tim would know.
The Demon I have is an 850, I did have a 750 DP Holley on there, but went for the demon.
Thanks Stinga, Tim's pretty good at sorting the issues out, seams to like the challenge.
Thanks Jeff, all hatches look good.
#264
_BARRY JACKPOT_
Posted 10 February 2013 - 06:46 PM
#265
_rob350hatch_
Posted 10 February 2013 - 07:22 PM
Edited by rob350hatch, 10 February 2013 - 07:24 PM.
#266
Posted 10 February 2013 - 07:25 PM
#267
_Emu_
Posted 11 February 2013 - 10:06 AM
#268
_LS1 Hatch_
Posted 11 February 2013 - 11:56 AM
Especially ones with big wheels
#269
Posted 11 February 2013 - 05:34 PM
tims work is impecable
and from your build thread so is yours paul!
enjoy
#270
Posted 11 February 2013 - 05:50 PM
#271
_Pro308olh_
Posted 11 February 2013 - 05:56 PM
Edited by Pro308olh, 11 February 2013 - 05:57 PM.
#272
Posted 11 February 2013 - 06:34 PM
#273
Posted 11 February 2013 - 07:43 PM
Hi Trofa, Mate I thought about doing a loop, but I'm going to use it as a cruising car, if my idea changes then I will do one.
Thanks for the positive feed back Chris, Rob, Jeff and every one else, It certainly helps with the motivation, cheers.
Oh, and Dane'o, this pic should make up for the lack of Birds in the last lot of photos.
#274
_sting_
Posted 11 February 2013 - 07:44 PM
cheers sting
#275
Posted 11 February 2013 - 08:13 PM
Here's his thread.
http://www.gmh-toran...ge__hl__+axistr
