I remembered that there was two master cylinders for the XD and thought they would be for the disc/disc and disc/drum applications. The part I was thinking of is P10049 which is for the disc/disc and disc/drum panel vans, utes and wagons. I expect that the difference is in the prop valve.Same part # for both
P10050 ... so doesn't matter
Commodore booster and Master on LH/X.
#26
Posted 05 February 2009 - 01:13 AM
#27
Posted 05 February 2009 - 07:44 AM
Posted 05 February 2009 - 06:29 PM
Posted 06 February 2009 - 09:39 PM
Posted 06 February 2009 - 10:10 PM
I'm ignoring any discussion on the "new wheel"
#31
Posted 06 February 2009 - 10:53 PM
Edited by rorym, 06 February 2009 - 10:53 PM.
#32
Posted 06 February 2009 - 11:04 PM
#33
Posted 07 February 2009 - 09:37 AM
Posted 07 February 2009 - 12:23 PM
Posted 07 February 2009 - 12:58 PM
#36
Posted 07 February 2009 - 01:36 PM
Posted 07 February 2009 - 03:34 PM
Yes it will suit disc rear.... but its not actually relevant anyway
Since a Torana weighs differently and has different sized rear brakes to a Falcon
Show me a formula that can calculate the desired pressure for a car and I'll start to believe it matters to people like us
You probably use a bias valve on the back that you adjust anyway don't you ?
#38
Posted 07 February 2009 - 03:38 PM
Posted 08 February 2009 - 02:14 PM
Posted 08 February 2009 - 02:26 PM
#41
Posted 08 February 2009 - 02:29 PM
Posted 14 February 2009 - 10:54 PM
Just noticed the WB statesman booster has the bent arm on it already...Fit OK?
I believe you Dattoman, but why wont it fit?
Still wrong pushrod length or Mounting holes wrong position or Booster physically too large diameter?
#43
Posted 18 February 2009 - 10:52 PM
Posted 18 February 2009 - 11:46 PM
#45
_Drue_
Posted 21 February 2009 - 11:03 AM
i have just had a look at this thread and am a bit confused.
i have a 76 lx sedan. (straight rod i guess.)
i want to get rid of the proportinal valve and have a later plastic comodoore style booster/master clyinder.
so what do i need?
i have std torana brakes disc/drum
i do want to up grade them to comodoore later (if that can be done)
Posted 02 March 2009 - 08:12 PM
Is the double diaphram commodore booster only in V8 commies or in 6's as well?
#47
Posted 03 March 2009 - 06:37 PM
I'm pretty sure it was used for the 6 cylinders as well as V8's (VB through to VR).
#48
Posted 03 March 2009 - 07:07 PM
VL turbo and V8
VN-VR all V8 and alot with FE2 suspension
Just go measure the bugger
#49
Posted 03 March 2009 - 08:21 PM
#50
Posted 05 March 2009 - 07:01 AM
How is this going rory? thinkin of doing the same. the torana master just dont cut it i think with the skyline calipers.
Still waiting for delivery of both of them TUF...One guy hasnt answered emails since 20 Feb...I paid for it on 11 Feb.
