LC 2 Door
106 replies to this topic
#76 debkar
debkar
  • 911 posts
  • Car:1971 LC 2 Door
Posted 19 December 2009 - 07:47 PM
looks nice. Im glad the car has gone to a good home..Cheers..and merry xmas
Hi, many thanks , and to you,
#77 ido09s
ido09s
  • 337 posts
Posted 19 December 2009 - 08:52 PM
Looking good Simon. We need some full car pics now :)
#78 debkar
debkar
  • 911 posts
Posted 21 March 2010 - 01:02 PM
Hi all,
Not a lot of progress on the car recently, working mainly on interior. Have added fibre glass door trim tops to my GTR trims, and will run these in the car. Speaker holes were cut by previous owner, why would anyone do that? Also have GTR trim for the seats, will carefully remove the S trim, and store.
Dash is ready to go in, gauges with needles re done.
Reco gearbox to go in as well, nice ratios compared to my current M20 box. Shorter shifter as well.
Building shed at the moment for the Torana, so will wait until that is finished to do much more. Working under the carport isn't the best. Car needs a radiator and exhaust.
Dash, ready to go in
Front trim
Rear trim
Dash, sorry bad pic
Edited by debkar, 21 March 2010 - 01:04 PM.
#79 ido09s
ido09s
  • 337 posts
Posted 21 March 2010 - 03:51 PM
so glad YOU bought this car :D Its looking so cool now :D
#80 debkar
debkar
  • 911 posts
Posted 21 March 2010 - 03:58 PM
Many thanks, delayed putting it back on the road to try and get everything spot on,
Regards Simon
#81 ido09s
ido09s
  • 337 posts
Posted 26 May 2010 - 10:13 PM
any more updates Simon?
#82 debkar
debkar
  • 911 posts
Posted 27 May 2010 - 08:11 AM
Hi Brad,
Just finished my shed at home, so work will start again, I haven't done anything for a couple of months,
Hope to have more done soon,
Regards Simon
#83 ido09s
ido09s
  • 337 posts
Posted 27 May 2010 - 12:57 PM
Cant wait mate. Will be good to see the finished product
#84 blake
blake
  • 267 posts
  • Name:Blake
Posted 27 May 2010 - 08:04 PM
Hi all,
hey mate, just wondering how you got the highlited red from 5500 rpm to 7000 rpm so red, also on your oil and fuel etc, it looks really good and i wanted to do this to my gtr dash, but just dont know how.
cheers Blake
#85 debkar
debkar
  • 911 posts
Posted 27 May 2010 - 08:12 PM
Hi Blake,
I bought the gauges like that and put them in my surround. I was told they were re coloured by Dash Original, but I don't know for sure. When you look really close, the new red is a little larger than the old markings. But they look great in the car,
Regards Simon
#86 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 11:38 AM
Quick update.
In the last year I have removed front end and replaced all front end bushes, ball joints, rotors, pads, mounting rubbers and brake hoses. As below the front end is back together, and I have Lovells springs sitting in the car to gauge the ride level, it looks good, so they will stay. The front end was in good condition, but I thought it best to replace everything, prior to going back on the road.
I have reconditioned steering rack to go in, and new rubber steering coupling.
Induction is now triple 40 mm Dellortos. I have found 40s a little more street friendly than 45s, in the past, so I have 40s with at the moment 32 chokes. The motor since fitting these is very responsive , even from around 1500 rpm . Motor revs well up to my self imposed red line of 6000rpm. I will run 2.5 psi fuel pressure via regulator, as I've found Dellortos do not like much more fuel pressure than that. All lines from the pump will be braided with Earls fittngs.
I have decided to repaint the car, and have started stripping down again. this time around it will be painted Monza Red. Wheels will be the '75 Sprintmasters still, but I have been considering 15 inch Convos,
Thanks for viewing
Simon
Edited by debkar, 28 August 2011 - 11:40 AM.
#87 ido09s
ido09s
  • 337 posts
Posted 28 August 2011 - 07:24 PM
Looks good mate. How those springs do not bind is beyond me!!!!
Colour, i will reserve my comments till its finished as it looked to cool in white :D
Keep the Sprintmasters and get the Convos as well as they are a cool looking wheel and suit Torrie's really well :)
#88 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 07:49 PM
Hey Brad,
Yes, springs appear to have dropped a bit, bump stop clearance is less than when I first set them in.
I know, hard decision to change colour, but I am big fan of red LCs, and body is nice and straight, should come up well.
Yes, think I'll go Convos, 6inch, but definately will keep the '75 Sprintmasters
Regards Simon
#89 ido09s
ido09s
  • 337 posts
Posted 28 August 2011 - 08:15 PM
It will look sweet i am sure whatever colour it ends up :D
#90 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 08:20 PM
Thanks mate, was a great starting point, that's for sure, straight, rust free, good panel fit
That's the same block in the car, that came with it, even that was very good when sonic tested for wall thickness,
Regards Simon
#91 _SLR Torrie_
_SLR Torrie_
Posted 28 August 2011 - 08:48 PM
Love the car Simon!! Can't believe how clean it is!
Had it been previously restored or has in been rust free from the factory?
Thanks John.
#92 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 08:58 PM
Hi John,
I've been right over the car, it has had a drivers side lower front guard section fitted, passenger side lower guard looks to have had a little repair work and some small holes filled with s mig on the passenger side front floor, apart from that it is very clean.
Had , I think an original 89 odd thousand miles on when I purchased it from a forum member.
It is one of the cleanest LCs I had seen in a long time,
Regards Simon
#93 ido09s
ido09s
  • 337 posts
Posted 28 August 2011 - 09:00 PM
This car should think itself lucky as i was going to cut it up and go drag racing with it :( You saved a life Simon lol
#94 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 09:05 PM
Hey Brad,
Ah yes, that's right, I still reckon that would have been pretty wild, the set up you had in mind,
You still going to put that running gear into something else?
Regards Simon
#95 ido09s
ido09s
  • 337 posts
Posted 28 August 2011 - 09:21 PM
Nope. My girlfreinds car has run 11.0 with a best mph of 135 so that will be fast enough for me :D
#96 debkar
debkar
  • 911 posts
Posted 28 August 2011 - 09:40 PM
Sounds good, that is quite quick,
#97 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 28 August 2011 - 09:55 PM
G'day Simon, are they the right banjo fittings for the webers?
#98 debkar
debkar
  • 911 posts
Posted 29 August 2011 - 08:20 AM
Hey Stinga,
They are for Dellortos, I think they fit Solex as well, but nor Webers, they are 12mm but I think Webers are different, I could be wrong.
I don't have a weber to try them on,
Regards Simon
#99 debkar
debkar
  • 911 posts
Posted 29 August 2011 - 06:42 PM
Hey Stinga
Here is link , Dellortos are listed as 12 mm x 1.25, Weber listed as 12mm x 1.5,
Regards Simon
http://www.earls.com...CARBURETTOR.PDF
#100 _Ozzie Picker_
_Ozzie Picker_
Posted 29 August 2011 - 07:06 PM
looking good simon,
the car looked way to good to repaint,but you may aswell recolour it in your favorite combo,i think the convo,s will look sweet,but i also like sprintmasters.
dellortos fill the engine bay,they look fully sick mate.
cheers craig.
