it seems a 8 inch rim with 4 1/2 inch backspace,running a.235/40/17.thats a 617mm rolling diameter.fits in the front a a lx torana.with maybee minor srcubing sometimes
my brake assembly comes out 1 inch more than standard.so im thinking i get 1 inch more back space and get 5 1/2 inch backspace ?.
if the answer is yes.ive done the calculations and a 17x8 rim,with 5 1/2 inch back space will be 25mm,wider than the rim on the car at the moment.the tyre will also be 12mm bigger in diameter.the car also has to be lowered yet,around 45mm.
it looks like 1 inch wider will be a tight fit.does any think 1 wider will be to big ?.
current ride height
shots of clearances
ordering the wheels thursday morning.any opinions ?
